Question about Mitel Superset 4025 Corded Phone (mitsup4025)
Remove a non-prime line
A little hard to explain. We have only one line going into the 4025. However, the unit "thinks" there are two lines. So we need to press one of the bottom right two keys to "select" an outgoing line, even though it is the same line. How do we tell the unit there is only one number coming into it so that when we pick up the handset we don't have to select a line? Thanks.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 112 Answers
Need to log into phone system and change class of service option. What mitel phone system do you have
Posted on Jan 11, 2009
I have a BG55 blower when I try to prime it no gas come in bubble. I have made sure there nothing in gas line,and it skeet when I put a pin in the little hole, but no gas when u try to prime.
Apart from the bubble there is at least one non-return valve that could be stuck or not working because it is dry.
Could be removing the bubble and wetting everything thoroughly with fuel and quickly refitting it could kick-start it and make it work.
Sep 05, 2016 | Stihl Bg 55
Trimmer won't prime to start
Look inside the tank. Some units have a stone inside that blocks the fuel line when it is tipped a certain way. Might be what's happening here.
Aug 13, 2016 | Garden
Fuel line clogged
Walt, best thing to do is to flush the tank... having an air compressor is a big plus, first remove the tank, drain fuel from it...remove the fuel line.. now put a little fuel In it and see if it's actually coming out of the bottom barb of the tank... unless you have a bit chunk of debri it's hard to think the fuel line itself is clogged... do you have an in line filter along the fuel line.. take it step by step, start off with the tank and go from there ...
Oct 15, 2015 | Cub Cadet Garden
My prime bulb looses pressure and first start is hard. I have to remove fuel line from filter and cover with thumb prime re install then first start takes time.
Does the engine run fine after it starts? Most common problem with primer bulb losing prime is an air leak in the fuel line or primer bulb. Air leaks don't always leak fuel. If there is an air leak between the primer bulb and gas tank there is no pressure, only vacuum. If it is not a major leak it might not leak without pressure but it will allow air to enter the fuel line. If it is a very minor air leak it could allow air to replace the liquid in the fuel line over time, but so little air once it is primer again that the fuel pump can over come it with volume of fuel.
Primer bulbs do not stay firm, as they are when initially pumped up, after the engine is running. There are check valves in the primer bulb that hold pressure in the primer bulb and throughout the fuel line to the engine. Once the engine starts the fuel pump creates vacuum drawing fuel into the engine diminishing this pressure and releasing the check valves. At this point the primer bulb is just another segment of fuel hose allowing fuel to pass through it as the fuel pump demands. The primer bulb functions much better when the outlet side is higher than the inlet side. This position makes it easier for the check valves in the primer bulb to seat and release as needed. If the primer bulb is functioning properly and is positioned with the outlet side higher than the inlet it should not be necessary to cover the end of the fuel hose with your thumb to get it to prime.
If the engine is hard to start after being fully primed there could be a problem with the fuel system on the engine. Some engines are hard to prime once air has entered the system, especially fuel injected models.
Dec 19, 2014 | Boating
How do you turn the speaker phone back on for Mitel 4025?
While on a call and using the handset, place the call on hold, then hang up the handset, then press the line button of the active line. The call will now appear in handsfree mode on the speaker. To take the call off the speaker and go back on handset mode, simply lift the handset. Hope this helps.
Apr 24, 2014 | Mitel Superset 4025 Corded Phone...
Troubleshooting the superset 4025
If *ALL* the buttons are lit up solid then try rebooting the phone (unplug the phone line & plug it back in). However, if only one or 2 lines are lit up solid then that is an indication that those are companion key appearances of other extensions that are presently set to "call Forward Always" mode. You will need to visit the physical home location(s) of those lines to un-forward them. Hope this helps.
Apr 18, 2014 | Mitel Superset 4025 Corded Phone...
2007 Freightliner business class m2 mercedes diesel ran out of fuel and now we can get it to start. It will crank but it seems as though the pump won't pick it up. we have tried pressurizing the tank and...
Hello. If you remove the fuel filters and fill them with fuel, then hold the accelerator pedal to the floor while cranking the engine it should start. If that does not work, spray a little starting fluid (ether) into the air intake while cranking, just use the ether sparingly. This should get you going again, good luck.
Feb 27, 2010 | 2007 Dodge Sprinter
Primer bulb won't prime
it sounds like the filter on the fule line is cloged try to remove the filter and then try to prime the trimmer. it it does you need to replace the filter. just about any filter that will fit will do.
Jun 05, 2009 | Troy Bilt Tb70ss Gas Trimmer
Need to replace the clutch
when you buy the new clutch assembly , ask - make sure the little tool is in the box to release the hydraulic line at the slave cylinder , you don't wont to loose prime in the hydraulic system , that would be time consuming ,otherwise its a normal job, if you have never released a hydraulic line from the ford slave cylinder before , it is tricky , ask the parts man to show you a slave unit and explain how it releases . you will be thankful in the end .
Jan 01, 2009 | 1993 Ford Explorer Limited
How can I start the soap syphon feature on the Karcher Model 210 - 1200 PSI unit ? Does the line need to be primed ?
If there is a check valve in the little line that you put into your soap tank, it doesn't need primed. I have very large 5000 psi units and have enough suction without one. If you can't get it going, you can always remove the hose end near the pressure washer end and fill it by immersing the tubing in the soap, but that shouldn't be necessary. Sometimes the little fitting with the check valve in the bottom get plugged up as well, so that might be your problem. Hope this helps you, Rick
Apr 03, 2008 | Karcher 2500 PSI Pressure Washer
Mitel Superset 4025 Corded Phone (mitsup4025) Logo
100 people viewed this question
Top Mitel Lands Phones Experts
Dustin
Dustin
David Payne
David Payne
Marvin
Marvin
Are you a Mitel Lands Phone Expert? Answer questions, earn points and help others
