Laptop wont turn back on after plugging it direct without an adapter
    Scholar:
  • 174 Answers
Its the motherboard not the ac adapter nor the battery.Get your motherboard replaced.
Posted on Nov 26, 2008
My toshiba CB35-A3120 chromebook just turned off,and now won't power back on.Tried a extra power adapter,nothing.
remove your battery and power from it for half an hour then plug just the chromebook power cord back in and see if it turns on without the battery in. if it does then unplug put battery in then plug power back in and try to turn it on again if it doesn't come up with the battery plugged in with the power plugged in you may need a new battery. the chromebook should run good without the battery but you wont be able to use it when you have no power around.
Mar 18, 2015 | Toshiba Computers & Internet
It wont charge therefore wont turn on if you can help me please do or give me an estimate price to fix it
Im very sorry to hear that, please follow these simple steps for you to be able to isolate the exact problem.
1. Removed the battery.
2. Connect the laptop directly to the power outlet without using the battery just for the meantime.
3. Turn on the laptop. If the laptop is able to power on, that means that the AC adapter is working fine as well as the DC port. If the laptop is not able to turn on, it maybe the AC adapter itself or the DC port.
4. Try to use another AC adapter if possible, make sure that that AC adapter is working fine. If the laptop is still not turning on, the problem is with the DC port itself. In that case, you will need to replaced the Motherboard itself.
Hope this will help...Thank you for using Fixya...
Sep 14, 2011 | Gateway M-6319 Notebook
It just wont turn on i have checked the power lead and its ok its an acer aspire 5050 laptop
Hi. I would suggest you double check the ac adapter if the powercord is properly attach to it ot also you might want to try powerdraining or powercycling your computer. To do this you must turn off your laptop then remove the battery and unplug the ac adapter then press and hold the power button for 20 seconds while the battery and ac adapter is out, after that place back the battery and plugin the ac adapter and try turning on your laptop, if this doesnt work then try power draining it again and just use the ac adapter or just plug it in without the battery then try again turning it on. If it still has the power issue then try a known good ac adapter so that you could double check that it is not an ac adapter issue or a battery issue. If all that trouble shooting step doesnt work then you could also try calling acer tech support to help you on your issue if your machine or laptop is still under warranty they would help you fix it by sending that laptop to there depot without any charge. Hope this Helps
Jun 09, 2010 | Acer Aspire 5050-3242 Notebook
It won't turn on
Hi. Try theses simple steps:
Remove the Battery
Remove the AC Adapter
Press/hold down power button for 10 seconds
Plug AC Adapter in and turn the computer on
If the system doesn't turn on still then there's a problem with your motherboard. and it might need replacement.
Jun 06, 2010 | IBM ThinkPad T40 2373 Notebook
I left my laptop turned on in my office when i came back then next morning it wont start even if I push the power button. The laptop was turned on when i left it.
Try to perform power drain. Take out the battery and unplug the power adapter. Press and hold the power button for 30secs. Put the battery back in then plugin the power adapter then trn on the computer. You can also power on the computer without the battery. If your computer wont turn just using the power adapter then there is a possiblility that there is a problem with your power adapter.
May 19, 2010 | Computers & Internet
My lonovo laptop won't charge. how do i fix it?
if ti works with the adapter plugged but the battery do not charge to work without adapter ..than the battery is dead and you need to replace it ..If it do not work without battery and just with the adapter ..it means tha adapter has an issue and try to check the plug ..the cable and the adapter itself..before buying another verify at the store with the laptop to see if the adapter is to blame ...and not the plug into the computer ..so you do not end up with 2 working adapters ..and still no charge ...If it is the plug itself ..then you have to change it ...you can get a spare part on the ebay..or just go to a repair shop ..cause they are pretty universal ...
May 12, 2010 | Lenovo Ideapad U350 Laptop Notebook
My mom can not turn on here laptop
Hi:
You might want to resubmit your problem, with more details, but some general things to check are:
1) Is the laptop battery charged, or is the laptop plugged in ?
2) Remove the battery, unplug the AC Adapter, then hold the power switch down for 10 seconds, then put the battery back in , connect the AC Adapter and see if it turns on
3) Remove the battery, unplug AC adapter, hold power button down for 10 seconds, and then plug in the AC adapter, see if it turns on.
If all of the above fails to help, You most likely need to take the laptop into a shop for further troubleshooting.
Oct 30, 2009 | Computers & Internet
E machine 510 wont charge!
Yes, remove the battery from the laptop.
Plug-in power adapter and turn ON laptop (without battery).
After the laptop starts up and Windows has settled, put battery back in the laptop.
Allow to charge for a few hours.
Oct 07, 2009 | E-Machines eMachines Desktop PC
Its just shut down and wont turn on. It has been working fine.
If you have connected your power adapter directly (without a power strip) to another outlet that works, and still doesn't power on, these are generally the reasons:
1. Power adapter is faulty - replace
2. Battery is faulty - replace (try without battery)
3. Power jack on laptop is faulty - repair
Hope this helps to at least narrow down and help you troubleshoot your problem.
Aug 23, 2009 | HP Compaq Presario V2000 Notebook
Help needed to get power connected.
There are a few possibilities.
If it's been plugged in continuously, the adapter may have simply overheated. Allowing it a few minutes to cool down without being plugged in could possibly fix it. Try unplugging the power cable from both the wall and the laptop for 30 minutes and give it another shot. This might work.
The other, less happy, possibility is that your adapter overheated to a critical point or was struck by an electrical surge and is damaged beyond repair. You can order a new one from a site like eBay or directly from Toshiba. Looks like you could get one from eBay for around 25$US incl. shipping but be careful and make sure you order the right thing.
Some eBay results: http://search.ebay.com/search/search.dll?from=R40&_trksid=m37&satitle=ac+adapter+portege
Mar 13, 2008 | Computers & Internet
Computers & Internet Logo
42 people viewed this question
David Payne
David Payne
