Question about Hobart A200 Stand Mixer
Planetary Cover removal
Hey bigg t, I need to get a new planetary drive shaft in my mixer, but i need to get the old one out. Whats the best way to get the cast iron cover off other than brute force and a pry bar? I like my mixer. thanks for your time, SR
Using flat screwdriver, remove upper main shaft cover screws (3 of them) to expose shaft nut. Using 3/4" wrench, remove nut and washer on top of main shaft. Using 9/16" wrench, remove double nuts and washers on both small shafts (the double bearing-retainer plate can stay screwed on). Using flat screwdriver, carefully pry stainless drip ring from lower housing (it's just press-fit). Using 3/4" wrench, remove acorn nut and locknut from bottom of main shaft (hold on to the housing, it's gonna drop down and it's HEAVY). Using flat screwdriver, remove cast iron cover hold-down screws (4). Place wood block over end of main shaft bottom to protect threads, and tap upward with a hammer. Don't go crazy with hammer, top housing could go flying. It may take several taps (it's on tight). Increase force slowly so as to minimize chance of damage. Prying out the two press caps from upper housing with a flat screwdriver will give you a place to stick your fingers to lift cover off once it's tapped loose.That'll get the top housing off. But planetary shaft isn't coming out without complete transmission dis-assembly. Better get a book, or better still, hire a pro. Just be careful with Hobart factory repairmen. I've had a VERY bad experience with a VERY highly-paid factory tech. You may have better luck than me, but I'd ask around at a few restaurants and search the 'net for an independant repairman. They tend to work harder for less money than factory guys, and take more pride in their work. Hope this helps!
Posted on Nov 28, 2008
I have a kitchen aid mixer moder KP26M1XLC, the planatary keeps falling off the mixer housing. Any suggestions on how to repair
You are going to need to remove the top housing and look inside, there is a circlip on the main planetary shaft that retains the planetary and mixer shaft assembly. You may get away with a new circlip but if the groove that engages the circlip is damaged you'll probably need to fit a new planetary as well.
Nov 24, 2017 | Food Mixers
I have a Hobart Kitchenaid K45SS mixer and want to know how to remove the agitator shaft from the planetary so I can paint the planetary.
To do this, the whole planetary news to be removed. Use a light hammer and 5/32" pin punch to drive out the pin holding the planetary in place. Then use two flat-blade screwdrivers placed on opposite spots under the planetary and push down on the screwdriver's handles. This will force the planetary up and off the central drive shaft.
Now you can remove the agitator drive shaft which is held on (depending upon the age of your mixer) by a screw or ring atop the gear at the end of the shaft.
Re-assembly is the reverse process. Be careful to line up the pin''s hole in the planetary with that in the drive shaft so that the pin can be driven back in place.
The Service Manual can be downloaded from:
http://www.kitchenaidparts.eu/documents/pdf/service-manual/classic-svc-manual-new-email-version.pdf
Jun 07, 2017 | KitchenAid Food Mixers
How do I reattach a planetary that was pulled off?
I haven't seen enough of that model to remember, look up a local service agent and ask them is probably your best option. Whoever does the warranty repairs for Kitchen Aid would be the best person.
Dec 18, 2015 | KitchenAid KP2671 Professional 6 Series...
Planetary assembly low and beater not locking
Edward, it sounds like your planetary is starting to separate.Where the center shaft connects to the planetary commonly separates, the pieces are machine pressed together, and can separate, usually your beater, and planetary plate will just fall off into the mixer, while the center shaft stays up inside the mixer with the gears on it.
What you will need to do is buy a new planetary assembly, you do also have the option to have it pressed back together by a machinist, but it is usually cheaper just to buy a new planetary. According to your model number you have a Onyx Black mixer, here is a link to the replacement planetary on our website: http://www.mendingshed.com/9708176.html
That should solve your problem, also here is a link to the service manual in case you need any help taking the mixer apart: http://ep.yimg.com/ty/cdn/mendingshed/kitchenaid6qtservicemanual.pdf
And of course, if you need any help you can call us and speak with a KitchenAid technician over the phone
Thank you,
Colleen
Customer Service
MendingShed.com
Feb 25, 2014 | KitchenAid Food Mixers
Drive Shaft stopped kneading dough
To give the mixer strength it has planetary gears. Something may be wrong in the gear section
Nov 26, 2013 | Bosch 800-watt Universal Plus Mixer with...
The planetary pan has dropped about 1/2" and I can see the gears.
You need a new planetary. It's that simple, the new post 2002 design for the Epicurean the Accolaid, the Pro and Professional series mixers the planetary is held on by a grooved center pin that is simply pressed onto the planetary cup, when this shaft begins to drop you need a new planetary with new center shaft it is the only KA recognized fix, there is another but you need to have a drill press and be handy at making a jig. It is frankly more effort than buying a new planetary. if the machine is generally run down and you don't want to fix it you can probably sell it for parts, I know that I would be interested, but the machine is a good mixer and a planetary is like $30.00 bucks and takes about a half hour and some paper towels to change out. Easily performed by a DIY'er. Let ud know if this helped.
Mar 25, 2013 | KitchenAid KT2651X Epicurean Stand Mixer
Hobart a200 will run just fine without anything in the bowl, once I pour my ingredients into the bowl, it wouldn't even mix the ingredients. Try all 3 gears.
Short answer: something is worn/broken inside the mixer's transmission.
Longer answer:
Since none of the three gears operate, the problem is most likely on either the worm gear shaft (probably the brass worm gear itself) or the "transmission shaft" (ironic name as all three shafts could be called transmission shafts). If you're up to the task of disassembling the transmission, which is a very messy task, you'd probably find the problem on one of the two smaller shafts inside the transmission. You'll most likely find either a broken key or worn brass worm gear. Both of these items may have enough holding strength to operate under very light loads (such as an empty bowl) but slip once a load is presented.
Also check the planetary key. Remove the planetary by removing two nuts on the underside of the transmission, where the attachments attach (careful, as the whole thing will drop once the second, thin nut is removed). You will find a long key on the shaft (or in the planetary gear, whichever one it sticks to). Make sure it's not broken, and re-attach the planetary.
Aug 12, 2010 | Hobart A200 Stand Mixer
Older A200 Reessembly
just did mine a200f. try this, if all gears are in line place bearing cap back on planitary this is the cap on top. this should hold bearing in check from moving up and down. if this works for you remember not to over tigthen bottom jam nut, lower end should move freely. post to let me know if this solves your problem. Harry Ooooooooo
Jan 13, 2009 | Hobart A200 Stand Mixer
Hobart N50 / KitchenAid Model G: how do i remove planetary?
you need to remove all the back screws then if it doesnt come tap it with arubber mallet it may be seized on
Nov 19, 2008 | Hobart N50 Stand Mixer
Gear problem
Sounds like a sheared key,explain your problem a little more i work for hobart.
Jul 26, 2008 | Hobart A200 Stand Mixer
Hobart A200 Stand Mixer Logo
145 people viewed this question
Top Hobart Food Mixers Experts
Ross Keen
John Tripp
John Tripp
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Hobart Food Mixer Expert? Answer questions, earn points and help others
