Question about Samsung HCL652W 65" Rear Projection Television
The TV turns on and off after a few seconds and repeats itself.
I have a Samsumg HCN653W rear projection TV that does not turn on. When powering up, it turns on for a few seconds then it turns itself off. It keeps repeating the same sequence until I manually turn it off. I hear a little bit of sound just before it turns itself off. Do you know what the problem could be? Do you have a service manual for this TV?
  • Samsung Master
  • 8,617 Answers
There could be quite a few things that would cause the set not to power up. I dont have the service manual, however you can get a copy of the service manual at the following link for your model. As thats the only proper way to be able to check for the proper voltages to determine whats wrong with the set.
Heres the link.
http://servicemanuals.vstore.ca/
Posted on Nov 26, 2008
65" mitsubishi rear projection tv won't turn
IF model number posted is correct and green power light comes on for a few seconds and then goes off:
On front of set press and hold both the Menu and Input (device) buttons at the same time for at least five seconds and release both buttons.
Power light will then blink a two digit error code like 2 blinks, 2 blinks, a pause and repeat it several times.
Let me know what error code is found and I will tell you what it means.
SD TECH
Oct 09, 2011 | Mitsubishi WS-65611 65" Rear Projection...
Samsung HCN653W DLP TV will not come on.
how sthe bulb on it is it new been chaged can u unplug unit for wile plug back in how many flasshes can u count usally flasshes meen a serv code
Jan 24, 2008 | Samsung HCN653W 65" Rear Projection...
Tv automatically powers off by itself within seconds.
This model has a self check: with the set plugged in turn it on--green power light comes on and a few seconds later goes off.
On front of set press and hold BOTH the menu and input buttons at the same time for at least 5 seconds and release both buttons.
Power light will blink a 2 digit error code like 2 blinks, 2 blinks, a pause and repeat it several times.
Let me know what error code you find and I will tell you what it means.
SD TECH
Apr 11, 2011 | Mitsubishi WS-65809 65" Rear Projection...
My tv will turn on and then after a while it turns itself off and then back on in a few seconds and this repeats all night
there is most likely a bad connection on the power board. i really suggest not letting it do that all night unplug the tv it can do alot of damage to the tv if it cycles like that for long periods of time.
Jan 05, 2011 | RCA Scenium D40W20 40" Rear Projection...
Hi.
Either the stk convergence modules or the vertical ic have failed.
replace the 3 parts and it should fire up again.
Nov 21, 2008 | Samsung HCN653W 65" Rear Projection...
Samsung rear projection tv
I think it could be a faulty diode on the power supply board. If you can check this for yourself otherwise call out a competant technician. Good luck.
Sep 30, 2008 | Samsung HC-P4752W 47" Rear Projection...
Tv turns off
Its the lamp that needs replacing. It will run for a couple of seconds and then it would dim or turn off.
May 27, 2008 | Sony Grand WEGA KDF-60XS955 60" Rear...
TV turns itself off after a few seconds, no picture at all
I had a similar problem with my Phillips 42 in. LCD HD TV.
Here's the problem. The Power Supply Board. I opened my TV up(warranty was up of course) and found several bad capacitors. Phillips and several other companies were sold capacitors that although were highly rated failed within 5 years because of a lack of preservatives. All sorts of electronic equipment is now being effected due to these defective capacitors.
Solutions?
1. Take it in and have it fixed
2. Open it up, check the board for faulty capacitors(bulged or leaking) Buy a new Power supply board and install it.
3. Remove PSB, remove faulty capacitors and replace with compatible new ones.
Hope this helps
Mar 28, 2008 | Samsung HLP4663W 46" Rear Projection HDTV
RCA F31317 31" TV Turning self off and on then completely off
the horzantle power supply is bad probably missing the B+ voltage this is a repair for a tech high voltage
Dec 21, 2007 | Hitachi 43UWX10B 43" Rear Projection...
Samsung HCL652W 65" Rear Projection Television Logo
123 people viewed this question
cce772000
Level 1 Expert
