Question about Sony KP-57WV600 57" Rear Projection HDTV-Ready Television
Blue screen on my sony kp 57wv600
My big screen has started to blue, it would work for awhile and has gotten to the point where it's blue all the time !!
I don't have alot of money right now and would like to fix this problem if possible ??
I'm very capeable to work on it I just don't know where to start ??
any help would be greatly appreciated !
    Sergeant:
  • 291 Answers
Convergence ic needs to be replaced to make it clear.
Posted on Nov 26, 2008
    Scholar:
  • 174 Answers
>>Front shot of the television. Their are two screw holes on the front of the unit near the edge of each side right next to the speaker grille.
>>Close up shot of the screw hold. It is covered by a plastic cover that has two tabs holding it in. Carefully pry them out with your flat head screwdriver. Do not apply too much pressure or you can break the tabs off. Once the covers are removed, unscrew the two screws with a Philips screwdriver.
>>To remove the cover, pull from the bottom of the front case and rotate towards you. Once you rotate it out, the top will disconnect and come loose. Do not pull it off, as there are cords attached. (see picture) Loosen the cables attached with the twist ties and set the front cover to the left side.
With the speaker grille and cover removed, you now need to remove the wood panel to expose the inner electronics on your Sony HD TV. To do this, remove the four Philips head screws from the panel. Then, pulling from the right, rotate the panel off and the electronics will be exposed.
>>This is a picture of the inner electronics of your Sony Rear-Projection High Definition television. The little black box towards the front of the unit is where we will concentrate our time as it is the control for the voltage & convergence adjustment.
>>When focused in on the controls, you want to concentrate on the bottom row for the voltage / ray gun projection adjustment. The colors are labeled below and from left to right are blue, green, and red. Choose the one that needs to be adjusted and turn ever so slightly with your Philips screwdriver to remove the lines. In my case, the red just needed to be turned 1/8 of a rotation to be back in adjustment. Do not turn to quickly or abruptly or you could possibly damage your TV by varying the voltage too quickly.
  • debroy
    debroy Nov 26, 2008
  • Sony Master
  • 4,806 Answers
The red and green lamps at the back of the unit have blown and need to be repaced
kind regards
  • 1 more comment
  • Lee Hodgson
    Lee Hodgson Nov 26, 2008
    the lamps are just like normal screw type light bulbs, you will find it quite easy to replace them
    regards
  • Lee Hodgson
    unplugging the TV from the mains is not going to help, rear projection tv's display a picture using the 3 primary colours, red, green and blue, if the only colour on the screen is blue then the lamps have blown.
    As with standard lights they only have a short life cycle and blow when the element burns out
    best regards
  • Lee Hodgson
    take the back off the TV and look at the bulbs while the TV is on to see if this is the case, do not touch anything in the TV while the TV is on
    Sergeant:
  • 276 Answers
First unplug the device for sometime from the main power scource for sometime then replug.
Sony Projection TV problem
sony rear projection KP series are know for having bad utbes after while..ihad seen the blue tube goes on most.
Jan 22, 2010 | Sony KP-57WV600 57" Rear Projection...
Sony goes blue
you need a new Blue CRT you can get them at the following link.
http://servicemanuals.vstore.ca/
Jan 15, 2009 | Sony KP-57WV600 57" Rear Projection...
I have a sony KP-57WV600 Big Screen Rear projection television. The problem is this: When I first turn the tv on the picture is fine, than after it warms up- the screen turns red. What would the problem...
Let me know when TV warms up does it go to standby?
If yes, standby light would be blinking, let me know how many times it blinks?
And if TV does not go to standby mode, does picture remain with red tone?
Dec 06, 2008 | Sony KP-57WV600 57" Rear Projection...
Cleaning the screen cover on my sony big screen
To clean its front screen, you should not open front cover as its complicated procedure. just take off its back cover as its shown in picture and use air-blower to clean dust. Then use soft cotton cloth to clean its screen from internal and 3 bulbs / lenses (CRTs) and job is done.
Need further help, let me know.
Bye.
Sep 13, 2008 | Sony KP-57WV600 57" Rear Projection...
Sony KP-57wv600 big screen
you will need to replace the Green CRT your model uses the sony # 873365201 CRT. The other site I work for just got a shipment of Sony and RCA CRTs(Tubes) in on friday. So you can get one at the following link these are brand new Tubes and they provide free shipping and free on line tech support with instant messageing in case you need help installing it. Heres the link.
Jun 22, 2008 | Sony KP-51HW40 51" Rear Projection...
Sony KP 57WV600
how many times does it blink?
Mar 26, 2008 | Sony KP-57WV600 57" Rear Projection...
Blue to Black screen on Sony KP-57WV600
i too have 57wv600 and your problem is same as mine VOLTAGE withen tube is off ...this is common problem sony knows full well and will not tell us this voltage can be adjusted with a philips screwdriver i had blue lines then solid blue then shut off...7 blinking lights ...went to this site followed directions (too simple)and now i have perfect picture.serviceman said i needed new tube.b.s. ...so never change your tube it is not the prob!!!!!!!....go to www.somelifeblog.com/2007/06/sony-projection-tv-red-line-repair.html read post(comment) near bottom of page by paul t dated 12/26/2007 and instructions on how to remove our front panel is fully explained ...a screwdriver will fix your problem I guarantee it.....
Dec 28, 2007 | Sony KP-57WV600 57" Rear Projection...
Sony KP-57WV600 57" Rear Projection HDTV-Ready Television Logo
16 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
