Question about GoVideo Televison & Video
Doesn't respond to any control - displays "SAFE"
  • mhb3 Nov 26, 2008
    now working fine -- thank you
  • 928 Answers
Unplug the unit for about 10 to 15 mins then plug it back in to reset the unit.
Posted on Nov 26, 2008
Buttons on microwave
testing every step and fix it. God bless you see the diagram attached
Microwave Buttons Don't Work
Touchpad and Control Panel
If the microwave buttons don't work the touchpad and control panel assembly are probably defective.
Touchpad
If the microwave buttons don't work the touchpad might be at fault. Generally speaking, if the dishwasher display is working and some of the buttons respond correctly but some don't, the problem is with the touchpad.
User Control and Display Board
If the microwave buttons don't work the user control and display board are most likely defective and will need to be replaced. If some of the buttons work and some don't, it is more likely a touch pad problem and the touch pad will need to be replaced.
Main Control Board
If the microwave buttons don't work the main control board is most likely defective and will need to be replaced. If some of the buttons work the touch pad is likely the problem. If none of the buttons work the problem may be in the main control board.1_24_2013_5_23_47_pm.gif1_24_2013_5_24_54_pm.jpg
Jan 24, 2013 | Goldstar MV-1501 Microwave Oven
Soyo monitor MT-NI-DYLM1998 "out of range."
Your windows 7 screen resolution is set too high and your display doesn't support it. There are 3 possible solutions to this problem:
1. Press F8 during startup and choose "Enable row-resolution video"
2. Press F8 during startup and choose "Safe mode" and change screen resolution there, then reboot.
3. You can always use another display (if you have one) to set screen resolution to lower value.
Oct 15, 2012 | Soyo Computers & Internet
My usb video device don't work :( .
??? Try out MS Fixit. Use IE (doesn't seem to like Chrome) and use USB in filter. It will provide a USB fixit executable. Let me know if it works out. The site and fixes are fairly new.
http://support.microsoft.com/fixit/
Oct 06, 2012 | Computers & Internet
My R-4A58 unit only displays
The keypad control board will need to be replaced.
Apr 26, 2012 | Sharp Microwave Ovens
HP 4500...when trying to scan, or make a copy, screen displays "Scanner Failure" and will not work. Please help.
The "Scanner Failure" message appears when the scanner unit doesn't responds to the commands from the printer's processor. This is a major hardware failure - the scanner unit is effectively dead.
Replacing the failed scanner unit with a new one would cost more than a new All-in-One so either use the printer as is (just as a simple printer) or sell it for parts and get a new one.
Sep 02, 2011 | HP OfficeJet J4580 All-In-One Laser...
I have a Liebherr No-Frost Premium, with the freezer at the bottom of the unit three years old. I've had a number of problems with the box. The immediate pressing one is that the thermostat seems...
For that problem, the electronics control board and the thermostat must be check. Since the display doesn't follow the control button and it adjust itself automatically without controlling, it's already sure that the control is the problem. Check first thermostat then electronics control board. Be sure that the door are tightly close.
It is a pleasure to advice you.
Jul 09, 2011 | Liebherr SBSes 74S2 Premium NoFrost
I have a 42PC5 LG Plasma, and the problem is that the TV Remote control and Buttons (on the TV) are not working/responding. The only way to close the TV is by plugging out the Electricity Cable, and when...
i think that there is a shorted buttons or in normally close position, try to press each buttons slowly and you will feel something that is ticking if one of the buttons does not tick it is damage it is in normally close position that will be the cause of the problem. specially check the volume button.
Jul 02, 2011 | Televison & Video
--2005 GMC Envoy AC Trouble--(compressor still active) Have replaced blower motor (original one had "burn" evidence), resistor and resistor connector. The blower is still not working. Have...
SOUND LIKE BAD BLOWER MOTOR RESISTOR.CHECK BLOWER MOTOR HI BLOW FUSE AND RELAY.YOU WILL NEED OWNERS MANUAL IN GLOVE COMPARTMENT TO LOCATED BLOWER MOTOR FUSES AND RELAYS.
Jun 06, 2011 | GMC Envoy Cars & Trucks
Hi, My Samsung YP-U3 has been really great up until now. But now, When I put it into my Computer (USB"s), it doesn't show up on "My Computer" (where it show's C, D, Drive etc) only...
Have you tried booting into safe mode and seeing if the problem persists? If it can be detected in safe mode, then there is a possibility your USB drivers are corrupted, and will need a re-install. To do this, remove all USB devices from ports, disable USB in your Start/Settings/Control panel/System, and reboot. Windows will then detect them at boot, and install the drivers needed to get them back up and running again.
Hope that helped.
Cheers from NZ
May 07, 2011 | Samsung YP-U3 MP3 Player
Display shows "Harmony safe mode" and will not respond/turn off
remove one battery. press and hold the #2 while replacing the battery. hold the #2 until you see "upgrade success". press activities and you're back in business.
Mar 07, 2009 | Logitech Harmony 550 Remote Control
Televison & Video Logo
15 people viewed this question
Top GoVideo Televison & Video Experts
Marvin
Marvin
Demonic-2011
Demonic-2011
 Grubhead
Grubhead
Are you a GoVideo Televison and Video Expert? Answer questions, earn points and help others
