Question about Vizio P50HDTV10A 50 in. Plasma HDTV
Vizio 50'' Plasma AV1 & 2 Ports Unresponsive
I have a PS2 that I've been using on this TV via the AV1 port for about 2 years. Suddenly about a week ago, all I get is No Signal when I turn on the PS2. I tried AV2 with the same result. I've tried a friend's PS2 and cables with the same result. Both PS2s work on another TV just fine. Is there something I'm missing or is this a main board problem that I'm going to have to replace?
  • 3 more comments
  • loridaniel40 Dec 04, 2008
    I have the same problem but with the DTV mode, have you fixed your tv yet?
  • jlp333 Dec 20, 2008
    I've got a P50HDTV, never a problem, but all of a sudden it seems the AV inputs don't work. DVD's won't play, and I just get a "No Signal" message onscreen. I noticed that when I scrolled through inputs, it used to read "ASV-1" and "ASV-2"; however, now it reads "AV-1 (S-video)" and I don't have super video cables.
  • VellanLear Dec 28, 2008
    I am having exactly the same issue.  I have a standard DVD player in the AV1 input port and a Nintindo Wii in the AV2 port.  I have switched ports on each and gotten new cables for each with no result...I am only receiving the "No Input" notice.
    When using the input button on the side of the TV, it doesn't cycle to the AV1(Video) or AV2(Video) options...only to the AV1&2(S-Video) options.  when using the remote to select either of the AV1 or 2(Video) inputs the screen goes black as if searching for the signal longer than usual, then pops up the "No Input" message.
    I noticed that right after this occurs and I hit the AV input button on the remote, it pops up with the AV1(S-Video) first (or 2 depending on which I just attempted to switch) as if it bounced to the other input and doesn't register the video input.
  • TheQueue
    TheQueue Feb 10, 2009
    Unfortunately, I had tried steps like that. The strange part is, I was able to get some devices to work on the AV ports, and all the devices that didn't work, worked just fine on other TVs. It's like the motherboard is confused about whether the connection is there or not. Maybe some sort of grounding issue?
  • Anonymous Mar 15, 2009
    Thank you snfjsm - I had the same problem with my Wii and your fix fixed the problem. My Vizio TV is now seeing the video from the Wii and I am no longer getting the "no signal" message. THANK YOU> THANK YOU>
Put off the TV Using the remote .Then unplug the TV 's power line from power source.Allow this for Just Over one minute .Then plug back the powerline and your TV should be okay.
i had the same problem with wii and this fixed it .
Posted on Feb 05, 2009
IT WORKED!!!! I HAD TO WORK THIS A LITTLE....BEFORE IT WORK ...BUT IT IS NOW WORKING!!!!
OK...SO I HAD THE TV SELECTED TO ANOTHER INPUT (COMPONENT 2, I BELIEVE) THEN I TURNED THE TV OFF....UNPLUGGED IT ......WAITED 2 MINS. TURNED IT BACK ON WITH THE REMOTE.... SWITCHED TO AV1 (OR 2) AND I STILL HAD NO PICTURE.
NOW HERE IS WHERE IT WORKED: . I TURNED THE TV TO THE AV1 INPUT (SIGNAL COMING FROM WII) THAN USED THE REMOTE TO SHUT OFF. UPLUGGED...WAITED ANOTHER 2 MINS AND TURNED BACK ON.....AND TO MY SURPRISE!! BINGO. ALL GOOD. THANK YOU THANK YOU THANK YOU!!!
Posted on Dec 29, 2009
Oh my goodness! I can't believe this worked! I had this problem a year ago while still under warranty & they sent a repair guy out to fix it. Now of course it's not under warranty & did it again. I found this solution & tried it & I CAN'T BELIEVE IT WORKED!!!! THANK YOU SO MUCH!
Posted on Feb 04, 2010
HOLY **** Batman! This fix works! Husband thought he was getting a new LED TV until we tried this!
Posted on Oct 11, 2010
  • LLV67 Jan 05, 2011
    We had a great Picture in TV mode--but was only in Black and White. When a DVD was on--Color was fine. We tried this fix--by putting it in AV mode--turning it off with remote--then unplugging the TV from the wall--wait 2 minutes--Plugged it back in--turned it on--switched back to TV mode--and FIXED!
