Question about Mitsubishi WS-65613 65" Rear Projection HDTV
WS-65613 Mitzubishi Rolling screen horizontal / no inputs work
I recently aquired this tv free off craigslist. Tv is in outstanding shape. Only problem is the tv after turning it on goes into a rolling horizontal to the left displaying " please insert card into slot ", when I access the tv menus there is no rolling anymore, picture display is very still and clear, however it doesnt matter which input I select (ant A , ant B, Input 1 2 3, Monlink, DVI ) it will not display any of the video. Any Thoughts on how to fix this?
  • dyeaton66 Jan 07, 2009
    We have the same problem with this model. Screen started with a weird shaking thing then would stop and then went darker and then horizontal - now nothing. Only shows blue screen with menu option - tried getting other devices to work (i.e. dvd, vcr players - nothing!) HELP!!
5 Suggested Answers
techman
  • 3130 Answers
SOURCE: rolling screen
Ahh the old rolling picture problem. If this set has a Picture in picture feature, your problem is on the PIP module itself. There is a kit of surface mounted capacitors that need to be replaced If you have some soldering skills you should be able to do this your self, but if you do not, I advise you to get someomne who does as most of these PIP modules are not available any longer. The kit can be purchased from http://www.mcminone.com/search.asp?keyword=Mitsubishi+PIP+kit&btnSubmit.x=6&btnSubmit.y=7 Good Luck
Posted on Mar 28, 2007
MrBob84
  • 90 Answers
SOURCE: Screen blacks out
Check your set for coolant leakage. It is very prevalent on Mits HDreadys.
If your 4 layer Signal board - beneath the blue gun - has coolant on it, you'll have problems finding a replacement. If it's the boards under the other 2 guns, they can always be repaired as they are single layer.
A drip shed should be installed to keep the coolant off your boards.
Mr Bob
Posted on Feb 03, 2008
Slinteriors
  • 8617 Answers
SOURCE: TV screen goes blank but power stays on
Sounds like the CRTs are going into protective blanking due to the vertical output ic needing to be resolderd. Try resoldering the vertical IC that may possibly fix the issue.
Posted on Jun 15, 2008
  • 927 Answers
SOURCE: hello,65613 mits
Good Day, boofis68;
Sound like you may have voltage concern,9 volt source. Check for 9-volts DC to the Terminal PCB at connector JA pins 57 and 58 if missing, check IC9C25 (9-volt regulator) part # 270P677030 on the Signal PCB and replace the two caps. Good Luck, big IRISH.
Posted on Aug 31, 2008
Why can't my Mitsubishi Medallion go to 1080 with my Direct TV HD service?
if it is a ws-65613 you would have to be connected to the DTV component input on the back of the set as this is the only HD input for this model.
If the set will not go to that input (skips it by) let me know as there is a way to restore missing inputs--if you hook HD in any other way it will not work on this model; let me know if you need help;
I am here to help and know these sets well.
SD TECH
Mar 01, 2010 | Mitsubishi WS-65613 65" Rear Projection...
Rolling horizontal black bar 1" tall on the tv screen
this is a problem with heating of some components of the TV inside it.
i would suggest you to look inside the unit and check for components with high heat
Oct 01, 2008 | Mitsubishi WS-48513 48" Rear Projection...
Mitsubishi WS-A55, HD1080 Series TV picture scrolls horizontally
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary
Mar 05, 2017 | Televison & Video
Mitsubishi tv ws65613 and remote wont work
You could try a replacement remote from www.Remotes.com
You will need an original or the replacement to access some of the features of your television
I hope that this helps.
asnowman
Oct 12, 2009 | Mitsubishi WS-65613 65" Rear Projection...
Mitsubishi WS-65613 tv green power light keeps blinking tv will not turn on
Unplug the unit for 5 minutes then plug it again. Turn it on. If it does not power up, press the SYSTEM RESET button on the front panel with a pointed object such as the point of a pencil or end tip of a paper clip. The green LED light will flash quickly for about a minute then stops. You may turn on the TV then. The changes you made most recently, before using
SYSTEM RESET, may be lost. Changes you made previously, however, are not lost.
Sep 11, 2009 | Mitsubishi WS-65613 65" Rear Projection...
Mitsubishi ws65613 no picture or sound, blue screen only
Good day, Bgchzy;
This model is known for the tubes leaking fluid, glucose, on the PCB. Check the front of the chassis for said fluid, it may be only a drop, so look closely.
To fix, after TV has no power, try cleaning the board with cleaner and brush, let dry. I suspect this because of multi unrelated problems.
Jun 13, 2008 | Mitsubishi WS-65613 65" Rear Projection...
Ws 65613
1-800-552-7278 Mits parts = still gonna cost ya.......T.
Oct 24, 2007 | Mitsubishi WS-65613 65" Rear Projection...
Ws 55513
The constant blinking green light means that the TV is not booting up. This is a common problem on this set.You need to remove the shield from the DM board (standing upright on the left where the DTV RF connector is)and inside you will see the four leaky capacitors (1000 MFD 16 VOLT)replace them,plug the TV in and wait 70 seconds for the blinking light to stop,then turn on the TV.The hard part will be removing the board from the TV(lots of screws and connectors,takes time)
Sep 22, 2007 | Mitsubishi WS-65613 65" Rear Projection...
Mitsubishi WS-65613 65" Rear Projection HDTV Logo
108 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
