When wiring a new plug for which voltage input?
The cutter has a white wire, a black wire, and a green one - white is the neutral line, black is the hot line, green is ground.
You can see this in section 4-9 of the owners manual, if you don't have a manual you can go to www.millerwelds.com and get a PDF file of the manual.
Rank this answer please,
Carl
Power Plug Wiring
Connect this welding & cutting equipment with the power supply of 110 or 220V AC.
For the wiring, please note that:
For 110VAC,
- The green wire with yellow stripe is the ground wire
- The red/brown wire is the hot wire
- The blue/black wire is the neutral
For 220VAC,
- The red/brown wire is positive 110VAC
- The blue/black wire is negative 110VAC
Connect the earth terminal with the earth cable of minimum diameter of 2.5 mm2.
That's for 120V hookup. How do I hook thi machine up to 230V?
