Question about Toshiba 65H80 65" Rear Projection Television
I JUST BOUGHT A TOSHIBA MODEL NUMBER 56H80 AND IT HAS E GOING FROM BOTTOM TO TOP NONSTOP AND THE COLOR ISN'T LINED UP.
  • jay_boogy Nov 26, 2008
    still not fixed but I will try it
  • Toshiba Master
  • 4,806 Answers
Check that the lamps are screwed in properly and reset the tv
regards
Posted on Nov 26, 2008
  • Lee Hodgson
    Lee Hodgson Nov 26, 2008
    also try a factory reset using the manual provided with the TV
    regards
Sound no picture 56h80 toshiba
This set will blank the picture for several different reasons:
No filament voltage to the three tubes it uses.
No high voltage to the three tubes it uses.
No vertical or horizontal sweep (prevents all three tubes from having the screens burnt with a line.
Some of these can be tested but most require a schematic etc.
Set has several fuses and some do not look like fuses--called pico fuses.
Jun 11, 2012 | Toshiba Televison & Video
Hi, our toshiba rear projection tv will turn on but no picture. whats the problem? thanks
MODEL NUMBER 56H80 TOSHIBA PROJECTOIN TV,PICTURE IS NOT COMING AT ALL
WHATS THE PROBLEM
Feb 04, 2011 | Toshiba 57H81 57" Rear Projection...
We've lost the remote to our Toshiba 56H80 TV and need to change the picture size. Is this possible from the panel on the TV?
No,sorry this function work only for the remote control.Try website like Remotes.com to buy an original remote.
Oct 31, 2010 | Toshiba 56H80 56" Rear Projection...
Whats the model number
Satellite Pro L300-164 -> Model No:
PSLBDE-00500AR Vote for me...:)
Jul 26, 2010 | Toshiba Satellite Pro L300 Notebook
My rca toshiba 50 inch projection tv is showing a 3d color curve
Need the model number to help as I am not sure of you have a RCA or a Toshiba
Dec 19, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Seeing double
You need to replace the convergance IC's
Sep 03, 2009 | Toshiba 56H80 56" Rear Projection...
Toshiba 56H80 Convergence Problem?
There are 2 large IC's in your set and one of them has burned out. These are called convergence output IC's and are usually the STK392-010's. A good idea would be to go ahead and replace both with the newer, upgraded STK392-150 IC's. A good tech can change those IC's in about an hour and a half, and when I do a housecall for a set like that I charge $150, but shops in your area will vary so be sure to ask around.
Sep 07, 2007 | Toshiba 56H80 56" Rear Projection...
Screen Discoloration Problem
dJbsharp1: Check if the cleaner you use discolor or remove the clear of the screen. Touch the cleaned part and somewhere else on the screen to see if is rougher than the part you didn't clean-up. If this did not occur you can clean it up completely and watch the difference. If it's rough as I described you, a replacement will be necessary. It is easy to replace. Very easy. Part Number: 23430829 https://www.vancebaldwin.com/webwiz/wwiz.asp?wwizmstr=WEB.SEE&partnumber=4003246&smodel=56H80 Click below to all the info and also for instructions on how to do-it-yourself with the service manual for FREE!!! Good Luck !!! https://www.vancebaldwin.com/shop/research_new/TBA/56H80.pdf SithPitt
Jul 04, 2007 | Toshiba 56H80 56" Rear Projection...
Wavy colors do not line up
http://www.digitalhome.ca/forum/showpost.php?p=564268&postcount=220
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
http://www.eserviceinfo.com/
Oct 25, 2006 | Toshiba 56H80 56" Rear Projection...
Toshiba 65H80 65" Rear Projection Television Logo
95 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
