Question about Westinghouse L1975NW Monitor
Low volume on monitor model L195NW
The volume controls is turned up on the computer but I have no volume on the monitor. Is there a control volume on the monitor.
Thx
    Scholar:
  • 149 Answers
The user guide is here
http://www.westinghousedigital.com/manuals.aspx
yours is listed under LCD monitors
there is a way to turn up the volume via the onscreen display page 13
bear i mind though that the speakers inside the monitor are 2watts only so won´t be really loud anyway
Posted on Nov 26, 2008
How to increase the volume using the on screen menu?
Be sure the audio output from the sound card in the computer is connected to the monitor, else you cannot control the audio volument with the monitor control.
Jun 24, 2014 | iiyama AS4316UTC 17" LCD Monitor
Max volume to low
Check the settings of the monitor for audio volume. Also check the individual volume control setting for the applications and system sounds. Or call ViewSonic technical support for assistance.
Jun 15, 2014 | ViewSonic Computers & Internet
My Korg c15s has a lot of grating staticky noises when played ....I'm told it cannot be repaired as Korg no longer makes parts for this model?
I have a Korg C-15s and also experiencing loud crackling sounds when I turn it on. The problems seems to be either the sliding volume control or the amplifier itself. Honestly though, I believe the issue is the volume control. I opened my piano to get a closer look and attempted to clean the contacts on the volume. Unfortunately after cleaning the contacts, the crackling sounds became somewhat worse. After I turn the piano on, the volume control is generally rendered useless......volume set to low volume and the noise is quite loud and other times the volume control is set high and get very low volume crackling noise. No real consistency. The noise does diminish after a few minutes but so does the piano sounds to an inaudible level. There were a couple of instances where I turned it on and surprising enough, no no noise and perfect sound. For these reasons I believe the issue is within the volume control and not so much the amplifier. I have an electronics background and noticed that the volume control is very unique in design and is not something that can be substituted with another volume control from other sources.
My recommendation is to check the sound quality of the audio from the RCA L/R audio outs on rear of the piano by connecting to a stereo receiver. If it sounds fine you're in luck. If the crackling sound does not diminish after a few minutes like mine does, I would suggest disconnecting the internal speakers and using the audio out only. You can connect a pair of studio monitors or high quality computer speakers, preferably with a small subwoofer to deliver the full audio range and deeper tone of a real piano. I'm currently using a basic pair of Logitech computer speakers and is quite acceptable until I can afford a high quality set of monitors or relocate my piano closer to my high quality Yamaha receiver.
I hope this info helps a bit.
Aug 18, 2010 | Yamaha Full-Size Keyboard
How do i turn the volume up
Did you turn up the both (at the PC Audio control panel and at the Monitor control panel) volumes up?
Try using MP3 player or any audio sound sources feeding the monitor audio input to see what happen also.
Apr 09, 2010 | Westinghouse LCM-19v1 Monitor
My volume is not working correctly. I have it turned up to 100 - the highest and I can barely hear it.
Monitor volume is affected by TWO volume controls (or even three...)
1: Volume on the monitor can be set to 80%
2: Main Volume on the COMPUTER can be set to your liking.
3: Wave volume on the computer mixer settings should be set for 80% (See Sound on your control panel or right click your volume control near the clock)
If all these are right and the volume is still low, check that the audio is not set for surround 5 or 7 channel and the monitor audio connector is plugged into the REAR green connection on the computer.
Still problems, the audio driver in the monitor is shot.
Dec 05, 2009 | Proview PL913S 19" Flat Panel LCD Monitor
HOW DO I TURN DOWN THE VOLUME? I DOTN SEE THE VOLUME BUTTON
This monitor has no volume. The volume is controlled by the computer connected to the monitor, and not controlling the monitor itself.
To regulate volume on computer, click on the small audio icon near to the clock, or locate the audio settings icon in control panel.
Jun 04, 2009 | HP Pavilion F1523 15" LCD Monitor
I am unable to find the volume control
can be controled by windows master volume in the windows control panel!
Feb 26, 2009 | Acer AL1711 17" LCD Monitor
How u turn up the volume on a ViewSonic monitor w?Built-in spkrs?
when i push the volume up or down button on the side of the monitor, a key icon pops up on the bottom left corner not letting me control my volume
Dec 23, 2008 | Computers & Internet
Acer speaker?
There are two possible problems here. (1). The volume control on your monitor is turned down. With the button on the front of your monitor, find the menu/option button, and look for volume control (2) The volume coming out of your computer is low. Double click on the speaker at the bottom right of your screen, located on the start bar. Use the sliders to change the volume. This should fixya up.
Good Luck!
Dec 12, 2008 | Computers & Internet
How can i connect compaq presario 1425 to a desk top pc so that i can use it front volume nob of the monitor to adjust the sound system from the desk top to listen to the sound
hi dear
Monitor Volume Control In order for the volume control feature of the Presario xx25 monitors to work correctly with the computer, it is necessary for the monitor to be powered on at least 8-10 seconds before the CPU. Try removing the computer and monitor from any surge protector or power strip that they may be attached to, and turning on the monitor first, then the computer itself.
3rd Party Video Cards The volume control on the 1425, 1525, 1725 and FX monitors is a digital control. It sends its commands via two conductors in the monitor's VGA data cable. The corresponding points on the VGA connector on your 4700 series Presario accept this signal. A 3rd party video card would not have this functionality built in. Most times, it just means the remote volume knob ceases to function. You can still adjust levels with the software. In some cases, however, a 3rd party card can cause the volume to either drop or go full on with no way to control it. One possible solution is to turn the computer on and let it fully boot up BEFORE you turn on the monitor. This way the monitor's remote volume function will not be initialized and you may be able to use the software volume controls.
You can if you want, go to any Computer parts store and purchase a VGA extension cable. You will need to remove pins 4 and 11. This cable will be installed on the monitor cable and then to the card itself. The rest of the manufacturers cabling will remain the same. You will lose the use of the volume control knob on the monitor. If this is not acceptable, then you will need to remove the card.
oke
cropp
Mar 20, 2008 | Computers & Internet
Westinghouse L1975NW Monitor Logo
308 people viewed this question
Top Westinghouse Computers & Internet Experts
Jim Goldsmith
Jim Goldsmith
Alun Cox
Are you a Westinghouse Computer and Internet Expert? Answer questions, earn points and help others
