Question about Whirlpool GD5SHAX Side by Side Refrigerator
Evaporation tube freezes
My Problems with Whirlpool GD5SHAX Side by Side Refrigerator is that the tube running through the freezer to the defrost evaporation tray freezes and water runs into the bottom of the freezer and freezes. On the next defrost cycle water runs through the seal onto the floor.
    Sergeant:
    Champion:
  • 291 Answers
Shape the hose under frig like a J-trap and it will quit sucking air up it and it wont freeze
Posted on Nov 26, 2008
MY REFRIGERATOR CONSTANTLY RUNS BUT FREEZER DOES NOT FREEZE AND FRIDGE DOES NOT GET COLD. ONLY A LITTLE COLD AIR BLOWS FROM INSIDE OF FREEZER BUT NOT COLD ENOUGH. FRIDGE MOTOR JUST KEEPS RUNNING AND
Can you tell me if there is a layer of frost covering the back panel inside the back of the freezer? Here is a photo of a panel that has frost building because of a defrost problem HERE
Here is a GD5NHAXMB00Parts Manual go to page 16 and item number 6 is the 2303804 User Control and Display Board
The board could be the problem causing defrost failure or the W10135091 Electronic Control Board
Sometimes these boards will have burn marks or signs of heat damage but not always. Can you unplug the refrigerator and examine the above board first? It can be found on page 17 and item number 18 Once you have done this and see no problems we will examine the defrost heater 2323198 Defrost Heater
I am here to help you resolve this problem so please respond Thanks Sea Breeze
Mar 29, 2013 | Whirlpool GD5SHAX Side by Side...
Hi my freezer is freezing intermittently. For example, it will freeze the ice cream and then the next day the ice crease is soft. it may go two days working fine and then back to the same problem again...
Hi, The defrost timer is sticking on sometimes...replace it..
Check out these tips...they can help you figure out what is going wrong withyour refrigerator
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Sep 09, 2011 | Whirlpool GD5SHAX Side by Side...
NO COLD IN THE REFREGERATOR SIDE
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Oct 19, 2010 | Whirlpool GD5SHAX Side by Side...
Drain tube freezing up
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
heatman101
Oct 07, 2010 | Whirlpool (ET8FTEXSQ) Top Freezer...
Refrigerator side is not cooling anymore.
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
heatman101
Jul 19, 2010 | Whirlpool GD5SHAX Side by Side...
Food freezes in the refrigator
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
May 20, 2010 | Whirlpool GD5SHAX Side by Side...
My Whirlpool Refrigarator isnt cooling or freezing. Its running but there is no cool air on either side. Ive adjusted the temperature control to the coldest setting but still nothing...what could the...
Pull the lower front panel off. Inside you'll see a round small timer with a screw slot in it. Turn the screw slot slowly to the right (clockwise) only, until you hear a slight click. Wait five minutes and feel the walls of the freezer, they should be getting cold by now. If so, you need a new defrost timer. Thank you, Dana
Mar 26, 2010 | Whirlpool GD5SHAX Side by Side...
Ice maker is freezing up
The solenoid valve can leak slightly to make your problem. To check it, undo the tube from the solenoid to the freezer with the solenoid unplugged, and the water pressure on. Any leakage is bad, replace it.
Sep 04, 2008 | Whirlpool GD5SHAX Side by Side...
Kitchenaid refrigerator/freezer
SORRY, YOU NEED A TECHI. THERE. EITHER YOUR TH/STAT IS STICKING OR THERE IS AN ISSUE WITH YOUR AUTO DEFROST UNIT. ALL THINGS TOLD CHECK THAT THE FREEZER OR EVAPORATOR FAN IS RUNNING. IF NOT IT COULD ALSO CAUSE PROBLEMS.
May 21, 2007 | Whirlpool GD5SHAX Side by Side...
Whirlpool GD5SHAX Side by Side Refrigerator Logo
203 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
