Question about Tatung V30CMTT 30 in. HD-Ready LCD Television
Picture color is off/people look green
I have a Tatung LCD. Turned it on this morning & the color is not proper. All of the people on tv look green.
3 Suggested Answers
SOURCE: tatung LCD television
The power outage simply precipitates a pre-existing flaw in the power supply unit of this TV. You will need to either order a new power supply and put it in yourself, or send it to Tatung to fix. I had the same problem. Contact this person:
Vila Khamkathok
Customer services supervisor
Tel: 800-827-2850 x161
Posted on Nov 08, 2007
  • 11361 Answers
SOURCE: i lost power in my house for less than a minute
Unplug it for about an hour to let it reset itself, if still does not work, you will have to open it up.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
Posted on Jul 14, 2010
  • 1654 Answers
SOURCE: The picture on my lcd,
Does this happen while watching the tv through a cable service or satallite service or does this also happen when watching a DVD through a player?
Pixelation occurs when the incoming signal to your TV is weak or incomplete. As a result, the TV doesn't have all the data it needs to process the image correctly, and pixelation occurs. In layman terms, it can be thought of as the TV's manifestation an incomplete image. The causes of this problem usually stems from incomplete or incorrect digital or analog signals. The other causes are weak cold solder joints in one or more of the buffer boards, or tuner on the set. If your handy and know how to solder, you can take the boards out of the set and look for bad solder joints on the board and simply re-solder them. If it is not the cable or satallite and your hesitant to take the boards out to look for bad soldering, then I suggest you have a tech look the set over. If it is still new enough that you have a warranty let the dealer who sold this to you take a look at it. Let me know how you wish to proceed.
Posted on Mar 16, 2011
0 characters
1 Points
My Tatung plasma TV model no. P42hsmt when powered on shows green static no picture when changing channel screen turns to a strip of lines and returns to green spot static
If you wish to get some details; visit the site linked here. Pull up older posts. Surf the site with patience.
Line, faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent.
Jun 07, 2015 | Tatung Flat Panel Televisions
Digital Lifestyles 42" LCD HDTV
How many hours has the tv been used ... approx... as this will reveal further solutions..
Jun 09, 2008 | Digital Lifestyle FA1B32Z 32 in. LCD...
Green picture
Hi Lizzette,
I am afraid your problem is a little technical. Well if you know something about lcd tv technicals, the problem seems to be the T Con board and/or its connectors. Check the ribbon cables and connectors, clean them properly and and start the tv.If it is not possible or it does not work, please consult someone qualified to handle your set. Good luck.
Dec 18, 2013 | Samsung 46 in. LCD HDTV
Insigna lcdtv32 the picture has turned green.
Ask the technician of the manufacturer for the service mode or the program for setting your lcd to its factory deault setting. then set your tv using a remote control. Not all technicians are willing to give that information. Try to download manual of your lcd from this link and check it yourself :
Dec 07, 2009 | Insignia IS-LCDTV32 32 in. Television
Sony 50A10 LCD tv. Turned on tv this morning and
Yeah the fans continue to rotate for at least 2 minutes past shut off time.
Nov 16, 2009 | Sony KDF-E42A10 42 in. LCD Television
Tatung plasma has cloudy screen. In and out seems to depend on backround color if picture is bad or not
That was the first generation, I would invest in another set considering the age and parts availability.
Apr 29, 2009 | Flat Panel Televisions
My 61 inch RCA Scenium, currently has sound but no picture appear
My exact same problem turned out to be the cable box not the TV. Try unplugging cable box for 5 minutes then power up! Solved my problem!
Apr 01, 2009 | RCA Scenium HDLP61W151 61 in. HD-Ready...
Westinghouse LTV-27w7 HD TV, two yrs old, blueish square flashing on & off, no picture.
if you have warranty work they will direct you to the service center you will need, I do not know of any bb that service tv's.
May 08, 2008 | Westinghouse LTV-40w1 HDC 40.02 in. LCD...
Mine isnt even 1 year old and same problem. was fine last night, woke this morning, turned it on and there they are green and purple
Apr 08, 2008 | Sony BRAVIA KDL-40S2010 40 in. LCD...
TV has sound with no picture display
Is it possible the pip and the main picture have been swapp and the main picture is showing as the Pip?Is a possibility,check it out and let me know.
Sep 29, 2006 | Tatung V30DMTT 29.6 in. LCD Television
Tatung V30CMTT 30 in. HD-Ready LCD Television Logo
64 people viewed this question
Top Tatung Flat Panel Televisions Experts
Jaime Hernandez
Josh Whitehead
Josh Whitehead
Are you a Tatung Flat Panel Television Expert? Answer questions, earn points and help others
