Question about Konica Minolta bizhub 250 All-In-One Laser Printer
Water spilt on minolta ep3000
Vandals spilt water on our copier. The machine warms up, and the touch panel comes on, even indicates when panels are opened, but the screen and the buttons on the front won't function, none of them.
Any ideas, any fuses, or something that we could look for. We would really hate to toss, in many ways, a good copier. Please help! Thanks.
    Sergeant:
  • 276 Answers
The printer needs reparing the only solutiuon.if u have idea of reparing the board u can open the printer and try it.there r fuses in the printer but that does not links to this problem.
thanks,
Posted on Nov 26, 2008
  • Konica Minolta Master
  • 1,879 Answers
You don't have to waste the whole unit, just replace the control panel board. Call up for service.
    Sergeant:
  • 291 Answers
Its the circuit short in the machine and needs reparing for sure.
  • 19,396 Answers
Unplug the machine immediately. The machine must be taken apart by a technician, dried up, and then tested if there is a faulty part.
  • Ginko
    Ginko Nov 26, 2008
    The buttons do not work because there is still liquid inside, the machine , including the button pad assembly must be taken apart and dried up with a dryer.
    If you keep powering the machine without drying the inside, you risk to cause short circuits, and therefore further damage.
    Call the phone number listed on the owner manual and ask a technician to do the job.
    If you want to do it yourself you can use an hairdryer set to cold air, but bear in mind that there is a good chance of damaging the machine.
In my Minolta EP3000, coming white lines while copying
clean the lens and also remove the drum cartridge and clean the drum error and developer section.
Apr 05, 2016 | Konica Minolta Office Equipment & Supplies
Dark copies are coming even I placed a plain white paper as the original in MINOLTA EP3000 Photocopier.
When was the last time the drum and developer where replaced and drum cartridge was clean along with transfer and sep assy??
Mar 13, 2016 | Minolta Office Equipment & Supplies
On display showing problem code 500
Sir,
To clear this code requires you to gain access to the System reset. Open front door locate a small panel with one screw to release it in side will find two small black buttons find service and let machine reset if the code persists then your fusers is gone, the EP3000 is a legacy equipment may find a problem in locating spare parts if the thermistor, thermosat or fuser lamp is shot. Ensure machine is on when you attempt above.
Sep 06, 2012 | Minolta Office Equipment & Supplies
KONICA MINOLTA C253 COLOUR MACHINE ERROR CODE C-D403 touch screen not working printout not coming our service engineer could not find the error
The c-d403 code indicates a checksum error. Try turning the copier off and on via the Main power switch either behind the copier or inside the front door of the copier. Checksum error along with no operation panel means something could be fried on the main board.
Feb 17, 2011 | Konica Minolta bizhub C250 All-In-One...
Minolta cs pro EP3000 copier. The copy is too dark even on lightest.thanks
Clean the optical parts:mirrors,lens and the charge and transfer/sepaRATOR CORONAS.
May 13, 2010 | Office Equipment & Supplies
EP3000 error code c0500 will not clear
Sir,
Feb 02, 2010 | Konica Minolta DiALTA Di200 Copier
Minolta ep3000 service m1 ? and how to reset ? can you help
M1= main motor
1. Does the transport motor (M1) operate during power up?
NO, Ensure the connection of the connector (PJ21A) is secure.
2. Replace the transport motor.
YES, Check if there is excessive load on any of the rollers,gears,etc.
3. Replace PWB-A.
Jan 22, 2009 | Office Equipment & Supplies
Konica Minolta bizhub 250 All-In-One Laser Printer Logo
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
