Question about Alpine TDM-7545
Removing TDM-7545 unit from dash
My Alpine TDM-7545 is dead(thanks to coffee spillage) How do I remove the entire unit from dash? When i remove the face-plate I can't seem to release the unit from the dash. thanks bj
  • zpreciso Jan 17, 2009
    cant get the unit out of the dash
I cant seem to remove the unit from the dash ? thanks zac
Posted on Jan 17, 2009
Oil pressure is at 80 psi at all times
Simple test: remove the wire from the sender unit, if the needle falls then the sender unit is dead - replace it; if the needle stays the same then the indicator in the dash is dead and it gets iffy - if you have some experience you could replace just it, otherwise you will have to replace the entire dash.
Jul 01, 2010 | 2003 Isuzu Ascender
I purchased a vehicle with an Alpine TDM-7546 in dash radio. Where can I find a user manual describing how to use it's functions?
Hello! you can purchase a user manual for a Alpine TDM-7546, for $5 at the following link:
www.pacparts.com/library/default.cfm?mode=auto&mfg=Alpine
Guru...........saailer
Feb 02, 2010 | Alpine TDM-7546
Trying to set the radio stations on Alpine stereo
The radio either does not have the yellow power wire connected(constant 12v) or the wire is connected to a switched source and when the key is turned off the radio has no backup power. You will need to pull the radio out and verify the yellow wire is not connected to switched voltage and connected to constant power. It is also possible that they have the red and yellow wires mixed up. Remember yellow constant power and red is switched power(with ignition key). And also disconnect your negative battery cable when working on the electrical system of your vehicle...you may short something out and damage your vehicle's electrical system or head unit.
Sep 19, 2009 | Alpine TDM-7543
Removing alpine receive from dash
Unless you have the 'keys' that came with the unit, you'll need an Alpine dealer to a) get keys so you can remove yourself (wiring just un-plugs) or b) installer. CStereo mfgrs use different snap-lock mechanisms and sometime different keys for different models.
Apr 21, 2009 | Car Audio & Video
Removing my alpine 7510T
The trim ring around the radio must be removed, then slide alpine head unit removal heys in each side.
Dec 26, 2008 | Alpine TDM-7561 Cassette Player
Remove cdm-7854
I was able to get the radio out just by pulling it out - there was no locks on my unit- thanks for your help.
Jun 21, 2008 | Alpine CDM-7854
Leaks grounds at removable filter.
You can get entire brew units on E-Bay for 25-50$.
Nov 27, 2007 | Solis Master 5000 Espresso Machine
How to adjust the clock?
According to the manual you hold the clock button in for a least 3 seconds. The time indication will blink for about 5 seconds.
Press the CT button while time indication is blinking to set seconds to "0".
Press H button to adjust hours and the M button to adjust minutes.
The time indication will stop blinking, 5 seconds after adjusting the minutes.
Oct 22, 2007 | Alpine TDM-7545
Wiring on tape deck Alpine tdm-7543
hi there is a manual in the model page click on it page 2 there is a description how to connect the unit good luck
Mar 20, 2006 | Alpine TDM-7543
Car Audio & Video Logo
338 people viewed this question
Top Alpine Car Audio & Video Experts
xxxxxx xxx
hoyzee1
Tygh Duval
Tygh Duval
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
