Question about Frigidaire Dryers
It will turn but not dry i loock for the fuse end i can not find it
    Genius:
  • 1,198 Answers
I never found a fuse in a dryer. If it's electric, look for a broken heating coil, they're replacable. If it's gas, you have to check all the parts: ignitor must be glowing red hot; flame sensor must be clean; and worst of all the gas valve can go bad.
Posted on Nov 27, 2008
My turn signals wont work
check the fuse some of those are burned,loock inside of the carr ,under the steering wheel a smalll box, remove the cover and you are going to see several small glass bulbs,pulled out and change all of them, they are very cheap, but is very important what number they have,could be 5 10 20 30 ect.ect .if you put wrong numbers you r going to have severe problems good luck.
Jun 01, 2014 | 1999 Pontiac Bonneville
Whirlpool Duet Steam is not heating to dry any clothes
Don't have your model so I couldn't bring up the schematic some will run with an open thermal fuse I suspect thermal fuse which is non resettable I've only run across a bad thermistor once based on the age check the exhaust exiting the house and at the dryer this a safety fuse designed to open due to excessive heat if the dryer cannot breath restricted exhaust.
Jan 21, 2014 | Washing Machines
2005chryler sebrig GTO comvertible I have electrico problem
Have you checked the fuses? Usually fuses are grouped up. I know the interior light and radio are typically together in the least, so it might indicate that. If it is a fuse and you replace it and it blows again, you probably have a short.
May 15, 2013 | Cars & Trucks
Transmission replaced will not move. put it in gear and odometer works
You need push-in the drive shafts to the transmition and make sure are lock up most drive shaft have a wire ring on the transmition side end that is the self loock .all times double check your work.good look.
Jul 22, 2012 | 2003 Kia Spectra
I have had my washer for about 4 months and i went down all my clothes are still full of water and i cant get any of the cycles to work it trys to spin and then it turns its self off
this usually indicates a blockage or restrictio in the drain pump.you can use a wet dry shop vac and attach it to the end of the drain hose.then you nee to remove the hoses from the drain pump and loock for anything blocking the pump or restricting the hoses.if the unit has a access door you need to check this as well make sure to check the hose that comes down from the bottom of the tub.
Oct 20, 2010 | Maytag EPIC MFW9700S Front Load Washer
GHW9100LW2 Whirlpool front load washer does not drain or spin
use a wet dry shop vac and remove all the water from the unit then check or remove all the hoses from the drain pump and loock for any obstructions in the pump or hoses.
Sep 08, 2010 | Whirlpool GHW9100L Front Load Washer
My dryer does not dry clothes
i would start by checking the thermal fuse and then the heating element itself.
Jul 28, 2010 | Whirlpool LER4634J Electric Dryer
Can the starter button on a 1983 gold wing be cleaned?mine hesitates before turning over.
first before breaking tis switch take a close loock at the battery cable end remove and clean them also check the ground wire from the battery at its other end and the positive at its end. most of these switchesn are not ment to be taken appart.
Feb 16, 2010 | 1983 Honda GL 1100 Innerstate Gold Wing
LOCK CODE
Normally, its the last four digits of your cell number.  If this was purchased on ebay, you'll have to contact the seller.
Apr 21, 2009 | Cell Phones
Dryers Logo
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
