Cannot connect to AR-M550-N web interface
I tried changing the ip address for the printer and now it is stuck in between ip's. I cannot connect to it using either the old ip or the new ip through the web interface. I have powered the machine off and back on and still have no results.
    Problem Solver:
  • 11 Answers
Check that the subnet mask and gateway are similar to your current network settings.set them from the machine control panel.
Posted on Nov 28, 2008
  • John Waithaka Nov 28, 2008
    ensure your ethernet/ network cable is properly fixed both on the machine and on the wall socket.Try a new cable.
How to set ip address for kyocera 1320d
Print a Status Page by pressing the green button for about 5 secs. Check the IP Address on the Status Page. If the IP Address is similar to your local network, you type that IP Address in an internet browser to open the Command Center (web interface).
If it is not similar, then you can change PC's IP to be similar to printer and via the command center, you change the printer's IP to a desired IP (similar to your local network) and restore then the IP of the PC to the one before.
Aug 21, 2014 | Kyocera FS-1320D
Need to install ir 5020 onto server. Do I need any config software first like HP JetDirect?
You would need to ensure that the IR 5020 has a valid IP address (Should be located on the Network Configuration Menu from the on-screen display). When plugged into the network for the first time the printer is usually given an IP address, this would allow you to connect to the web management interface and make changes to the settings from an easier interface than the on-screen display.
If you are planning on sharing the IR 5020 out from the server to other computers then you would then need to assign a static IP address to the IR 5020 so that the IP address would not change once configured.
(Side-note - I do not recommend using DHCP on printers as it can cause issues down the road if the printer is given a defferent IP address by the DHCP server.)
Sep 13, 2011 | Canon imageRUNNER 5020 Copier
How do i add the mac address of my printer to the list of permitted devices
Disconnect the Ethernet cable between the router and the cable-modem (or DSL-modem).
Access the web-interface inside the router.
Allow "all" MAC-addresses to access the router.
Turn the printer off.
Turn the printer on, so that it gets a "fresh" IP-address from the router.
On the router's web-interface, get it to show a list of the "active" DHCP-connections.
It should show the IP-address and MAC-address for your printer.
Copy that MAC-address, and the MAC-address of your computer.
On the router's web-interface, access the table of "allowable" MAC-addresses.
Add the two MAC-addresses.
Enable the "selected MAC-addresses only" option.
Reconnect the Ethernet cable.
Nov 04, 2010 | Computers & Internet
No ip info on menu
There is a tiny button on the print server back plane that you can press with a paper clip. This will print out a label with your IP address information. Get the IP address (hope that the printer is set for DHCP) and enter this into a web browser. This will take you to a web interface that will let you make configuration changes to the print server and printer. If the printer is set to static IP, change the IP address of your PC to be in the same subnet as the printer and then fire up the browser.
The user name for the printer is ADMIN and the password is 1234 by default. You can also download ZebraNet Bridge from Zebra's web site. This application will find your printer on the network and let you install fonts, upgrade firmware, change settings, etc.
Jan 19, 2010 | Zebra Z4M Printer
Pls. help us,how can we used land cord to connect printer konica 7035 to computer. we already down load a driver from internet . we try many times to check sa IP address and test print but still we cannt...
Using arp command (UNIX)
From UNIX you can use the arp command to assign the IP address to the network interface card.
Perform the following procedure:
1. Turn off the print controller and the main body printer.
2. Log in as superuser on a host on the same subnet as the network interface card. However, if
the server resides on another subnet, complete this procedure to store the IP address in the
3. Find the MAC address of the network interface card. The address is printed on the Status Page
each time you turn on the print controller and the main body printer.