Both hdmi ports dont work Vizio 50" model P50HDM
Reset Vizio TV default:
1. Press the MENU button on the remote. The on-screen menu is displayed.
2. Use the Arrow buttons on the remote to highlight the Help icon and press OK. The Help menu is displayed.
3. Highlight Clear Memory (Factory Default) and press OK.
4. Enter your parental control passcode. If you have not yet set up a parental passcode, enter the default, 0000.The TV displays, "Are you sure you would like to Restore Defaults? This will erase any custom settings."
5. Highlight Yes and press OK. The TV displays "Memory is being cleared. The TV will reset shortly."
6. Wait for the TV to turn off. The TV will turn back on shortly afterward and the Setup App will begin.
Feb 12, 2014 | Vizio P50HDTV10A 50 in. Plasma HDTV
Vizio will not play hdtv signal
All of those ports are built into the main board. Very easy to replace, board cost approx. 150.00
Apr 03, 2013 | Vizio P50HDTV10A 50 in. Plasma HDTV
How do you play avi files with usb port
you need to know waht video format your TV support.
then use a video converter to convert the vieos you have to the right format and resolution.
Here is the Best video converter I've used.
Jun 05, 2012 | Panasonic TC-P50S30 - 50 1080P Plasma TV
How i am connect Wi Fi or internet to my TV.it is vizio and model number is J V 50 P HD TV 10 A. and Serial number is PHLANCJ2804679. I WANT CONECT WITH INTERNET FOR NETFLIX PLEASE LET ME WHAT CAN I DO.
As I type this, I am using my Vizio 50" plasma. All you need to do is ditch your current monitor you use for your internet service and use the same cord from the monitor to plug it into your RBG port on the back of your tv.
Next for sound there is a 1/4 jack next to the RGB port on your tv. Connect your tv to your audio out on your computer. (headphones or aud out)
Select RGB on your tv, and your good to go. I bought a wireless keyboard and mouse for my computer which makes it more convenient.
Apr 19, 2011 | Vizio P50HDTV10A 50 in. Plasma HDTV
No sound in my 50 inch i have picture but no sound
what about the audio out ports in the rear can u hook a surround sound or something and see if u have sound then if not then id say something went wrong in the tv amp circuit in set
Jan 28, 2011 | Vizio P50HDTV10A 50 in. Plasma HDTV
HDMI ports do not work after lightning storm
Probably not, but your insurance should pay if you have a renter or homeowner policy.
Jul 21, 2009 | Panasonic 50 in. Plasma TV
Sound but no picture on Vizio WS42L TV
did you ever get it resolve? I am having the same problem. my tv is a year and and 1 week old. I am so upset.
Jul 19, 2009 | Vizio P2 42 in. HD-Ready Plasma Television
Panasonic TH-42PX60U plasma TV: red blinking light
are you using a PC to feed a signal or maybe a cable with an adapter?
I had the same issue when I used one of the rear HDMI ports to show a PC display. Apparently there is a software difference between the rear and side/front ports. Inputting the PC through the side HDMI port has solved the problem for me (so far!)
Mar 12, 2009 | Panasonic Televison & Video
PS 2 port problem
What is the model number of your motherboard? VIA does not make Processor's/CPU's.
VIA makes chipset's for motherboards.
In order to answer your question I'll need the manual for the motherboard. No manual listed here: http://www.via.com.tw/en/products/mainboards/others/p4xb_m.jsp
Here is a picture of the VIA P4XB-M motherboard. This model can not use DDR2 memory. (Only, 184pin PC2100 DDR266 DIMM)
Found here: http://www.upgradecomputermemory.com/ram.cfm//memory/V/VIA-Technologies/P4XB-M-Motherboard/256MB-VIA-Technologies-Desktop-184pin-PC2100-DDR266-DIMM.html
VIA P4XB-M
http://www.via.com.tw/download/mainboards/4/11/P4XB-M.pdf
99.0% of motherboards still use PS2 ports. One colored purple for the PS2 keyboard female port, back side of the MB & the other colored light green, female port, back side of the MB PS2 mouse port. By default, most motherboards have the jumper for PS2 keyboard enabled. Location for this two-pin jumper varies from board to board.
A USB port looks like this:
http://www.rickysays.com/images/usb-port.jpg
The PS2 port's are found in the upper left hand corner of this same picture. This next link will show how to connect USB motherboard jumpers including their wire locations. (Standard for most motherboard USB connections).
Mike
Dec 15, 2008 | VIA P4XB-M Motherboard
Vizio P50HDTV10A 50 in. Plasma HDTV Logo
1,194 people viewed this question
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
