Question about HP Office Equipment & Supplies
How to change a cartridge on c4345 - HP Office Equipment & Supplies
    Scholar:
  • 174 Answers
Installing new cartridge:
If you are putting in a new cartridge, make sure to remove the tape.
Turn on the unit, then open the print carriage access door. The print carriage moves to the center of the unit.
Fit the cartridge into the proper carriage.
The carriage with the gray latch is for the black ink cartridge (HP 56), or the optional photo cartridge (HP 58).
The carriage with the blue latch is for the tri-color cartridge (HP 57).
Slide the cartridge into the carriage at a slight angle, as shown in the illustration above. When the cartridge is fully inserted into the carriage, rock it upright.
Hold the hinged flap of the latch out while lowering the latch.
When the latch is fully lowered, release the hinged flap. It should catch under the tabs on the carriage, as shown in the illustration.
Close the cartridge access door.
The LCD display may indicate that the cartridges need to be aligned. Press Enter on the front panel. You may discard the alignment page that prints.
Remove cartridges:
Press down lightly on the top of each ink cartridge latch and pull the lower section of the latch out to release the cartridge.
Pull the cartridge out of the print carriage and relatch the empty print carriage. The print carriage may move to the right automatically, and if the latch is up, it could be damaged.
Posted on Nov 26, 2008
Is it possible to check ink levels on an HP C4345 All-In-One Printer/Fax. I use Windows 7. Have gone into Properties, etc w/no luck. Thank you.
First, I would try printing a document, and a window should pop up in the lower right corner. If not, make sure that you have all the necessary drivers for the printer installed, as that is the only way to check your ink levels with the HP C4345 All-in-One Printer. In my experience, you must use new HP printer cartridges (rather than ink refills) to have an accurate reading of the remaining ink.
Aug 11, 2011 | HP PhotoSmart C4345 AllInOne InkJet...
I have HP printer C4280 All-in-One my paper got jammed
Just press the Power button once. While the printer is Powered ON.
It will try to throw out the Jammed Paper.
Then remove the Power cable from the back of the printer.
Open the Real Door and try to take out the Paper stuck in there. Manually clean the rollers with a lint free cloth.
Jun 02, 2010 | HP PhotoSmart C4345 AllInOne InkJet...
I can't scan anything on my HP PHOTOSMART C4345 All-In-One
Try this: Power down the computer and printer, connect the usb to a different usb port. Reboot. The Mac should register the changed location.
The older apples used to be very sensitive to port selection and peripherials serviced. Perhaps they still are.
Regards
apeal
Aug 21, 2009 | HP PhotoSmart C4480 All-in-One Printer ...
How do i manually answer an incoming fax on my HP all in one c4345?
HP has left this as a mystery. I read the manuel and, while it states that one can receive a fax manually, it does not tell you how. Absolutely crazy.
Jul 05, 2008 | HP Office Equipment & Supplies
137 people viewed this question
Ben Johnson