4. Edit the hosts file (usually /etc/hosts) or use NIS or DIS to add IP address and node name of
the network interface card. See the network administrator for the IP address. For example, a
network interface card with a name of printfast and an IP address of has the
entry: printfast
5. Add an entry to the arp cache for IP address and Mac address of the network interface card,
arp -s 0:40:c8:0:0:ff
RS6000 (AIX) requires the ether option after arp -s. For example:
arp -s ether 0:40:c8:0:0:ff
6. Check the print controller and the main body printer to see that the network interface card is connected
to the network. Turn on the print controller and the main body printer.
7. Send a ping command to the network interface card to verify it is running on the network, as
for example:
ping or ping printfast
The network interface card will not respond to this ping command but it will read its IP address
from the packets.
8. Turn off the print controller and the main body printer and back on again and then send the
ping command again to verify that the network interface card obtained its IP address. A confirmation
message displays as: is alive
9. Remove the entry from the arp cache using the following command. Specify the network
interface card either by its IP address or by its name, for example:
arp -d printfast
Konica Network Interface Card INSTRUCTION MANUAL 2-5
Chapter 2 Setting Up the Network Interface Card
Using MAP
By using MAP (Management Access Program) included the CD-ROM that comes with the network
interface card, you can automatically identify the network interface card on the network and set it up
for TCP/IP by using Web Utilities. To use this method to assign the IP address to the network interface
card, the following procedure should be performed on computers in advance:
• TCP/IP correctly configured
• IPX/SPX-compatible protocol installed
• MAP installed and MAP setup correctly executed
About how to set up TCP/IP and how to install IPX/SPX-compatible protocol, refer to Windows Help
menus for example. For MAP, refer to “Using MAP (Management Access Program)” in this chapter.
To change an IP address already assigned to a network interface card, you can not use the
arp command. Use Web Utilities instead. These methods also allow you to set up subnet
mask and default gateway, etc.
Using NIManage
Refer to “Chapter 7 AppleTalk Configuration”.
 Accessing Web Utilities
The network interface card is provided with an HTTP server having Web Utilities. By accessing this server,
you can change settings of the printing system. There are two ways to access Web Utilities, through a Web
Browser, either through Netscape Navigator, version 4.x or greater or through Internet Explorer, version 4.x
or greater.
• Use MAP to have the network interface card on the networks identified automatically, thereby accessing
Web Utilities.
• Use a Web Browser to type the IP address assigned to the network interface card, and thereby access
the Web Utilities. For example:
If you designate the proxy setting in your Web Browser you cannot access the Web Utilities.
For more information see your network adminisrator.
2-6 Konica Network Interface Card INSTRUCTION MANUAL
A utility called MAP is provided on the CD-ROM that comes with the network interface card.
This program automatically identifies the network interface cards on the networks and lists them on Web
Browser screen. From this Web Browser list you can select a network interface card to change its settings
and control Web Utilities.
Aug 31, 2009 | Konica Minolta Office Equipment & Supplies
Restraunt Pro Express problems
Option 1 (Ethernet II only): Using a web browser, type the default IP address (found on a label on the interface card) into the address field of your web browser. The configuration screen should appear. The default password for the interface is Epson. We highly recommend this be changed. Once the web interface is running, all application, network, printer and password settings can be modified.
Jun 24, 2009 | Pc America Restaurant Pro Express
Add an address to group
Most of these settings for scanning to a destination can be done from the web interface page. Find the IP of the copier and type it into your web browser. Locate address book and make changes there.
Jun 16, 2009 | Sharp AR-M355N Copier
I can't change the printer IP Sharp AR-BC320
If you know the IP address, connect the printer with a laptop using a cross cable. Go to the printer web page by typing the IP address of the machine in the Internet explorer. Browse the menu under network setting and save after you change the gateway
Dec 19, 2008 | Sharp AR-BC320 All-In-One Led Printer
Sharp AR-BC320 Scanner Setup
login to the copiers web interface (the ip address of the printer ex: 192.168.XX.XX) you will see Network Scanning. Here you can change all the scanning e-mail options.
Aug 11, 2008 | Sharp AR-BC320 All-In-One Led Printer
Open Questions:
112 people viewed this question
