Question about Dell Dimension 5150 (DIM515MIN) PC Desktop
DVD tray automatically opens and closes
I have a Dell 5150 and the lower DVD tray keeps opening and closing (constantly) without either electronic or manual instruction. It only happens after the CPU has been on for 4 plus hours (or so). It's driving me nuts. It stops (for a while) when I switch off and re-boot.
  • Anonymous Nov 27, 2008
    I have the exact same problem with my Dimension 5150 desktop (DVD tray keeps open and close constantly.
    If you have a solution on how to fix this I would be greatly appreciate for the tips.
    Regards,
    Hung
  • Daniel Brooks May 11, 2010
    Please add me to MSN @ daniel.brooks@live.com so I may gather more information and help you further, thanks.
    Daniel
  • 13 Answers
Is the drive reading disc properly? if no then just change the drive.
If it can read disc then
1) Do an msconfig & disable startup - just to make sure that there are no pesky script or applcation doing it.
2) change the SATA port on motherboard or toogle between master & slave if IDE cable is been used.
Still if its not working then just change the drive.
Posted on Nov 27, 2008
Close dvd drive
Most DVD/CD drive are belt engaged driven by a small motor. If the tray is not sliding in and out by itself, it is highly probable that the belt is cut and therefore of course would require replacement. In some instances, it could be the small motor itself or the servo electronics that control it. There are also known instances when the tray is misaligned or the plastic rail/gear underneath have been worn out.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
May 19, 2008 | Dell (0F027) CD-RW/DVD-ROM (Combo) Burner
The disktray automaticly opens and closed several times. When I put a cd in de tray the tray closed and opend without playing
Hi, when a disk tray automatically opens and closed several time, might be from the disk tray itself is jambed that's why it opening and closes by itself. You can open up the player and check if any thing in hooking it.
Also it might need to be replaced, the wheels inside the DVD player might be too weak to move in and out without moving automatically.
The way i see it, you might end up replacing the disk tray with a new one..
Have a nice day.
Feb 18, 2011 | Audio Players & Recorders
My DVD tray on my Yamaha DV C6480 (it holds 5 DVDs) got stuck in the half open half closed position. It may have come off the track. I opened the case and reinstalled the DVD Tray. Now the tray...
This happens to us all the time. Here is the note I keep on how to fix it quickly:
When tray gets messed up, the drive wheel (with pegs that interlock with pegs on the tray) needs to be such that the tray slides in and out freely. Push tray all the way in. Turn on.
Hope that gives a hint.
Nov 04, 2010 | Yamaha DV-C6480 Multi-disc DVD Player
DVD drawer won't stay closed
the open button could be shorted meaning the unit is constantly being told to open its tray i think its worth having looked at and i think your sons off the hook dvds are pritty hard for kids to muck up unlike the older vcr you would no belive the things kids would put in them best one i ever saw was a weat bix and a slice of toast.
good luck
May 15, 2010 | Panasonic DMR-EZ47V DVD Recorder/VCR
LG RH1757 (80 GB) DVD Recorder / HDD Recorder Drawer keeps opening Drawer keeps opening and closing and won't read discs! Rassie from Cape Town South Africa
Could be a timing issue with the tray mechanism - possible that somebody has given the tray "a shove" to make it close instead of using the open/close button and has put the timing out.or a worn tray loading belt
Mar 16, 2010 | LG RH177 DVD Recorder/HDD Recorder
LG RHT 398H. DVD tray not closing, with or without DVD in tray. Tray closes upon request, then immediately opens again, and stays open. Any ideas please? Les
I've dismounted the unit and it seems that I have located the problem. The tray is connected to a wheel, so any displacement is translated into a rotation of this wheel. When the tray is near the close position, it releases a mechanism in order to position the lens. Summarising: if you have pushed the tray with your hand instead of pushing the button open/close, probably you have introduced a desynchonization. To solve this, when the tray is in close position, apply a small rotation to the wheel in order to compensate the desynchronization. There is not an exact position, but you need to try. A few degrees is enough. Regards
Jan 12, 2010 | Televison & Video
LG RH274H DVD Recorder keeps opening and closing the disk tray
Did this problem get solved? I have the same machine and the same problem. Any help would be appreciated.
Mar 22, 2009 | LG RH177 DVD Recorder/HDD Recorder
Cd drive opening and closing on its own
You never should have pried it open. Only use the manual eject pin-hole with a paperclip. Noe it seems the drive tray is damaged and will not close properly so it is constantly opening and closing trying to find home. The drive will need replaced.
Jan 02, 2009 | Dell INSPIRON 6000 CENTRINO...
Sanyo 6100 dvd player-disc tray automatically opens whenever power is on.
you should try inspecting & servicing the tray transport mech first and then the tray sense swt.
Dec 08, 2006 | Sanyo DVW-6100 DVD Player/VCR
Dell Dimension 5150 (DIM515MIN) PC Desktop Logo
146 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
