Question about Canon CanoScan 9950F Flatbed Scanner
Making strange noises and stopped working
My scanner recently started making strange noises and stopped working. It was well taken care of and I'm not sure why it stopped working.
  • letrandinh Nov 26, 2008
    Thanks for your reply. But I would like how much it costs for the parts and labor (just estimate)
  • 64 Answers
It sounds like a broken mechanic part problem. You need to bring it to an authorized repair shop.
Posted on Nov 26, 2008
  • Farhang Mobarhan
    Farhang Mobarhan Nov 26, 2008
    Unfortunately It is impossible to estimate the repair cost without open it and take a close look at it.
Why the scanner keep saying "busy try later or select another computer?
Strange bug. Check if a new driver is available for your unspecified scanner. Unistall driver and reinstall it or reinstall a more recent one
Aug 03, 2015 | Office Equipment & Supplies
Strange noises
It really helps if we had the year make and model of the vehicle to further help you.
Jun 07, 2017 | Vacuums
I HAVE AN ELCECTROLUX SPLIT AC.. VOICE COMES FROM IT IN LOW FAN MODE AND IT STOPS AT HIGH FAN (TURBO) WHAT COULD BE THE PROBLEM .HOW TO RESOLVE IT..?
Check and make sure the filters are clean. Strange noises can occur if they are dirty. It may also be a "dry" fan bushing. At the end of the fan barrel, (Usually the left side) there is a brass bush which can dry out and cause a squeaking noise. Carefully insert the long tube of a WD40 (or similar) oil spray can, into the outside of the fan barrel on the left hand side. NOT when the machine is running.. and give it a light spray, the oil should seep into the bush and quieten it down if that's the problem. To do the job properly however, the indoor unit would need to have the cover taken off and the bushing removed and oiled....
Mar 28, 2014 | Heating & Cooling
Samsung NX11 Error 00
Low Battery, or exhausted ones, also gaves error 00, due to inability to provide high power to the lens.
Jul 05, 2012 | Samsung NX11 Digital Camera
Two-Cup Button is Making A Strange Noise
Machine my need a new exshust valve try back flushing the machine with only a pinch of back flushing powder.
Feb 23, 2012 | Breville BES860XL
Just inherited Nikon 8000 ed scanner. Downloaded 3.1.4 driver. Scanner starts to work. Plug in in photoshop cs2 works. Slide tray starts to load then stops at about 3/4 mark....strange noise like...
Hi Good day!!! yes based on what you've said you hear something suspicious in your unit. maybe something wrong with the gears. I'll suggest to contact your local technician to check your unit because it is very risky if you open it on your own.
Thank you for using FixYa
Please accept if my solution helps you
Nov 08, 2010 | Nikon Super Coolscan 8000 ED Film Scanner
Belt squealing noise when heater turned on
yes...your engine belt is little bit lose that's y its causing noise...and hope when u speed up..it will stop squealing ..right?? so just tight your engine belt little bit and it will solve your problem in a min...take care n have a safe journey...n also if it help...rate it plz
Jan 23, 2010 | 2001 Hyundai Elantra
Microtek ScanMaker 9800XL
Microtek is famous for making a good product that will last you a good while if it is maintained and taken care of. Yet their lack of support for said products is lacking. Try to uninstall and reinstall all the software for the scanner. Make sure before you uninstall that you still have the install disc. If not then you can find the drivers on the Microtek site.
Mar 04, 2008 | Microtek ScanMaker 9800XL Flatbed Scanner
Scanning does not stops
please check all sensor arms in the document feeder. The sensor arm in the middle just below the separation pad is called 'paper end sensor'. If this sensor arm is blocked or broken the scanner don't stop the feeder.
Another possibility is a driver error.
Jan 08, 2008 | Fujitsu M4097D IPC Path-Through Flatbed...
Canon CanoScan 9950F Flatbed Scanner Logo
433 people viewed this question
old marine
old marine
