Question about Senco SNS41 16Ga Stapler 1" 2"
Narrow crown stapler won't fire
I can't get my narror crown stapler to fire it's like it's jambed but it's not
  • Anonymous Mar 16, 2014
    i cant find staples to fit stapler they are half inch crown
    President:
  • Senco Master
  • 1,388 Answers
If the gun has never been opened, the problem could be a lack of oil or worse, too much of the wrong kind of oil. No oil causes parts to stick. Too much of the wrong kind of oil caused the orings to swell and jamb parts. Carefully open gun to preserve head gasket and check for piston travel all the way down to the bumper. Piston should not be too tight, nor drop to the bottom under its own weight. The driver has a groove on one side that should align with the grove in the nose and it should not be bent. Next check the head valve by pushing the valve into the head with your thumbs. the valve should travel about 3/8 inch. If stuck apply air pressure to hole where gasket sits on head. The valve will pop out. Clean and lube parts replace orings or upper bumper if cracked. Assemble and test. Parts are not expensive at www.toolpartsdirect.com, enjoy
Posted on Nov 27, 2008
Where do I get staples for a B&D stapler? #9700
There are several brands of staples that will fit your stapler and the price will vary according to the depth of staple you are looking to buy. Arrow brand staples are the most common. All the ones I saw that fit the 9700 are Wide Crown Swingline Heavy Duty
Arrow 606 Wide Crown Swingline Heavy Duty 3 8 Inch Staples 1 000 Pack
Jan 06, 2015 | Staples Tools & Hardware - Others
I have a ns100a porter cable narrow crown stapler. The driver will not retract, so it will not shoot staples. what can be the problem and how can I fix it? Thanks Pam
Usually when the driver is slightly bent, it will not retract. Easy to check. Remove the head and pull out the cylinder and driver together. Adjust the driver or replace as needed.
Jun 04, 2011 | Porter Cable Cable 18 Ga 1" Narrow Crown...
When I pull the trigger to shoot staple on my paslode 1/2 inch crown 16 gauge stapler it just makes the sound of air coming out...it does not fire
I have had this problem with simular nail guns. Most likely ( in my experience ) it is the driver. It has either come unhooked or broken.
Feb 01, 2011 | Garden
Can not drive nails. Loud air hiss at top on tool
you have an air leak and you have to fix your stapler nailer hope its not cracked but just a seal
Sep 24, 2010 | Stanley Bostitch Sb 2IN1 2 In 1 Narrow...
I have a Stanley Bostitch Sb 2IN1 2 In 1 Narrow Crown Stapler/18 Gauge Brad Nailer gun. How do I adjust the depth the nailer shoots the brad nails into base boards? I see that their is a dial on the back...
look on the front of the tool.there is a dial right where the plastic meets the yellow housing.also look closely and you should see a diagram on the plastic telling you whitch way to go.
Jun 12, 2010 | Stanley Bostitch Sb 2IN1 2 In 1 Narrow...
MY SEARS 9.6 VOLT NARROW CROWN STAPLER WILL FIRE ONE TIME OR TWO, THEN QUIT. IF I PULL THE BATTERY BACK FROM ITS LOCKED POSITION ABOUT 1/4" IT WILL FIRE EVERY TIME. GOT ANY IDEAS? I LIKE THIS STAPLER...
The terminals on the battery or on the stapler must be damaged (bent or corroded). It's probably the stapler if the battery charges fine. Does it do the same thing with another battery, or just one? Assuming it's the stapler, and you don't want to mess around with the terminals you could tape a spacer on the stapler to keep the battery 1/4 inch out. You would probably have to tape the battery in place though. If the problem is corroded terminals, I have found that a little wire brush attachment in a Dremel works great. Not a brush like a disc, but a brush that looks like the kind used for paint stenciling.
May 21, 2010 | Arrow & Professional Cordless Staple Gun
Bostich narrow crown air stapler won't work
before going about rebuild get can of carburetor spray cleaner and stray the ram area lots of times the glue that holds the staples/or nails builds up and stops up the ram rod spray the rod a few times than with air hooked up dry fire if it frees up lube rod area
Jan 17, 2010 | Stanley Bostitch Sb 2IN1 2 In 1 Narrow...
Senco SNS41 16Ga Stapler 1" 2" Logo
282 people viewed this question
Top Senco Air Tools & Compressors Experts
John Trevino
yoopertech
Mike
Are you a Senco Air Tool and Compressor Expert? Answer questions, earn points and help others
