SOURCE: 1994 pontiac bonneville fires up but stalls imediatly
WOW a 94 with 46K on it thats rare. Your computer may be bad it sends the pulse to the injector.
SOURCE: 1998 GMC Sierra- runs rough then stalls when
had this problem on my neighbors 98 chevy truck with the same engine !!
it turnd out too be the fuel pressure regulator,you have too pull the upper intake too replace it!!
SOURCE: 1998 ford winstar 3 litre keeps stalling new fuel
WELL THIS VAN HAS MANY ISUSES NEED TO JECK FOR VACUME LEAK AT IN TAKE AND THE PLENUM IF ITS PLASTICK THEY TEN TO CRACK OR THEY HAVE GASKET FAILER VERY COMEN ON THIS CAR OR YOU MAY NEED TO CHECK EGR VALVE IF STUCK OPEN IT WONT IDLE THEN YOU HAVE THE IAC VALVE IDLE AIR CONTROL VALVE YOU CAN USE BRAKE CLEAN AROUND IN TAKE BUT BE VERY CARFULL FLAMIBAL SHOULD HAVE FIRE EXTINGSHER NEAR YOOU WHEN DOING THIS
Testimonial: "thanks turned out to be the air flow sencer on the breather so thanks to you i located and fixed the problem"
SOURCE: 93 mazda mx6 wont run. will start but runs very
If yours is the v6 2.5 the tps is adjustable and you can turn it up and down. On my mazda it acted like it was in the fuel system and i ended up replacing the distributor.
SOURCE: truck stalled out while driving will not start
Not sure about your truck older Fords have 2 fuel pumps 1 in the tank & 1 under cab drivers side. Anytime you change a pump you must change your filter. also check your fuel line if it has been pinched or has a leak pressure will drop
