Question about Panasonic PV-7400 VHS VCR
The cassette is stuck...
My Panasonic PV-7400 VHS VCR won't eject the tape i have in it, even after trying to turn the gears.
  • andrewalgier Nov 26, 2008
    that doesn't really answer my question.. how?
    • where exactly is this release catch?
  • Panasonic Master
  • 4,806 Answers
The tape is trapped in the mechanisms, you have to strip the VCR down to get the tape out
regards
Posted on Nov 26, 2008
  • Lee Hodgson
    Lee Hodgson Nov 26, 2008
    there should be a release catch on the cradle that the tape slots into, you may have to use some gentle pressure to release and eject the tape
  • Lee Hodgson
    Lee Hodgson Nov 27, 2008
    it will be on the left or right hand side of the cassette cradle, usually near the cog mechanism
Panasonic PV-7400 VHS VCR seems to be stuck in Memory Rewind Off mode. I power on, it attempts to rewind (though there is no tape in there now) for about 20 seconds, then powers off. I've pulled
Most of these problems are caused by a faulty mode switch. If the mode switch has gone off of it's true position, then the electronics might well think it's in rewind mode even in the off position. Sometimes it's just the switch that is faulty, but sometimes damage to the mechanism has thrown off the switch.
Apr 14, 2013 | Televison & Video
A cassette has jammed inside my vcr machine. It will not move forward or backward Can yoy please help
Since the tape won't come out then it means you will have to manually remove the stuck tape. This involves you disassembling the unit in order to help/assist the player get the stuck tape out.
Turn of the unit and remove from the wall, get a Philip screw driver, use it to remove all the screws from the unit and take it apart.
Open the cover and you will see the stuck tape and what's hooking or preventing it from coming out/ejecting.
Now plug the unit, and turn it on. Press the eject button, as the tape tries to come out, support it with your hand so that it can come out.
Or if it happen that the cassette tape has coiled inside the unit, carefully free the coiled tape and the press the eject button.
Lastly, the moment you disassemble the player, you would see what's preventing it from coming out, then you can free whatsoever that is making it stuck press the eject button and the tape should come out.
Make sure the unit is turned off each time you want to remove what's making the cassette stuck.
I hope understand the above explanations.
Good luck.
Mar 04, 2011 | Panasonic NV-FJ620 VHS/S-VHS playback VCR
VHS Cassette stuck will not eject
take the cover off. try to locate the loading motor and turn the gear on it and the tape will slowly eject.
Jun 29, 2010 | Mitsubishi HS-U260 VHS VCR
The vhs cassettes keep being ejected when put in the vhs player
Well the vcr might be broken for the part that allows the tape to sit in there or something is stuck inside of the vcr so it will need to be fixed.
Jun 17, 2010 | Panasonic NV-FJ620 VHS/S-VHS playback VCR
VHS tape only partially goes in & then automatically ejects Panasonic PC-C1332W 13 in TV/VCR combo
sounds like there is a tape in it you are not aware of ,it may have one (vhs tape) stuck in it.
larry
Nov 22, 2009 | Panasonic PV-C1332W 13 in. TV/VCR Combo
Tape would not come out.
Not sure on the removal, but if you replace the mode switch the machine might come back to life.
Jul 31, 2009 | Panasonic PV-7400 VHS VCR
Panasonic VHS Won't eject Tape
unplug then remove the top cover press down on the cassette release and remove the tape then rewind the part of the tape still sticking out by hand push in the button on the side of the cassette to open the cassette cover
May 21, 2009 | Panasonic PV-7400 VHS VCR
Tapes won't go down, and then eject.
Have you tried to force eject the cassette. May be the ribon of the tape has come out. Try using another cassette.
Mar 24, 2009 | Panasonic PV-V4522 VHS VCR
Door jammed open, no power
oN THIS VCR THERE IS 8SCREWS TO REMOVE THE COVER, REMOVE THE COVER CAREFULLY THEN PLUG THE CORD INTO THE WALL, THE CARRIAGE TRAY WILL ACCEPT OR REJECT THE CASSETTE. oNCE THIS PROCESS IS DONE AN THE CASSETTE IS REMOVED UNPLUG THE VCR AND REPLACE THE COVER WITH THE SCREWS
Jan 13, 2009 | Panasonic PV-V4540 VHS VCR
Televison & Video Logo
210 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
