Question about Canon imagePROGRAF W8400 InkJet Printer
Grayscale, black only printing
We have a Canon 8400 and are trying to print a grayscale, black only image. We have a grayscale photo and we also have a full-color poster with some black only/grayscale text. We cannot get the grayscale to print without color in it. It keeps printing with a lot of magenta. We have tried many different color settings and paper profiles. The full-color poster needs to be printed on matte paper. How can we get a grayscale/black ink only image to print with black ink only?!
  • us275 Dec 01, 2008
    FYI... If this Canon device is being driven by a
    regular print driver and not a true postscript rip, the device will be
    hard to control.
    My first suggestion is this... Open the grayscale image in Photoshop
    and convert it to your working RGB color space. Next, make sure to save
    the file as an RGB image with the color profile embedded. Update the
    image in the layout and create a new PDF. When making the PDF use the
    Full Gamut job.options
    http://alphalink.alphagraphics.com/opera...
    The PDF you end up with will be in an RGB format. It is best to print
    using RGB content to an RGB print driver. If you have mixed content in
    the layout document,i.e. RGB and CMYK and Spot, just change the option
    on the "output" setting when making the PDF to "Convert to Destination"
    and use the sRGB profile as the destination space.
    Now, print the new RGB PDF through the print driver with ICC matching
    enabled and sRGB as the preferred color space. You can also control the
    color further in the printer driver as well... there are RGB sliders
    that you can use to adjust the color.
SOURCE: Cyan, magenta and yellow not print after replace the new print head
I am going back to Epson
Posted on Jul 25, 2008
ikechinedu
  • 184 Answers
SOURCE: Color toner used up even though I selected grayscale
Selecting grayscale only will also make use of your color. when u select grayscale, look under the print options and select black cartridge only and for more economic printing, use fast draft or draft printing.
Posted on Jun 09, 2009
  • 630 Answers
SOURCE: wouldn't print black-and-white if the color cartridge is empty
Select true black and white. Any other setting uses the colour cartridge to sharpen the printing.
Posted on Aug 22, 2009
  • 217 Answers
SOURCE: I want to set the default on my Dell 1320c printer to grayscale
Should be an option in the printer driver to do this.
Try
Printing preferences
and either Colour or Paper/Quality should have an option to print in Greyscale or Colour
Posted on Aug 31, 2009
SOURCE: My printer is out of grayscale ink. It will not
bukes1 is actually right. I have the same printer and I'm having the same problem. The MP980 has a black, pixel black, cyan, magenta, yellow, and a grey cartridge, so 6 all together. The grey replacement cartridge is not readily available at a store. You have to purchase it online. I don't understand why Canon does not include it in the color multi-pack. It's quite a nuisance, because when the cartridge runs out you can't print at all.
Posted on Nov 11, 2009
Canon Printer MP250 doesn't want to keep the grayscale ONLY setting.many attempts to use only black ink but it keeps on setting color ink by default. SB001
If you are changing to greyscale before you print, it will only stay there for that print job. You need to go to the printer through the control panel - devices - printer and change it to greyscale. It should stay that way then.
Jul 03, 2015 | Canon Pixma MP250 All-in-One Color InkJet...
Both lights on printer flashing
If you set to black and wite it should also print pictures by the way, it does not accept grayscale because it won't be able to print in grayscale photo quality.
Aug 20, 2008 | Canon PIXMA iP1600 Printer
I have used last 4 year canon 2900B printer. How to set 300 dpi printing resoluation
Canon PIXMA Manuals MG2900 series Resolution
Resolution The data in the image you have scanned is a collection of dots carrying information about brightness and color. The density of these dots is called "resolution", and resolution will determine the amount of detail your image contains. The unit of resolution is dots per inch (dpi). Dpi is the number of dots per inch (2.5 cm). The higher the resolution (value), the more detail in your image; the lower the resolution (value), the less detail.
How to Set the Resolution You can set the resolution in Resolution on the (Scanning from a Computer) tab of the Settings dialog.
