Question about Samsung SyncMaster 551 15" CRT Monitor
Color Problem: Samsung CRT 551v (15") The whole screen look more red, never got a pure white. somebody told me using software to adjust the Red Gain & Bias. Anybody can help?
  • 1 more comment
  • rikisurya Dec 10, 2008
    I have RGB problem with my samsung syncmaster 551v. the display showtoo much red collor. what component must i check beside RGB VR(tunner) cause i can't find one.
    can you help me with RGB schematic please.
    thank's for your help
    Riki ST
  • 1newstar Dec 27, 2008
    Akai ct-21w. looks more redish, almost no green
  • rikisurya May 11, 2010
    can i get the schema diagram of the samsung syncmaster 551v collor processing circuit unit ?
    Problem Solver:
  • 7 Answers
This is your display cable problem. So, at first check ur display cable and plug it tightly with AGP card prot/display port. if the problem is still then change the cable . I think it will help u .
Posted on May 02, 2009
    Sniper:
  • 108 Answers
In Monitor CRT Red-Blue-green cathode guns are there.. Mixing of these colour we can get the original colour chrominace technique. if any of the colour gun is faulty we would get more REad or blue or green picture. Measure RGB voltages. you can verfify which gun is faulty. if then check RGB processing circuits. Else there might be problem Chrominance colour decoder system. Contact service centre
Posted on Dec 22, 2007
Hcl crt color 15" digital monitor.red color is
Unfortunately, this is not a fixable problem. Samsung CRT monitors are well known for losing color; they have defective cathode ray tubes. I recommend that you buy an lcd screen. sorry if that wasn't what you wanted to hear! don't forget to rate
Jan 13, 2011 | Samsung SyncMaster 753 DFX 17" CRT Monitor
The picture of my Funai 28D-3728 TV is a bit over colored in red. The color balance is correct (I mean no specific zones of screen where this effect is realized (e.g in the corners or in the center)) but...
This is not user adjustable.
The problem is in the R G B circuit. Thr Red gun circuit is totally on!
If this is transistor driven circuit replace the transistor. The component
mostly mounted on the small PCB on the picture tube neck.
Sep 04, 2010 | Funai CR202TT9 20" TV
Hitachi RP CRT Gone Red On All Inputs!!!
I want you to do a simple visual check of something that will tell me what the problem may be.
Go to a channel that is in black and white--old movie and tell me what color the screen/picture is.
You can also turn the COLOR in the customer menu all the way off and look that way.
What we are trying to see here is if TRACKING is set correctly or has changed. If the screen is somewhat to medium reddish it may be an adjustment outside of the customer menu.
Let me know what you find--I have seen several of these where the black and white picture was somewhat red--the idea is it should be as close to black and white as possible--if red is the predominant background color the picture will look reddish.
If this has helped and you confirm the red instead of black and white picture--I can tell you a easy way to adjust this.
If this information told you something you did not know and helps you rate this solution as I do this here for free.
SD TECH
Dec 23, 2009 | Hitachi 57F710 TV
VGA connector wiring detail
Pink - red input - pin 1 green - green input - pin 2 blue - blue input - pin 3 ground shield wire - pin 6,7,8 and 10 black - ddc 5v - pin 9 violet - screen raster - pin 11 white - data or sda - pin 12 orange - clock or scl - pin 15 yellow - vertical signal - pin 14 clear - horizontal signal - pin 13
Sep 11, 2009 | Samsung SyncMaster 753S 17" CRT Monitor
Samsung Syncmaster 551V Display is too wide
You can adjust the monitor picture size settings & position from the menu button on your monitor.
Apr 23, 2009 | SAMTRON 55V 15" CRT Monitor
Schema diagram samsung syncmaster 551v
Hi and welcome to FixYa,
Initially, pls try here.
Good luck and Thank you for using FixYa. Happy Holidays.
Dec 10, 2008 | Samsung SyncMaster 551 15" CRT Monitor
Red color problem
As you are not able to see red color on your monitor means you will be seeing green+blue=cyan color your problem is that red signal is not coming to red cathode of your crt. please check 1 connector loose(cpu to monitor) 2 crt base loose. 3 loose or print or dry near red cathode circuit 4 red video output. 5 red signal from processor to red video is missing 6 processor ic. good luck
Sep 27, 2007 | SAMTRON 55V 15" CRT Monitor
Screen
What you may have needed to do was adjust the green & blue crt screens to match the red. Go into your picture menu adjust, turn color all the way down to a black & white px. Now adjust each crt screen so that you end up with a true black & white px. Then adjust each focus control to get a sharp px, have your tv on a channel like the home shopping network so you can adjust each crt focus one at a time for clarity by cover the other 2 up. Then go back into picure adjust & turn color ahlf way up, you should see a better px.
Jul 01, 2007 | Philips 60P8341 60" Rear Projection...
15 pin VGA connector damaged.
i want to know that what is the color combination of vaga cable connector
Aug 28, 2006 | SAMTRON 55V 15" CRT Monitor
Redless screen
If still under warranty or if you have no electronic repair experience you should take the set back to the shop or to a repair person. Some of the solutions described below can be dangerous, TV's and CRT monitors are very hazardous to service. Even when plugged out, they can store very high, deadly voltages. How old is the picture tube? If there's lots of phosphor burn on it, chances are the red gun inside the picture tube is out. A sure-fire way requires an oscilloscope. Check the voltages on the three color guns at their corresponding pins on the CRT's neck board. You can see their levels change as you tweak their adjustment pots on the neck board. If the red voltage is present and at the same levels as green and blue, then the gun inside the tube is shot. If the red voltage is NOT there, then you can work backwards and find out where you're losing it. It could be a bad buffer amplifier (transistor or I.C.), bad solder joint, or even a broken wire in the cable harness. check for cracked solder joints where the RGB, Grd Sync connector is. check the pins on the molex power supply connector, could be that the pin for the red is pushed back and is not making contact. Try swapping the red and green inputs if you see red on your monitor and no green, then it is NOT the tube. If you see no red still but still get a green where red should be I would suspect a bad chassis.
May 28, 2006 | Samsung SyncMaster 551 15" CRT Monitor
Samsung SyncMaster 551 15" CRT Monitor Logo
354 people viewed this question
Top Samsung Computers & Internet Experts
asber
270rexton
270rexton
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
