Question about Lands Phones
Answering switched to handsets
Handset display is NEW VOICE MAIL. UNABLE TO RETRIEVE MSG.CHARGE/INUSE LIGHT BLINKS. PHONE MODEL IS 25942 5.8 CORDLESS ANSWERING SYSTEM.
  • 928 Answers
Just to confirm this is a GE unit right?
You can try to unplug the unit for about 2 or 3 mins. then plug it back in see if you can retrieve now.
Normally as well the voice mail is provider specific so you might have to call your provider for information on retrieving it.
Posted on Nov 26, 2008
    Genius:
  • 1,605 Answers
Need to change a new battery.
the battery is not holding the charge
    Sergeant:
  • 276 Answers
Is the phone totally/fully charged
  • 1 more comment
  • smarttech Nov 26, 2008
    • Press the ans on/off button to turn the answering system on and off. The Message Counter indicator lights when the answering system is on. The indicator blinks when you have new messages.
    NOTE: The answering system displays "- -" when it is off.
    Unit beeps
    • Clean the charging contacts on the cordless handset and base charge cradle with a soft cloth or an eraser.
    • See solutions for "No dial tone " on previous page.
    • Replace the battery.
    Telephone Solutions
    No dial tone
    • Check or repeat installation steps:
    Make sure the base power cord is connected to a working electrical outlet.
    Make sure the telephone line cord is connected to the base and the wall jack.
    • Connect another phone to the same jack. If it doesn’t work, the problem might be your wiring or local service.
    • The handset may be out of range of the base. Move closer to the base.
    • Make sure the battery is properly charged (for 16 hours).
    • Make sure the battery pack (in the handset) is properly installed.
    • The handset should beep when you press the TALK/CALL BACK button, and the charge indicator on the base should be lit when the handset rests in the cradle. If not, the battery may need to be charged.
    • Place handset in charge cradle for at least 20 seconds to reset the unit.
    Handset does not ring
    • Make sure the handset ringer software switch is set to on.
    • You may have too many extension phones on your line. Try unplugging some extensions.
    • Check for a dial tone.
    You experience static, noise, or fading in and out
    • The handset may be out of range of the base. Move closer to base.
    • Make sure base is not plugged into an electrical outlet with another household appliance. If necessary, relocate the base.
    • Charge the battery (for 16 hours).
    Memory dialing doesn’t work
    • Did you program the memory location keys correctly?
    • Did you follow proper dialing sequence?
    Unit locks up and no communication between the base and cordless handset
    • Unplug the power adaptor from the electrical outlet and the back of the base. Remove the handset battery. Wait for 30 seconds and plug the power adaptor back into the base and electrical outlet. Reconnect the battery and charge for 16 hours.
How do I retrieve voice mail messages from my uniden dect 6.0?
If you subscribe to a voice mail service, you can use your phone to access your voice mailbox. The new message
LED on the handset flashes and appears in the handset display whenever you have messages waiting in your
voice mailbox. When you subscribe to the service, your voice mail provider provides you with the access number
and the required voice mail signaling tone. You can use your phonebook to store the access number
Feb 13, 2013 | Uniden DECT 6.0 Cordless Telephone...
Base keeps blinking, and phone says new voice mail, read manual, says nothing about voice mail.Model 25942 series 5.8 Ghz Cordless Handset Answering system guide.
try unplugging the base to reset it. That voicemail signal is set on or off by your phone service provider. Check with them to see if a: you have v-mail or b: they can reset it
Sep 13, 2009 | Uniden Cordless Phone
Panasonic kx-tga101cs incorrect voicemail message
Press and hold "Clear" until it beeps. It will clear the invalid voice mail msg.
Jul 16, 2009 | Panasonic KX-TGA101S Cordless Handset
My handset displays "New Voice Mail" and the base displays 00.
This is the problem, thebase charge light flashes continuously,It says that I have a new voise mail and the the base says (00)
Mar 04, 2009 | Uniden Cordless Phone
The base "charge/in use" light is blinking two blinks each time.
Called comcast (phone service provider) and requested that voicemail isn't activated until phone has rung 7 times. My answering machine is set for 5 rings.
Feb 02, 2009 | GE 25942GE2 Cordless Phone System
How do you unregister a defective handset so that it can replaced
1. Delete or listen to all voice mail messages, if necessary, to clear the IN USE/Voice Mail light indicator.
Note: Skip this step if it does not apply to your MD Series cordless telephone model.
2. Press OFF on the base station and each handset.
3. Press and hold down PAGE on the base station until the IN USE light flashes slowly, then release.
4. Press and hold down PAGE again until the IN USE light begins to flash quickly, then release PAGE.
5. Quickly and fully press and release PAGE again.
6. Please register handset displays. Press OK to begin the registration process, or press EXIT.
Dec 10, 2008 | Motorola Mobility MD41 Expandable Handset...
New Voice Mail flashing light
press "mute" key to access menu, press the up or down arrow key labeled "caller ID- volume" until you get to "handset setup", press the "mute" key again, press the down or up arrow until you have "defaultsetting" selected, press "mute" key, press "1", then press "mute" once more. At this point your handset will reset clearing the indicator for all the handsets. I've had to do this twice on my phones and it worked every time.
May 10, 2008 | Uniden Cordless Phone
What worked for me was to call my phone from another phone and leave myself a voicemail. I then went in and retrieved and deleted that voicemail. Once I hung up from my voicemail service my handsets reset about 10 seconds later.
I hope this helps!
Apr 05, 2008 | Uniden Cordless Phone
Displays new voice mail and VMWI constantly blinking when no voice mail
Subscriber is T-Mobile@Home. First, cleared all messages from T-Mobile voicemail.
Now to fix your GE phone:
Push the program key. Select Handset Setup Push the program key Select Default Settings Push the program key Select 1 Yes. Push the program key
Hope this helps.
Mar 06, 2008 | Uniden Cordless Phone
Cordless Phone
You did record a message on the answerer, didn't you? Mine displayed that until I recorded the outgoing message for the answerer. You do not need any service from your phone provider. The answerer in the base unit simply records the caller's message when you don't answer after a set number of rings. The manual tells you how to name the handset, which is a nice feature if you don't wish to use "unit 1, unit 2, etc".
Aug 28, 2007 | GE 28112EE2 Cordless Phone
Lands Phones Logo
330 people viewed this question
Top Lands Phones Experts
Marvin
Marvin
David Burbee
David Burbee
Are you a Lands Phone Expert? Answer questions, earn points and help others
