Question about Motorola Mobility V600
Motorolla v600 the bluetooth would not power on everytime i select bluetooth it says connection failed. what can i do ches
0 characters
1 Points
I cannot pair my motorolla bluetooth with my LG VX9200
This has worked for 99% of bluetooths . Turn off bluetooth complety.Go to search for devices menu on your phone but dont search yet.. Press and HOLD the power button on the bluetooth do not let it go. when the bluetooth starts blinking (some will blink blue some red some both) When it starts blinking keep holding power button(on bluetooth) while doing this then do search for devices on your phone when should see it pop up. when you go to pair therm it will ask for password most are default 0000.
Dec 14, 2010 | LG enV3 VX9200 Cell Phone
My LG Shine KE970 can not find Motorolla H700 bluetooth headset
Is the question really, is your H700 in pair mode? To set this you need to push and hold the big talk button while the boom is closed. once the purple light comes on open the boom to keep the light. Now you can search for it with your cell phone.
Hope this helps and don't forget to rate :)
Dec 10, 2008 | LG Shine KE970 Cellular Phone
Bluetooth not powering up
Try this ::
1. Create a link between your Motorola RAZR Phone and any Bluetooth Accessory 1.0 and up, you need to turn the Bluetooth connection "on". This is how: Go into your phone "settings". > Then select "Connection" > "Bluetooth Link" > "Set Up" > "Power" > "On". The connection will stay on until you turn it off. We recommend to turn it off when not in use to preserve battery life. 2. To connect your RAZR to another Bluetooth hands free kit or headset, go into "Settings" > "Connection" > "Bluetooth Link" > "Handsfree" > (Look for Device). You phone will scan for available devices located within the range of the RAZR, approx 30 feet away. If your cell phone is already connected to a Blue Tooth headset, you must disconnect from it to find other devices. Once you have identified your bluetooth device, highlight its name and click on the "select" button.
3. The Bluetooth device will ask permission to connect. Select "yes" and press the "select" button; after that you will be prompted to insert a PIN code to initiate a secure connection. The PIN code is sually provided by the Bluetooth device manufacturer, not the RAZR. Once the connection is made, you should see the bluetooth logo displayed on the internal screen, while the external screen Bluetooth indicator will flash.
Nov 24, 2008 | Motorola Mobility RAZR V3i Cellular Phone
Samsung a920
on your a920
press the menu button,
scroll down and select settings,
press 8,
press 1,
select on,
select 2,
select always visible,
press the back key twice,
which will bring you to the menu
select tools,
press 1,
Note: make sure that your motorolla h500's bluetooth is active and visible to other bluetooth devices
then select add new.
GOOD LUCK!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Jul 07, 2008 | Samsung MM-A920 Cellular Phone
I recently had to get another Motorola V3a through alltel and on my new phone I am not able to use ringtones that I recieved via Bluetooth. On my old one, I was able to. The ringtones do download, but the...
download motorolla conection program then P2K commander connect your phone to the motorolla program then start the auto start on the P2K then open the P2K commander select the p2k phone system and re read find audio and change the attributes on the blue toothed sounds so that they mach the factory sounds then they will work you can also use this to delete unwanted animations and sounds to free up space on your phone and fyi Altell did this to force you to buy ringtones there sales rep confirmed this
Apr 28, 2008 | Cell Phones
V3i as modem
yep simply attach the cable start your motorola ponetools and tada you are done
Nov 18, 2007 | Motorola Mobility RAZR V3i Cellular Phone
Bluetooth problem
I have a motorizr z3 that I purchased a week ago. I cannot get the blue tooth to turn on. I ONCE got my Plantronics bluetooth synced but it would never turn on again, so I deleted it off, and now everytime I try and turn bluetooth on, I get a message of "Bluetooth Power Failed - try again later". It tells me the same thing when I try Setup or Find Me...any ideas how to get this to work?
Oct 13, 2007 | Motorola Cell Phones
maybe you have defective power switch (tact switch) or lost connection in the battery terminal. or u have defective power IC.
Sep 10, 2007 | Motorola Mobility V600
Motorola Mobility V600 Logo
21 people viewed this question
Top Motorola Mobility Cell Phones Experts
D. E. Hev
Chris Hunt
Lawrence Oravetz
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
