Question about StarTech.com StarView SV431USB 4-port KVM Switch
All channels scrambled 1570 code inop cant turn on emu code
Cant turn on secret menu for emu,1570 and 2004 inop,please help
  • 10,515 Answers
Hi
Print this out, read it at least A FEW times before continuing.
You can forget about EMU codes with the SV PVR it AU's (Auto Updates).
This is an updated version by me
First, Very Important
You may need to load the latest F/W (Firm Ware)v4.506 Oct it is in the 'eko.4shared' link below.
To find your present Software version press Menu/System Setup/System Information. If it is not v4.506 goto the link at the end of this post, download and install it before continuing.
SECOND
Then make sure you are plugged into the correct socket at the back (one of the four together) marked up. NOT the antenna socket. The manual is wrong.
THIRD
Before doing a scan Goto Menu / Installation and make sure the (Cable Network Option) top item is set to your local provider if not correct it by using the right / Left arrow keys on your remote, then move down to Autoscan and wait till it has finished scanning.
Fourth
If channels are not clearing after a scan goto Menu / System Setup / (Press OK) when the Parental Control line in yellow is highlighted then press i then 2007, this should take you the the Cas System Menu. (You may need try this a few times to get your key press timing correct on the remote control but this will get you into the Cas Syatem Menu) If you can't get onto the Cas System Menu screen then you are doing something wrong so re-read it and keep trying.
Fifth
When you are on the Cas Menu Screen and with Nagravision 1,11 highlighted in Yellow Press OK, On the Provider ID Line select the same provider as earlier by using the left/right arrow buttons on remote then press the LAST (load default) button on your remote, then the OK button to (Store) wait for it to save then press exit, then make sure Autoupdate option is On (Bottom Item in Cas System Menu.) This is the equiv of the EMU, Exit out, Goto a scrambled channel and wait for update.
Goto the TheBox PVR Folder for F/W and Documentation Folder for How too's
http://eko.4shared.com/
Taran.
Thnx,
Posted on Nov 26, 2008
    Sergeant:
  • 291 Answers
Unplug the device completely and then connect it 1 by 1 properly.and then check out.
  • jamesrated Nov 26, 2008
    PRESS MENU SELECT FACTORY SETTINGS TYPE IN 0000 THEN SET UP YOUR BOX FROM SCRATCH. SELECT ENGLISH YOUR SUPPLIER AUTOMATIC SCAN WHEN ALL THATS DONE GO BACK TOMENU SELECT PARENTAL CONTROL PRESS INFO ON YOUR REMOTE TYPE IN 2004 GO DOWM TO EMU TURN IT ON THEN YOU WILL HAVE EVERYTHING BACK ON.
    http://forums.afterdawn.com/thread_view....
    just click this link
Some channels have gone went to menu 1570 by an accident presed ok on set default key now channels gone except for rte1 please help thanks
go back in press 1570 go to your subscriber make sure your keys /codes have not changed then scroll down to key emu and turn on hope this helps
Jun 22, 2010 | StarTech.com StarView SV211K 2-port KVM...
Can someone please tell me how to put in emu on starview 5 usb 2 - i go to menu but cannot access emu - tried codes 1570 and 8989 but still only freeviw channels
Press menu. then on installation press 1570, this takes you to nagrivision underneath it says emu , scroll left or right to turn it onto on , press ok, this wiill take you to the code providers which you need to put in which ever one your with.
Jan 30, 2010 | StarTech.com StarView SV431USB 4-port KVM...
Starview box(3 YEAR OLD)gone off,follwed instructions to factory
1st have you scanned the correct provider ex NTL, TW etc?
2nd did the scan find any channels or none at all?
EMU is the emulation to unscramble the channels, to access this in a starview press menu enter 1570 to bring up the secret menu, scroll down to Key EMU and use the <> buttons to turn on.
Exit out and select a PPV channel eg Sky Sports 1 and it will update. You are then set to go.
If no channels are picked up with the scan then check the VM website to see if there are engineering works in the area causing the problem.
Oct 05, 2009 | StarTech.com StarView SV211K 2-port KVM...
Starview help, using correct codes but have prob, please help
Factory reset, rescan exit to main menu enter 1570 on remote, scroll down to emu and turn on exit all way out and allow to update.
Sep 20, 2009 | StarTech.com StarView SV211K 2-port KVM...
Hi there .. i purchased THE box super API ver : 7.08e .. unfortunately am not getting the secret menu using 1570 .. please advice me to fix this prob ,,, thanks
if your getting free to air channels then try,menu,and on installation(do not press ok)type 1570(as quick as you can)on screen you will see nagravision highlighted(here is where you enter codes by hand,just press ok)to turn on emu just look at the end of the screen (see emu and scroll left or right and switch on)if this will not work try to google afterdawn.com and look at forums(look at the end of peoples messages and you will see blue signatures)(eamos library eko4shared.com)all files and sofware and all you need is in there(cause more than likely you will need a new flash if the above dont work,and no secret menu appears)i can give you codes and help putting them in if you get into secret menu.
May 04, 2009 | StarTech.com StarView SV211K 2-port KVM...
Starview3 super, 3 or 4 Irish channels only, emu switched on.
Not 100% certain that this'll work but this is what I did & hopefully it'll work for you too - good luck :-
Subject: Star View 3 The Box Super when channels discappear ;o) 1. Press menu then Factory Setting & Enter code 0000 to reset. 2. Exit to main menu & enter 1570 to get into the CASS SYSTEM & turn EMU on 3. Reinstall channels (Goto Installation, Cable network (try TW first & if no channels try NTL then C & W and so on - I'm with Virgin & used the setings for TW) & Voila ;o) Nb: You may have to redownload channels so reconnect yr box to the computer & follow the link below http://www.4shared.com/file/76886028/fd4ac296/GTRom_the_box_Super_8102e_081129.html?err=no-sess & press download !!!
Feb 28, 2009 | StarTech.com StarView SV211K 2-port KVM...
Need new codes for 'the box' for CHORUS or CHORUS CORK
5E 01
01
AA 26 9E F2 E9 14 D1 AE.
NEW CODES FOR CHORUS AS OF APRIL 3RD.HOPE THATS OK FOR YE.works in cork so that should be ok for u jim.enjoy all
Dec 19, 2008 | StarTech.com StarView SV211K 2-port KVM...
Scrambled or bad channel
go to menu, press 1570 go to emu turn to on, exit 3 times, then go to s+y sports and let it update, it worked for me let me know if it works for you.
Sep 26, 2008 | StarTech.com StarView SV211K 2-port KVM...
The box super
hi i have the super box has anyone got the new code
Aug 16, 2008 | StarTech.com StarView SV211K 2-port KVM...
StarTech.com StarView SV431USB 4-port KVM Switch Logo
Top StarTech.com Computers & Internet Experts
loftys0504
john1601
Level 1 Expert
Are you a StarTech.com Computer and Internet Expert? Answer questions, earn points and help others
