Question about Bosch 24 in. SHU53 Built-in Dishwasher
Bosch Dishwasher Problem
I have the same problem you did (Dishwasher counting down to 1 and never finishing, going back to 13 upon off/on). Where did you get the board and where did you find instructions on replacing it?
Thank you!
Adi
  • vobriant Dec 01, 2008
    We have EXACTLY the same problem and it just started a few days ago! Our model is SHU5304 UC/U06 and we've had it since 1999. We're considering replacement of the electronics control box inside the door but before we spend $100 ++ for it we'd like to know it will fix the problem.
  • ap1964 Jan 03, 2009
    We have a 10 year old SHU5312 that has continued to clean well, but will stay on for far more than the typical 2 hour cycle, with the timer at 1 minute. It sounds like a variation of your problem and should be evaluated for control module replacement?
  • 42 Answers
If you remove the front panel (the 6 torx screws) and the facia panel you can access the control module. remove the module and open it up to see if you have a burn mark from the solder melting. if you do then you know to replace the control module
Posted on Dec 21, 2008
My bosch dishwasher counts down to 1 minute on any cycle but will not drain except by manually hitting cancel. I've replaced a defective drain pump but it still does this- any ideas?
The pressure chamber or hose (pressure chamber to sump) may be blocked and the microswitch is being activated because the water is not entering the tank quick enough. Isolate from electric, remove lid and left panel (looking from the front). There is a plastic chamber bottom right of left side with two microswitches, either this is blocked or the hose that runs from it to the right and along the back of the kick panel and into the sump. Clear either or both (make sure all hoses are pushed true when repositioning).
Apr 18, 2013 | Bosch Dishwashers
Bosch dishwasher error code c1
Hi
Pump-out not accomplished in normal time.
Check the drainage and replace or reposition the drain hose,Clean it out by running the disposer.
Feb 27, 2012 | Bosch Dishwashers
When the washer gets to 1 in the cycle, it doesn't stop washing.
try running the test cycle or running delicate economy in that cycle it gets up to 150 degrees in the very first cycle let it run 15 or 20 min see if the water is screaming hot it is not and Luke warm it is not heating it is most likely a control board heaters very rarely go out
Jul 24, 2009 | Bosch SHU5316UC Dishwasher
Bosch SHU4312 won't finish cycle, won't drain.
The control board on these units is prone to a cold solder joint cracking. I have read that Bosch recommends replacement and will supply the board, not covering labor. I repaired mine prior and have done one for a friend as well. Has lasted several years and counting
The symptom is constant cycling without ticking down the last few minutes
Jun 04, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
My Bosch dishwasher won't shut off. The timer says "1" forever and when you open it there is about an inch of SOAPY water still there.If you press start it goes to "13" and again counts down to "1" and...
Bosch SHE44C06UC
The dishwasher continues to run...I followed instructions and performed the diagnostic...the light above the quick wash was solid, the light above the rinse/hold was flashing...the code displayed in the cycle countdown window was P0...now assuming the machins isn't "pissed-off"..can you help-
Feb 28, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
Electronic controls don't count down properly
you have to replaced the main control resoldering wont fix it because the relay itself has gone bad replacing the board will solve the problem
Nov 20, 2007 | Bosch SHU5315UC Dishwasher
Your problem is the electronic control board and unfortant that you cant repair or even get parts for it . Only if you get the whole control board will you fix your problem assy unless you find a good appliance man that repairs electronic control boards
Apr 14, 2006 | Bosch SHU5316UC Dishwasher
Bosch 24 in. SHU53 Built-in Dishwasher Logo
317 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
