Question about Gateway Media Center 610XL PC Desktop
How do I install a power supply in a gateway 610xl computer?
Installation of a power supply on a gateway 610xl computer.
    Genius:
  • 1,061 Answers
REMOVE THE CASE AND UNPLUG ALL.THERE SHOULD BE 4 SCREWS HOLDING IT IN PLACE REMOVE THEM.REINSTALL NEW IN REVERSE.RICHARDM69
Posted on Dec 02, 2008
SOURCE:
It doesnt boot up at all , good power,but nothing past the power cord.
Most likely the power supply inside the unit is bad. Try replacing the internal powersupply.If possibe.
Jun 09, 2010 | Gateway Media Center 610XL (610XLMDIA) PC...
Power cuts off or does not start
Check the power cord if it is connected correctly, if does then probably there is problem with the power supply or in the motherboard. Try also replacing the power cords of the power supply.
Oct 21, 2009 | Gateway Media Center 610XL (610XLMDIA) PC...
I have a gateway media center 610xl that has no power.
if you know on how to replace the power supply then do it, if not proceed to bring the computer. or if you have friends can do this, then much better.
Mar 15, 2009 | Gateway Media Center 610XL (610XLMDIA) PC...
How do I change the video card in my 610XL PC?
After the side of the case is opened and the computer unpluged and the video to the monitor unplugged, if it has a card already installed , remove the screw holding the card down then pull the old card straight up out of the card slot. Align the new card that you purchased , pushing it straight down into the slot. Install the hold down screw. Reinstall the side . Install the software after hooking  the computer and monitor up.   If you don;t jknow which type of card ,down load a manual and maybe even further instructions from the weblink I provided.
Below it the Gateway support center for your model. All you have to do is to put in your 22 digit serial number.
http://support.gateway.com/support/drivers/dlcenter.asp
Feb 16, 2009 | Gateway Media Center 610XL (610XLMDIA) PC...
Gateway 610XL Disassembly
take cover off top of base.- pry off
remove two screws that hold speaker unit, it will tilt out, disconnect cables and remove speaker.
two screws on back of base and then take off back cover.remove sheild cover.
disconnect all cables. 4 screws hold power supply in.
rca connector board has little black button holding it on. pry up and then remove board to access connecters behind.
pull all cables out towards you.
remove 6 screws that hold base to back of screen, pull up tape under where cables go thru hole.
remove base from screen.
take out screws on back of screen. carefully pry all around case to seperate.
remove back, and then sheild. there are a few screws that hold it on.
If your screen was black, then the two inverter boards could be the problem. there is one in the upper left corner and one in the lower left corner. you can by them on internet. match the partnumber, there are 2 diffent ones.
Nov 05, 2008 | Gateway Media Center 610XL PC Desktop
Computer doesnt read the the ethernet is hooked up
Did you fix it?
If it IS a Gateway 610, then just download the intel PRO 100 LAN drivers and install them!
Worked for mine!
Jul 08, 2008 | Gateway Media Center 610XL (610XLMDIA) PC...
Power supply installation in gateway 610xl
to replace a standard ATX powersupply;
remove left hand side cover (ensure power is disconnected first);
disconnect the 20.24 pin primary power plug (big wide white one plugs directly onto the mainboard, also disconnect the 4 pin AUX power plug, looks just like the other one but is a smaller square shaped plug (older P3 boards will not have this)
disconnect all 4 pin power plugs from hard drives/cd drives and aftermarket fans (if any are installed), disconnect SATA power plugs from any SATA devices installed (flat black plug, 4 wires)
disconnect floppy drive power plug (if app) small while 4 pin power plug, once all of these are disconnected, looking at the rear of the computer there will be 4 screws holding the power supply in place, one screw will be more to the centre slightly to ensure you do not put it in upside down, once you remove those screws the power supply will slide right out.. simply re-do these steps in revers for instaling the new power supply
David
Feb 28, 2008 | Gateway Media Center 610XL PC Desktop
Video does not work
It sounds like the Lcd inverter board is bad in the monitor
as you turn on the computer if you see no video at all and the screen stays black all the time then the inverter or the power to the inverter is bad.
you need to have the lcd monitor checked out.
the flickering off and on is the usual symptom for this.
Feb 03, 2008 | Gateway Media Center 610XL PC Desktop
Gateway Power Supply
It's not likley the power usage that did in the power supply unless you split the feeds numerous times. The switch should be straightforward, unplug all the feeds paying attention to what you unplug and only unplug what comes from the power supply. It should be a simple matter then to unscrew the supply from the case, remove the old and reverse the operation.
Jan 01, 2008 | Gateway Media Center 610XL (610XLMDIA) PC...
Power Supply/Video on/off problem
hi, seems to be a problem design, you can check the users review on: http://reviews.digitaltrends.com/review1430.html options 1,5 even 6 is ok. sorry.
Aug 26, 2007 | Gateway /ton 160W Power Supply (6500582)...
Gateway Media Center 610XL PC Desktop Logo
114 people viewed this question
Top Gateway Computers & Internet Experts
Ekse
Prashant M
Prashant M
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
