Question about Bush 5693D 24" TV
Bush tv picture
All the colours on my tv picture have gone wrong, it looks like someone has had a big magnet against the screen, although I know that that has not happened, please could you let me know weather this problem can be fixed, and if so would I be able to do it myself
  • kevsaxo Nov 28, 2008
    i think the tubing has gone as my screen is in pink green and red is this something anyone can fix
    Novelist:
    Champion:
  • 236 Answers
Do you have any large stereo speakers near your tv? They have large magnet in them. It sounds like your screen is magnetized Your set has an automatic de-magnetizing circuit built into it. This circuit could have failed. If you have large speakers near your tv, they need to be moved,but you did say that you're sure that no magnetic field was near your set. Stargazer
Posted on Jan 13, 2007
Bush tv no colour, red has gone
T"Con board fault. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Oct 14, 2014 | Bush Industries IDLCD26TV16HD LCD TV
Picture is pink in places and dark scenes the picture is mostly green
Oh dear.
It sounds like you have magnetised the screen by placing something magnetic too close.
Your only hope is to unplug the TV, and remove ANYTHING magnetic away from it, such as speakers etc. Give it a few hours then retry.
If this has been going on some time, it will already be too late.
The other possibility is the tube could be going!
Jan 10, 2018 | Panasonic TX-36PF10 TV
I have a bush colour tv and there is a blue,green,red colour wash right across the picture so people''s faces look half blue,green red....sort of as if there is a rainbow across the screen.. i do not have...
It sounds like your TV may need degausing.
Is your TV situated near to any loudspeakers or other devices with large magnets inside them? Or has anyone been near your TV screen with a magnet???
You need to try to get the screen demagnetised (degaussed). Many TV engineers have a degausing coil that could do this. It only takes around 20 seconds at most.
Some TV's like Mitsubishi have a DG button on the remote, that does this function without the need to call out an engineer! It only needs one press of the button every few years!
Nov 17, 2009 | Televison & Video
Sony wega 28 inch colours wrong, circle on screen
It sounds that there is some magnet near by TV that is affecting picture tube. Please remove any extra speaker or any thing that has strong magnet inside, unplug TV for 20-30 minutes, replug back in, turn it ON, hope that will solve your TV problem.
Thanks.
Nov 16, 2009 | Sony WEGA KV-28HX15 28" TV
I have samsung 21 green screen
Either something wrong with the picture tube or something with scart input if you use one. / / David
Jul 29, 2009 | Samsung TXN3271HF 32" TV
Philips magnavox big screen tv that has sound but no picture
the picture driver has gone bad, look on ebay for one,make sure it looks just like the one you have, or it could be the verisitor has gone bad it's a kool fix
Nov 21, 2017 | Philips Televison & Video
Bush tv has a circle on screen like looking thru a telescope
HELLO
Funnily enough I have been given a 21 inch standard Bush set with the same problem!
It's a DEGAUSSING fault. This means the deguss circuit in the TV is not operating as it should - probably a faulty positor. When you switch the TV on (NOT FROM STANDBY) the circuit that removes magnetism from the screen does not work correctly.
Switch it off, unplug the set from the mains for 30 minutes or so and try it again. If there is no change, contact a TV repair centre.
Make sure there are no hifi loudspeakers next to the TV or a radiator as this can have an effect too.
ALL THE BEST! (:-)
Jan 06, 2009 | Bush 5693D 24" TV
Bush TV, model number RF6685VPL/A - Colours are wrong!
It seems that it is a degaussing problem. TV sets have a degaussing coil that when the TV is turned on , it automatically demagnetizes the screen. Never place any speakers or anything magnetic near or on top of your set. if you see swirls of color and like you say, wierd colors, it is that the screen is magnetized. Turn it on and off with the switch. Not the remote control. The degaussing coil only works by manually turn the switch on and off.
Nov 19, 2008 | Televison & Video
Strange screen colours
Your degaussing circuit is not fully 'demagnetizing' the picture tube.
You can manually degauss it using a strong magnet, but it's tricky.
With a tool made for demagnetizing you simply hold it close to the center of the picture tube and using a circular motion slowly spiral outward to the outer edge of the tube, pulling the magent further away from the tube at the same time. The same can be done using a strong magnet although the results may not be perfect. You can experiment with a magnet using wiping motions as you bring the magnet closer to and further away from the tube.
Mar 05, 2008 | Beko 324250WN 28" TV
LG PLASMA TV WITH COLOURED LINES OVER SCREEN
If the Video (Picture/Pix) is gone but you can hear the Audio (sound), then it could mean the YSUS PCB Assembly is gone/kaput/finish. Can replace the PCB, not repair the PCB due to timing circuitry involve. Cost maybe roughly $500 depending where you located. The PCB is located on the left hand side of your TV when you are facing the back (Back open). Might find 3-4 brown flex membrane connecting to the plasma panel. The PCB has a silver or black aluminum heatsink (big) on it.
Good Luck.
Dec 22, 2007 | LG 42PX5D 42 in. Plasma HDTV
Bush 5693D 24" TV Logo
170 people viewed this question
Top Bush Televison & Video Experts
Joseph Hoffmann
Raj Patel
Are you a Bush Televison and Video Expert? Answer questions, earn points and help others
