Question about Epson RX620 All-In-One InkJet Photo Printer
I have an Epson Photo RX620 & am experiencing a paper jam problem. The paper will attempt to load but the right side is all that is drawn in (about 1/4"). The left side stays complete out of the shoot & then, of course, the paper gets rumpled on the right side. The ink cartridge carrier then proceeds to go back & forth as though printing. Epson has not answered my problem so I am turning to you. Help John
  • 1 more comment
  • barb merkel Feb 10, 2009
    i have the same problem but when facing he printer it feeds on the left side but seems to jam on the right side?
    have an epson RX620 and paper jams on right side when facing printer......so it pulls through crooked if i let it go and then jams inside
  • Gordon Walz May 11, 2010
    Thanks
Dear Sir/Madam, Im looking for some help, in regards to my camera 'Sony DSC-F88' recently the lens has gone faulty and so I would like to order/buy a replacement lens 'carl zeiss rotating lens optical 3x'. Please let me know as soon as possible how much this would be as I would like to put in an order, or how much it is to get it repaired. ( I have already searched the sony website and have found no options as to get this ordered) or if possible direct me to the correct web link in order for me to put in an order. Many thanks R Monthy
Posted on Feb 09, 2009
Paper not feeding for epson nx400
Check the following:
  • If paper doesn't feed, remove it from the sheet feeder. Reload it against the right side, behind the tab, then press in the tab on the edge guide and slide it against the paper. Make sure the paper is not above the arrow mark inside the edge guide.
  • If multiple pages feed at once, remove the paper from the sheet feeder, fan the edges to separate the sheets, then reload it.
  • If the paper doesn't eject fully, you may have set the wrong paper size. Press the c:\users\home\appdata\local\temp\msohtmlclip1\01\clip_image001.gif Stop button, then open the scanner and remove the paper. Select the correct paper size when you reprint.
  • If it's wrinkled when it ejects, the paper may be damp or too thin. Load new paper.
  • Make sure you use new, smooth, high-quality paper, that is not curled, creased, old, or too thin. Make sure to load it printable side up.
  • Do not load paper with holes punched in it for insertion in a binder.
  • Make sure you load only up to the recommended number of sheets. If you're printing on both sides of the paper, try loading fewer sheets.
Paper type
Load up to
this many sheets
Plain paper
Approximately 120
Epson Bright White Paper
Epson Presentation Paper Matte
80
Epson Photo Paper Glossy
Epson Premium Photo Paper Glossy
Epson Ultra Premium Photo Paper Glossy
Epson Premium Photo Paper Semi-gloss
20
Epson Premium Presentation Paper Matte
Epson Premium Presentation Paper Matte Double-Sided
Epson Photo Quality Self-Adhesive Sheets
Epson Iron-On Cool Peel Transfer Paper
If the paper jams, do the following:
1. Gently pull any jammed paper out from the output tray or sheet feeder.
2. To eject the jammed paper, try turning the Epson Stylus NX400 off and then back on.
If that doesn't work and paper is stuck inside, turn off the Epson Stylus NX400. Open the scanner, remove the jammed paper and torn pieces, close the scanner, and turn the Epson Stylus NX400 back on.
Aug 17, 2012 | Epson Stylus NX400 InkJet Printer
Paper jam indicator shows after jam is removed
power cycle the printer, meaning pls. turn off the printer, then wait for about 10mins. turn it back on. while it is off check for obstruction or paper jam inside the printer, if none, turn it back on
if the issue persist, that means the printer is already broken
Feb 12, 2010 | Epson RX620 All-In-One InkJet Photo...
Epson Stylus photo 340 r printer paper jam when trying to print
first, make sure you the paper correctly to avoid paper jam.
Single Sheets 1. Open the paper support and raise the extension. 2. Place your paper short edge first against the right edge of the feeder, under the tab, with the printable (whiter or glossier) side up. If you are loading multiple sheets, fan the stack of paper before loading it to prevent paper jams. Note: Don’t load paper above the arrow mark inside the left edge guide. Some special papers can be loaded only one sheet at a time. Slide the left edge guide against the paper. Make sure it is snug, but not so tight that the paper is bent. (For letter- or A4-size paper, you may not need to move the edge guide over.) paper.4.2.1.jpg 4. Open the output tray and pull out the extension. You should also follow these guidelines:Always load the short edge first, even when you’re printing landscape-oriented pictures. • When using special papers, check the paper package for additional instructions. Some papers require using a support sheet included in the package. Note: Always keep unused paper in the original package and store it flat to prevent curling.
if you loaded the paper, it jammed again, remove the paper and tried to print, still the same, its a hardware issue, alraedy, the printers roller is broken
Feb 09, 2010 | Epson Office Equipment & Supplies
Paper jam, with no paper jam!
try to re open again your machine and look very carefully inside remember even how small the paper it will still cause for a paper jam.
if not try to send it to a service technician to give a look to the printer head and rollers.
thanks,
Jun 14, 2009 | Epson Stylus Photo RX620 All-In-One InkJet...
"Clear paper jam" error, but there is no jam!
Use flashlight to shine inside of all possible visible areas of printers. Especially to the very right or very left. I'm sure you will find something. Remove it
If you need further help, I’m available over the phone at https://www.6ya.com/expert/alex_22751bbefa74c3d0
May 25, 2017 | Epson Stylus Photo RX620 All-In-One InkJet...
I put a lighter pound paper in the printer RX620 and it all entered the printer at once (about 25 pages) and is stuck! I can't free it--can you help me?Thanks
unfortuanately you'll need to roll up your sleeves and pull very hard to remove that jam... the manual recommends the proper thickness of paper for the printer and you should stay within those boundaries
Robert
Jan 06, 2009 | Epson RX620 All-In-One InkJet Photo...
Paper Will Not Load
1. Turn the printer off and open the access cover.
2. Look for any obstructions in the paper path and remove them if necessary. (It is possible to move the carrier assembly with the power off.)
3. Turn the printer on, load some paper, and press the Form Feed button.
4. Watch the paper as it feeds through and try to determine where the jam is occurring.
5. Check to see if all the rollers are turning.
If all the rollers are turning, there may be something in the feed path that you can't see. Go to step 6.
If not, there is probably a feed motor or a gear problem and the printer may require service.
6. If the paper is jamming under the carrier assembly, you may be able to fix it using the manual feed slot.
7. Turn the printer off.
8. Take a #10 envelope and feed it through the left side of the manual feed slot until it comes right through the printer to the back of the exit rollers.
9. Move it up and down first, and then slowly move it over to the right side. If something is stuck under the black guide plate, this may work it loose.
Nov 10, 2008 | Epson Stylus Photo R220 InkJet Printer
Epson cx4800 - will print in text mode but gives me a paper jam message in photo mode pape ris not jammed
It sounds like a driver issue. Have you tried to uninstall and reinstall the software on your computer?
Nov 02, 2008 | Epson Stylus CX4800 All-In-One InkJet...
Paper jam.
In each case it seems that it is a software corruption possibly caused by a windows update.
Do the following.
Switch off the printer.
Go to Start/Printers and Faxes/ click on remove printer.
Go to Control panel add/remove software
Remove ALL Epson modules
go to Start /Run in the filed type REGEDIT
go to Edit/Find in the Field type Epson RX620
Select and delete all entries that turn up
Shut down you Internet connection.
Disable all Anti Virus and Mal-ware protection
Reinstall Epson from disc following the prompts exactly.
Restart the Computer
Dec 12, 2007 | Epson RX620 All-In-One InkJet Photo...
Epson RX620 All-In-One InkJet Photo Printer Logo
101 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
