Question about Western Digital Passport WDXML800UE (WDXML800UETE) 80 GB Hard Drive
I have just bought a WD external hard drive (250GB). i plug it in via USB (2.0) and my computer will not auto install the device. i have no software with the product. help!
  • amith_tpmado Dec 07, 2008
    1. usb not recognized one of the usb devices attached to the computer malfunctioned, and windows does not recognizeit.
  • Edward easley
    Edward easley May 11, 2010
    Hello. I would be glad to help. Do you hear the characteristic tone that happens when you plug a usb device into the computer?
  • 32,281 Answers
If you are running Windows ME, or Windows 2000, or Windows NT, or Windows XP or Windows Vista you do not need any drivers, Windows will detect any USB devices provided the USB device does not draw more power that the USB port can provide.
Your Maxtor external drive shoud have a power adapter connected to it before you insert it into the USB port.
If the Maxtor drive has not been partitioned and formated then you cannot use or see it until you do so.
Your manual should give you instructions to do so.
Basically you need to go into the Control Panel, then Administrative Tools, Then Computer Management, then Disk Management to create a partition and format the drive in NTFS file format if you are using Windows NT, XP or Vista.
Posted on Nov 27, 2008
I have a Verbatim portable hard drive model #JH8916 that has a capacity of 250GB that seems to be malfunctioning and isn't recognized when the USB cable is plugged into my computer, an HP tower. I...
This is a common problem with external drives, I have had it happen to Segate, WD, and a few off brand drives. Usually when one of these drives gets flaky, you have 2 options:
1. do a google search on your particular model on how to remove the drive from the case, then install in a desktop computer
2. use disk recovery software to attempt retrieval of files
The first on will work if there is a problem with the driver interface to usb board that is built into your device. By installing in a desktop, you are bypassing this potentially bad part. This step will also make the 2nd option run faster if you have to resort to it.
A good rule of thumb on these devices is to never have only 1 copy of the data.
Good luck retrieving your data!
John Vickers
Aug 12, 2011 | SimpleTech SimpleDrive Portable USB 2.0...
My computer says "USB device not recognized" when
You are likely missing the drivers. If you really need to get it open, plug it in, find the drive, right click and select explore. This MIGHT work; i'm not entirely sure.
Feb 09, 2011 | Western Digital WD Passport 250GB Portable...
Hello I am having problems with the auto synch on my WD 3200XMS-00. I am able to save data via cut or copy and paste but will not back up my whole computer. I just bought it and I dont want to return it Is...
-the first you plugged-in the external drive, it should have installed the built-in software that came with the drive.
-if it did, you may need to uninstall and reinstall the software that came with it.
Dec 18, 2010 | Western Digital Passport 320GB External...
Do I need a disc to install
This is a external hard drive and no need for you to install any software to a computer in order for it to work , this is a plug and play device you just need to wait for the computer to recognize it after you plug it to a USB port and once its recognize its ready to use.
Jun 11, 2010 | Western Digital WD Passport 250GB Portable...
When I plug it into my USB on my pc the device gets power but isn't regonized by my computer. I'm running XP
Did you install the software that came with the drive? Set a password for it? If so, you need to access the wd SOFTWARE and type in your password and the files should appear
Feb 10, 2010 | Western Digital WD Passport 250GB Portable...
I cannot retrieve my files from the wd 250gb
First instinct is that your drive has failed. I would remove the drive and insert it into a system to test. If it works, then it is the housing from the external drive that failed. If the drive does not work once inside your system, then the drive is bad. Good luck.
Jun 04, 2009 | Western Digital 250GB MyBook External USB...
Windows XP will not recognize my WD 250GB Harddrive
Just plug your USB HDD directly into your MBoard's USB port...
Feb 09, 2009 | Western Digital 250GB MyBook External USB...
WD Passport 250GB External cannot be recognized.
Go to BIOS (Press DEL or F2 to enter BIOS). Check if the Power state is in S1. Ensure that USB setting is in Hi-Speed.
Restart the computer and try using the device. this should fix. Let us know the result.
Thanx
Jan 16, 2009 | Western Digital Passport WDXML800UE...
Maxtor OneTouch 4 Mini 250GB External Drive Does not show up on my computer
Are you connecting Drive via a USB hub or direct into two separate USB sockets on PC?
May 05, 2008 | Maxtor OneTouch 4 Mini 160GB External USB...
Western Digital Passport WDXML800UE (WDXML800UETE) 80 GB Hard Drive Logo
147 people viewed this question
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Marcin
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
