Question about Hyundai ImageQuest HP4240 42 in. Plasma Television
30mm. vertical black line on screen.
We are a Childrens Hospice with a 42inch Plasma screen that was donated to us when we opened 2years ago. In the last few months a 30mm. vertical line has appeared on the screen, this line has disappeared on a couple of occasions for about a day but seems now to be there all the time, this screen is the centre piece of our Hospice & is loved by all the children who stay with us.
  • lilysmom96 Dec 31, 2007
    HI my set is about 3 years old and is doing the same thing - one line sometimes two.
Hi I have just fixed this problem on my screen. The fault was a dry solder joint on the driver circuit of the screen. Have a look at my thread here. I have tried to explain it as well as possible. Hope it helps.
Posted on Jan 23, 2007
    Sniper:
  • 79 Answers
  • 4 Answers
Hi
it works
cheers
Posted on Mar 15, 2008
Theres a better picture and howto here http://www.avforums.com/forums/showthread.php?t=462873 look at reply post 11 , youll easily see the 4 parts to solder..Im gonna try again tomorrow now i know where they are
Posted on May 07, 2007
LG plasma 50 inch tv with a fine vertical black line in the center of the screen that runs from the top of the screen to the bottom
Try changing the input device to something you are sure works. Switch off TV manually, switch off power, remove plug and retry after 48 hours. If problem persists, please refer it to a qualified service technician.
Jul 25, 2012 | LG 50PG20 50 in. Plasma HDTV
42inch LG plasma TV
well if you could please give out the model nuumber thank you
Sep 10, 2008 | LG RU-42PZ61 42 in. HD-Ready Plasma...
We have a one yr old panasonic Ciera 42inch recently we started having a blue and pink line appear vertically down the centre of the screen, this lasted a few days and it has now turned into a thick black...
All plasma TVs have boards that control vertical and horizontal output to their respective areas. They are connected to the screen by ribbon cables. If one of these boards fails all together, has a failed chip, a bad connection, or a bad ground somewhere it will result in a black line in the area of that board. A bad ribbon cable connection on the bottom will result in a vertical black bar though the screen. Many times resetting the connection will fix it, if the ribbon cable has been nicked there could be a severed connection. They an sometimes be fixed, but it is a pain. An yes I have done it, but the bar is gone. The same will happen if the chip that outputs to that area opens. The connectors are the first place to look paying close attention to the cable, they are extremely delicate so great care must be taken if you decide to tinker with em, the usually have lift locks that release them.
I hope this will help out in solving the problem ......
Nov 04, 2010 | Panasonic Viera TH-42PX80U Plasma TV
Green vertical line on videocon 42inch plasma tv
Hello Depending how wide the line is their could be two possible causes.
I have two questions for you.
1. How wide is the line.
2. Does it run from top of screen to bottom of screen?
If the line is thin a single strait line then it is possible the PDP has gone Bad (Panel). (Screen). The screen will to be replaced.
If the line is at least 2 or more inches wide then its a buffer board which can be replaced. LG calls this board Hand insert Boards or display driver boards..
Jul 27, 2009 | LG 60PS60 60 in. Plasma HDTV
When tv has been on for 30mins or so we get two vertical black lines appearing off centre screen with lots of multicoloured lines inbetween unwatchable and plasma 42inch is only 4mnths old
your tv should still be under factory warrantey you should take back to place u you bought it may give you a nother one that works ok or help you get this resolved. Donot try to fix yourself or the warrantey will be no good.
Mar 01, 2009 | Samsung TCD1341 TV
Vertical lines on screen
1. Frist on the BURN MODE.
2. Check whether same
Vertical lines on screen ?? 3. If yes ..?
4. Then change the LOGIC BOARD or PDP
Jan 11, 2009 | Hitachi 42HDS69 42 in. Plasma Television
Nec plasma tv 42MP4
these plasma vertical black lines are notorious. there's a video of a fix on this plasma tv repair site. good luck!
Jul 29, 2008 | Samsung PPM42S3 42 in. Plasma Television
Half Screen has colored lines, Half screen is working ok
there is a defected capacitor in the vertical circuit trouble shoot and replace. or if the vertical circuit is separate then replace the whole board.good luck
Jul 11, 2008 | LG 42PX5D 42 in. Plasma HDTV
Red Vertical Line and Black Screen, Sound OK
Check this out
http://forum.eserviceinfo.com/viewtopic.php?t=30810
have a nice day
Oct 08, 2007 | LG RU-42PZ61 42 in. HD-Ready Plasma...
Vertical muliticolor lines
The output freq of the vcr is sitting to close to an rf signal from a digi broadcast i guess,cross modulaion is the term.the rf can be moved away in freq to another bit of band width or if not using rf connection it can be switched off rf output altogether.find online vcr manual and find rf change section
Jan 07, 2018 | JVC PD-42V31 42 in. Plasma Television
Hyundai ImageQuest HP4240 42 in. Plasma Television Logo
1,868 people viewed this question
Top Hyundai Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jay Seifried
Level 1 Expert
Are you a Hyundai Televison and Video Expert? Answer questions, earn points and help others
