Question about Lexmark N2050 for X3350 (14T0300) Wireless Adapter
Lexmark N2050 802.11b/g Wireless Network Card
How to install Lexmark N2050 802.11b/g Wireless Network Card
After installing my lexmark 7675 my laptop cannot access the wireless network
Wireless communication issues could be due to wireless signal quality, signal interference, firewall, etc. Make sure your printer is positioned where it receives excellent wireless signal strength (avoid physical obstructions whenever possible) and away from appliances which emit wireless signals (e.g. microwave ovens, cordless telephones, baby monitors, and other wireless electronics) that may cause interference. Make sure to allow full access to all Lexmark software and printer communication processes in the program rules/permissions for your firewall.
You may also refer to these articles from the Lexmark website to identify and rectify this problem:
- Wireless & Network Communication Issues with 2008 Lexmark Inkjet Products
- How to identify a Wireless Communication Problem and Resolution Tips
I hope this helps.
Jan 28, 2012 | Lexmark X7675 AllInOne InkJet Printer
I can't get my Macbook setup to use the Lexmark x6650. I used the install disc and the wifi light on the printer is green, but I still cannot figure out how to setup my Macbook to print to is...
Print the network settings page to identify if your printer is connected to your wireless network:
1. Press Setup on the printer operator panel.
2. Press the right or left arrow button until Network Setup is displayed, press OK.
3. Press OK at Print Setup Page.
4. Press OK when prompted to Load Paper.
5. Press OK. The network settings page will now print.
Check the Network Card Status, SSID, Trouble Code, TCP/IP Address. SSID should be the name of your wireless network. Otherwise, you may need to reset the printer's wireless network settings.
How to reset network settings:
1. Press Setup.
3. Press the right or left arrow button until Reset Network Adapter Defaults is displayed, press OK.
4. Press the right or left arrow button to display Yes, pressOK.
Once the Wi-Fi light turns on to solid orange, run the Lexmark Wireless Setup Assistant on your Mac.
Sep 21, 2011 | Lexmark X6650 4-In-One Wireless InkJet...
Cannot get the wireless connection to work on the printer. The USB cable is connected to the back of the PCU. I've installed and uninstalled twice and nothing. It did work when I first got it and...
Here are some guidelines to identify and fix your wireless communication issue:
  • What is the status of the Wi-Fi light on the printer? Green light means that it's connected to a wireless network while Orange light means it's not connected to a network.
  • Try to print the printer's wireless network settings to determine if it's connected to your own wireless network. On the printer operator panel, touch the Setup button > Network Setup > Print Setup Page. Your printer will then print the its wireless network information page. Ensure that the printer is connected to your network by checking the Network Card Status, Wireless SSID, Quality or Trouble Code.
  • If printer is not connected to your network, you may need to reset your printer's wireless network settings. On the printer operator panel, press Setup button > Network Setup > Reset Network Settings. The Wi-Fi light on the printer will momentarily turn off then back on to solid orange. You can then run the Wireless Setup Utility application on your computer to reconfigure the printer to connect to your wireless network. On your computer, launch the Lexmark Printer Home application > go to Settings tab > Wireless Setup Utility. Please follow the instructions on your computer screen.
If you still need assistance, please contact Lexmark Technical Support Center for additional assistance.
Aug 21, 2011 | Lexmark Pro901 All-In-One Inkjet Printer
Is the Lexmark x5495 wireless? If it is, how do you connect it to a laptop. I lost my installation disk.
The Lexmark X5495 printer is not a wireless printer, however, you have the option to connect it to a wireless print server. You can then connect the wireless print server to your wireless network so all the computers connected to your network will have access to the printer.
To connect the printer to your laptop, please visit the Lexmark website at http://bit.ly/hsBChY to download and install the printer driver. Execute the file and follow the instructions on your computer screen.
Aug 11, 2011 | Lexmark X5495 Printer
How to turn on wifi
Configuring the optional internal wireless print server
If you purchased the optional internal wireless print server after your printer was already set up, follow these steps:
1 Install the internal wireless print server into the printer. For more information, see "Installing an optional internal
wireless print server" in the "Setting up the printer" chapter.
2 Click Start Programs or All Programs Lexmark 3500-4500 Series.
3 Click Wireless Setup.
4 Click Start.
5 Follow the instructions on the computer screen.
6 Click Finish to complete the installation.
Also here is the link to the setup guide and user manual
click here
configuring the wireless is in the setup guide
Oct 18, 2010 | Lexmark X3550 All-In-One Printer
I have a lexmark x4690 wireless printer. I had to change my bell sympatico dsl router. Now I need to change the network on my printer but I can't. I no longer have the driver cd and I tryed downloading...
You will need to reset the printer's wireless network adapter then reconfigure it with your new wireless network settings. On the printer's operator panel, press Setup button > Network Setup > Reset Network Adapter > hit Ok. The Wifi light will momentarily turn off then will turn on orange. Once you have that, run the Lexmark wireless setup utility on your computer to configure the printer with your new wireless network settings. Thanks.
Aug 04, 2010 | Lexmark X4690 Wireless InkJet Printer
I have a lexmark c534n color laser printer that I want to make wireless. There are several products but I dont know which one to get. there is the n2050 wireless network card for 40.00 but I dont know if...
In my travels, I believe the matching brand for this type of architecture makes the best sense and Lexmark would be quicker to support any issues. Best bet is ti go with Lexmark 802.11b Wireless Print Adapter bridge ( 1010042 )
Jul 08, 2009 | Lexmark N2050 for X3350 (14T0300) Wireless...
Lexmark 4800 series reset printer to factory wireless settings
i have a lexmark printer its plugged in but dont have a icon to make it print
Oct 07, 2008 | Office Equipment & Supplies
Can't print wireless anymore - Lexmark X4550
Is the printer a wireless, network, or connected to another computer wired.
Also, be sure that your "workgroup" is still named the same on all computers.
Apr 01, 2008 | Computers & Internet
Lexmark N2050 for X3350 (14T0300) Wireless Adapter Logo
107 people viewed this question
Top Lexmark Computers & Internet Experts
mukhtar21 shaikh
mukhtar21 shaikh
Robert Monigold
Robert Monigold
micky dee
Are you a Lexmark Computer and Internet Expert? Answer questions, earn points and help others