Appropriate Resolution Settings Set the resolution according to the use of the scanned image.
Item Type Use Color Mode Appropriate Resolution Color photo Copying
(Printing) Color 300 dpi Creating a postcard Color 300 dpi Saving to a computer Color 300 dpi Using on a website or attaching to e-mail Color 150 dpi Black and white photo Saving to a computer Grayscale 300 dpi Using on a website or attaching to e-mail Grayscale 150 dpi Text document (document or magazine) Copying Color, Grayscale, or Black and White 300 dpi Attaching to e-mail Color, Grayscale, or Black and White 150 dpi Scanning text using OCR Color or Grayscale 300 dpi Important
  • If you double the resolution, the data size of the scanned image quadruples. If the file is too large, the processing speed will slow down significantly, and you will experience inconvenience such as lack of memory. Set the minimum required resolution according to the use of the image.
Note
  • When you will be printing the scanned image by enlarging it, scan by setting a higher resolution than the recommended one above.
Oct 07, 2014 | Canon LASER SHOT LBP-2900 Printer
Canon Pixma 3600 I want black & white printing only for documents Question: How do i turn off the colour cartridges for black & white printing only?
The Grayscale print option optimizes the look of color slides for printing on a black and white printer by adding shading. The Pure Black and White option prints your slides in monochrome.
  1. Open the presentation you want to print.
  2. Click on the word File in the Menu Bar.
  3. Select the option Print.
  4. The Print dialog will appear.
example:
sayurisan20_3.jpg 5.In the Color/Grayscale section, choose the Grayscale option to print in black, white, and shades of gray. 6.Choose the Pure Black and White option to print in black and white only. 7.Click on the OK button.
Jun 06, 2011 | Canon Office Equipment & Supplies
Black and white prints are not black
Sorry, steve, that you are experiencing this problem.
According to canon.com's website regarding the i9900 InkJet Photo Printer:
Why color ink may be used when printing in black and white Even when printing in black and white, color ink is used for the following reasons:
  1. Automatic cleaning of the print head.
    To prevent the print head nozzles from clogging, the print head is automatically cleaned periodically. At that time, a small amount of each color ink is consumed.
    Therefore, although printing in black and white is performed, color ink is also consumed.
  2. Color inks may be used to create black.
    When printing in grayscale or on photo paper or when duplex printing, although printing appears in black and white, the color black may be created using the three (cyan, magenta, and yellow) color inks. Printers without a pigment black tank / cartridge will print black / grayscale will create a composite black using color ink even on plain paper.
    Therefore, although printing in black and white is performed, color ink may be consumed.
  3. In order to keep the heavy black ink from smearing on the page or in the printer, color ink is used when duplex printing to help create black text.
I might suggest taking out the color ink cartridges leaving only black there, but some printers don't take kindly to this. So, you may have to further experiment with magenta, cyan, and yellow to make it at least seem b&w to your best eye's judgment.
Good luck on this.
Jul 13, 2010 | Canon i9900 InkJet Photo Printer
PRINTS PROBLEM
More than likely what you want is a gray scale image and not a true Black and White image. If you tell the printer to print Black and White for a photo, you will lose all the gray shades available between the black and white bookends.
Normally, you can set the printer to print grayscale only from the driver properties page.
Don
Feb 16, 2010 | Canon PIXMA MP210 Photo All-In-One Printer
Jun 09, 2009 | Canon PIXMA iP1800 InkJet Photo Printer
Color photo printing
On the menu tab for 4X6 ,under effects ,you have selected black and white or grayscale
Apr 02, 2009 | Canon PIXMA MP980 All-In-One InkJet...
Black & white photo printing reddish-pinkish-orangey
In the Printing Preferences select to print in Grayscale.
Sep 19, 2008 | Canon PIXMA MP530 All-In-One InkJet...
Canon imagePROGRAF  W8400 InkJet Printer Logo
144 people viewed this question
old marine
old marine
