I have Teac Televideo MV 3450. The 4Amp keeps blowing everytime I change it. What is causing the fuse to blow?
  • 3 Answers
SOURCE: fusible link keeps blowing out , shutting tv off
Thanks to you, I was able to find the solution to my problem.
Have you tried using the correct Fusible Link? I noticed in another post that you said you replaced it with a 500ma instead of the 400ma. I had the same original problem as you and found the exact fuseible links at Part# 576-3960400000 Littelfuse Fuses - A 125V UL TL LL .400A . They are only 55 cents plus shipping. I bought 5 for under $10 shipped. Only took 2 days to get them. My TV works like a charm now! I too thought I may need to replace the IC's but thankfully my TV is working fine. If you did need to replace them, where were they located? I couldn't find any stk IC's inside either and the IC's on the heat sinks are all small. Just trying to be proactive, in case I ever need to replace them.
Posted on Feb 01, 2008
  • 3 Answers
SOURCE: blown fuse
Most likely there was a power event (surge, brownout, ect) that caused the power supply to fail in the TV causing the fuse to blow. you will need to have someone come and look at the unit and give you an estimate. If you keep putting fuses in and blowing them you could actually be causing more damage.
Posted on Mar 10, 2008
  • 291 Answers
SOURCE: thermal fuse keeps blowing
they will blow if the heat dont get out of the dryer and builds up inside / check and see if vent hose behind dryer is kinked or vent going outside is open / it will be one of those two.
Posted on Nov 25, 2008
  • 149 Answers
SOURCE: 95 f250 #7 fuse keeps blowing under hood what does this controll
you have a short its almost impossible to find..i would take it to a dealer
Posted on Dec 11, 2008
  • 8 Answers
SOURCE: main fuse keeps blowing on my Proscan 60690
check the voltage reg.
Posted on Dec 17, 2008
One of the 2 fuse inside keep blowing
When a fuse trips, there is something wrong. Unless you find the component that causes this (or the shortage) you won't be able to use the receiver again.
To diagnose this I need to hook up the device to some gear, so I can't give a correct diagnose over the net. Sorry.
Jan 27, 2015 | Teac AG-680 Receiver
User manual for Philips urc model srp3004/10
check manual at this site.
Follow the instructions to program code for TV. The codes for each manufacturer including Teac is at the back of the manual.
Sep 12, 2014 | Office Equipment & Supplies
Cause fuse keep blowing
You have a short. you will need patience to route the wires from the harness to the light source, and to inspect for frail damaged wires.
Aug 16, 2013 | 2006 Toyota Sienna LE
My teac ag-680 fuse keep blowing everytime i replace it and plug the reciever up
are short in the audio output transistors may have been short since a channel 2 or maybe 4, also open resistance check carefully and change them after you put a 75w bulb in series 100w or where is the fuse clearly, you have to remove the fuse when you put the focus if all is well will turn on only a small incandescent and amplifier work well you put audio speakers and there will, if everything is well put the fuse back and ready.
Jan 14, 2013 | Teac AG-680 Receiver
Fuel ECU fuse keeps blowing (30 amp)
Your fuel pump is internally binding and causing the fuse to blow. Change the pump (and filter while you're back there.)
Jun 14, 2009 | 1993 Jeep Wrangler
Keeps blowing fuse.
Dissconnect ALL speakers from back of unit then try to turn on.
If it works you have a speaker short.
If not, you have a more serious problem.
DO NOT replace the fuse with anything else but what was specified, as it can cause a fire!
Jun 14, 2009 | Teac AG-V8600
Fuse blows everytime i turn it on
the blue coloured varacter in your power supply circuit needs to be changed
Mar 30, 2009 | Teac AG-V3050 Receiver
Can't change TV to AV input.
dont bother trying to do it but then i got the same problem :)
Nov 30, 2008 | Televison & Video
Hitachi Performa CP-RS55 Multimedia... Problem
ok " sounds like you have a short, thats why it's blowing fuses
Nov 06, 2007 | Hitachi Performa CP-RS55 Multimedia...
The fuse keeps blowing out
you have defective power supply! you have shorted parts! like diode or regulator. replace the shorted regulator.
Oct 03, 2007 | iLO 3200 32 in. LCD Television
Televison & Video Logo
Top Televison & Video Experts
