Question about Toshiba TP61H60 61" Rear Projection Television
Need screen for 61" toshiba theaterveiw projection tv
    Scholar:
  • 56 Answers
The part numbers for the screens for the TP61H60 are:
Fresnel (interior screen) 23837528
Lenticular (exterior ribbed screen) 23837528
They used to run about $170 for each plus shipping which was expensive due to their size. The problem is that they are discontinued. I have had success using screen from other manufacturers in different sets, i.e. a Hitachi screen in a Sony TV. Even if you can find a larger size screen you can cut it down using a utility knife and a straight edge. I have done that as well.
Good Luck!
Rob
Posted on Nov 26, 2008
Need manual for toshiba 61'tv
just enter user manual for toshiba 61 TV into your browser or on their website
Nov 13, 2011 | Toshiba 65HM167 65" Projection Television
Toshiba no picture
then your optical section has fault.
Mar 17, 2008 | Toshiba 61A61 61" Rear Projection...
I forget the pin code for my 61' toshiba tv how do i clear it
Dont know what model or how old your TV is but try this,
While the enter PIN code screen is displayed, press the RECALL key four times within five seconds and the PIN code will be cleared so you can enter a new PIN code but it has to be with the original remote. Worked with my old Toshiba TV about 2 years ago.
If it doesnt work I only waisted about 10 secounds of your time and I'm sorry.
Nov 13, 2011 | Toshiba Televison & Video
I have toshiba theaterveiw and when i turn it on it powers up then it powers down then the red power light blinks on and off
The flashing power light on those Toshibas is usually caused by capacitors on the power board having failed solder connections. I have fixed them before by removing the power board and resoldering the capacitors. If you have experience with soldering and electronics it is an easy repair. Most shops will recommend replacing the entire board since their labor to repair it would probably cost more. Toshiba put out a service bulletin on this issue which a good technician should be aware of. (If memory serves the capacitors are C109 and C110. Since your TV still turns on you probably haven't blown fuse F860 which often blows when these capacitors act up.)
Jun 20, 2011 | Toshiba TP50G60 50" Rear Projection...
Toshiba tv 61a61 screen all red
jeffjo7,
Your unit is 10 years old and more than likely needs the drives adjusted on the blue and green guns. I have a tip at http://www.fixya.com/support/r6814105-adjust_screen_drive_crt_projection_tvs
which explains the process to adjust the screen drives for the best picture.
Thanks for using FixYa and for the great rating.
hardrocko
Mar 14, 2011 | Toshiba 61A61 61" Rear Projection...
Is playing video games bad for my TV
Absolutely not. Your set is the safest type of tv to play games on. Plasma sets are the worst type to play games on due to screen burn in. You are good to go.
Jul 14, 2009 | Toshiba 61HX70 61" Rear Projection...
BLINKING POWER LIGHT AND TV DOES NOT POWER ON
I have a toshiba 61 inch projection tv the power light flashes with no picture any easy fixes?
Jun 24, 2008 | Toshiba TP61G90 61" Rear Projection...
Toshiba TP61G60
Hi.
I have toshiba TP61G60 projection TV and accidently broke the 61" grey plastic screen which is covering a glass screen.
Does anyone know wher to buy that screen?
Apr 15, 2008 | Televison & Video
Toshiba Rear Projection TV Problem
Toshiba is one of the few sets that do not have a diagnosis feature built into the power light , Toshiba has to be able to light the screen to access its self diagnosis features. So you will most likely need the service manual to check the voltages in order to properly diagnose your set. You can get a service manual at the following link, and they will email it to you if you would like. here is the link.
http://servicemanuals.vstore.ca/
Feb 09, 2008 | Toshiba 61HX70 61" Rear Projection...
Screen replacement
try contacting www.tvscreenprotectors.com for discontinued screen replacements
Nov 25, 2007 | Toshiba TZ50V51 50" Rear Projection...
Toshiba TP61H60 61" Rear Projection Television Logo
82 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
