Question about IBM ThinkCentre S50 8183 - P4 3 GHz (8183D9U) PC Desktop
System hangs by inserting pen drive
When i inserted the pen drive the system hangs.
  • 2 more comments
  • Anonymous Dec 21, 2008
    my computer hangs when i insert pen drive or try to open its contents mine is p3 256 mb ram comp working with window xp
  • virtuvian Jan 12, 2009
    System hangs by inserting pen drive.I have tested the pen drive in other
    systems the pen drive is perfectly functioning.
    please help
  • Anonymous Mar 05, 2009
    please help
  • Anonymous Mar 12, 2009
    connect pendrive pc hang
When insert pen drive system being hang
Posted on Feb 28, 2009
If you have any antivirus software installed
check disabling it. it works or not.
Arvind.RB....
Posted on Jan 31, 2009
I tried out using the pen drive in other systems it is perfectly alright.
Posted on Jan 21, 2009
I solve this problem
i connect my pen drive my pc is hang
iuse 4 gb pen drive transcend
an i use quickheal antivirus software. with internet sequrity
in a internet sequrity one tab is sequre drive and autorun is enble and disable.
try it...yr problem solve......ashvin
Posted on Sep 07, 2010
DISABLE ANTIVIRUS AND SCAN PENDRIVE
JITENDER SHARMA
Posted on May 14, 2010
Take the hamer and broke the pc tatzzzzzz solve
Posted on May 02, 2009
PC hangs when I insert pen drive solved for me at least
Right click on MyComputer>manage>device manager>
On the right Pane
under the Universal Serial Bus Controllers >
Disable the Intel .... Usb2 Enhanced Host Controller
you must disable usb2 enhanced host controller and plug you pen drive.. see if it works..
I gotta tell something more.. that is in my Gigabyte bios,there is a Usb controller,Usb 2.0 controller,usb keyboard support etc. etc..
and i kept all of them enabled while unintalling the driver..
it worked for me...
solution personally founded by MD. Abrar(Me).. :)
Posted on Sep 08, 2012
    Scholar:
  • 135 Answers
USB drivers ? or a faulty pen drive of usb port...
have you tried plugging it into another computer or another por on the same pc ?
if yes then what are the results ?
you can try removing the USB driver..
what version of windwso do you have ?
Posted on Nov 27, 2008
5 Suggested Answers
SOURCE: system hangs by inserting pen drive
dude u need to reinstall ur windows ..there are othere ways also but im telling the best way .so ur system will remain healthy..
Posted on Apr 16, 2010
vkyhunk
  • 156 Answers
SOURCE: system hang when i insert pen drive
solution..
1) Check The USB Port for Damaged, Bend Or Broken Pins.
2) Check The Pen Drive For Physical Damage.
3) Try The Pen Drive In another USB Port. (i.e. if u r using the pen drive in the FRONT PANEL USB PORT than try it in BACK PANEL USB PORT)
4) Try The Pen Drive In Another System.
5) Tye Another Pen Drive.
6) If All Above Is Fine Then Format The PEN DRIVE.
7) Try The PEN DRIVE now.
8) Is Issue Still Persists Then..
9) Uninstall the CHIPSET/MOTHERBOARD DRIVER COMPLETELY and then clear %temp% & prefetch files and Restart Your System.
10) Install The Latest CHIPSET/MOTHERBOARD DRIVER and ANY AVAILABLE FIRMWARE for the motherboard..
Posted on May 22, 2009
abhi_patil
  • 569 Answers
SOURCE: System hangs by inserting pen drive
does other usb devices work fine on the same system please check if your pen drive is working fine on some other pc/laptop if it is working fine then you have to check with your usb ports.
Posted on Jun 09, 2009
  • 10 Answers
run compatibility wizard and chose that flash drives to run as / chose different settings,
usually caused by older flash drive drivers
check manufacturers web site for compatible drivers/ upgrades
Posted on Feb 11, 2011
System hangs by inserting pen drive.I have tested the pen drive in other systems the pen drive is perfectly functioning. please help
Feb 11, 2011 | IBM ThinkCentre S50 8183 - P4 3 GHz...
When i insert pen drive to my aspire5100, the system is hanged and also not recognise my pen drive
try another brand pen drive this one seems not compatible with your sys
Jan 07, 2011 | Computers & Internet
My both usb ports r not wrking n hangs when eithr card reader or pen drive is inserted bt works well when tata photon usb port or mouse port or key board port is inserted ?model- EMACHINES E275
Sounds like your laptop's USB ports are not capable of providing enough power to operate your card reader or pen drive. I suggest you buy an active USB hub (one with external power source, rather than the one which draws power from the laptop's USB port), & attach your card reader and/or pen drive to that USB hub.
Nov 28, 2010 | Acer Computers & Internet
My 8 GB pen drive is not working. it says USB device not recognised. Help me.
you might have not inserted the pen drive correctly. You should also try to insert the pen drive in some other USB port
Oct 21, 2010 | Computers & Internet
Apr 16, 2010 | IBM ThinkCentre S50 8183 - P4 3 GHz...
Pen drive
It seems FAT system on you pen drive is corrupted. I'd advise you to take your pen drive to some other pc connect it over there and whatever pops-up don't do anything simply go to command prompt and format your pen drive from cmd prompt. If you need further assistance plz do comment back.
Jul 25, 2009 | Lexmark X3350 All-In-One InkJet Printer
My laptop hangs on inserting any pen drive if it is inserted after booting; but if it is inserted before booting my laptop it works properly n without any problem.....
when you insert any pen drive generally it searches for the drivers and do some checking to see if it has to install drivers for the new hardware and it takes time...
Jul 07, 2009 | IBM ThinkCentre S50 8183 - P4 3 GHz...
Jun 09, 2009 | IBM ThinkCentre S50 8183 - P4 3 GHz...
System hang when i insert pen drive
solution..
May 22, 2009 | IBM ThinkCentre S50 8183 - P4 3 GHz...
Moser baer 4 GB pen drive is not working
i have 4gb moserbaer pen drive when i inserted it in to the Xp system it give the message "Insert disk"
plz. solve this problem.
Aug 05, 2008 | Computers & Internet
Computers & Internet Logo
4,364 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
