Question about Acer Computers & Internet
My wireless internet is not working. it says theres no wireless device when i press the button to turn it on or off
  • Laird Page
    Laird Page May 11, 2010
    If you'e pressing a button to turn on/off, it sounds like a laptop / notebook to me.
    Desktop PCs don't use "Buttons".
    Check your wireless card - make sure it hasn't popped loose from the connector.
    Check Device Manager and network connections to see if it's actually installed, and enabled.
    Reload Drivers if needed.
    Replace Wireless NIC (card) if it's defective
  • Daniel Brooks May 11, 2010
    Hello, Please add me to MSN @ daniel.brooks@live.com so I may gather more information on your problem. I will need to know the model and version of your network device and the infrastructure of your network, as well as your operating system.
    Problem Solver:
  • 18 Answers
Get the proper driver.
Posted on Nov 28, 2008
Won't let me change from wired to wireless.
Make sure that the wireless button is not turned off. If there is a physical button, then you may want to push it into the opposite direction in order to get it working correctly. The other option is to click the "search the web and windwos" area of your task bar. Type in "wireless" then there should be an option that says " turn wireless device off" or "turn wireless device on". In your case, you will click the option that says "turn wireless device on". This should resolve your issue of not being able to switch between wired and wireless.
May 20, 2017 | Computers & Internet
Np-qx411 wireless card not working
Check it is turned on.
Key 11 Wireless on/off
Easily turns on or off the several wireless network settings at the same time. - This button is useful on the airplane to turn off every wireless network device. - You also can set up a specifi c wireless network device with the Fn + key combination. On : Shows that any wireless network devices are turned on. Off : Shows that no wireless network device is turned on. Initializing process will take about 5 seconds after pressing this button. If you want to change the status again, press this button after 5 seconds. If the device cannot search wireless network while this button shows On, press the Fn + key combination to search and confi gure it manually.
See the manual,
http://downloadcenter.samsung.com/content/UM/201408/20140828175358730/Win7_Manual_eng.pdf
or download a new driver for it from here.
Global Download Center
Oct 01, 2014 | Computers & Internet
Can i restore my polariod 7 tablet to factory setting without messing up my iphone and laptop files.
Yes, its possible to hard reset your tablet. Turn off the device, hold the power and Volume up buttons together. Once the device turns on release the power button and continue to hold the volume up button. A Sceen with the android service icon will appear. Press the Volume up button once more then you will see a couple of selections. Press the volume down button and select (wipe data/ factory reset) option. be sure to press the power button to select the option. scroll down using the volume keys to (YES- Delete all user data) then press the power button again. Your device will begin to wipe its self. Once the selections appear again select (reboot system now) your device will restart and youll be back to when you first purchased.
Francisco Torres
Wefix Wireless Technician
Wefix Wireless
Aug 14, 2012 | Polaroid 7-in. Internet Tablet - Other
Turnon wireless
You have to hold the FN (function) key while pressing F12, that should work.
Jun 19, 2012 | HP Computers & Internet
Turn on wireless
start button
control panel
wireless icon
reset it there
Hi there! I would like to know how to unlock internet button from my HP probook. Its button light is orange and I have no access to the internet. I'll glad you anything you can do for me! ...
Not knowing the model of your unit, I respond with a general answer:
Using the wireless controls
You can control the wireless devices in your computer using these features:
?? Wireless button
?? Wireless Assistant software (select models only)
?? HP Connection Manager software (select models only)
?? Operating system controls
Using the wireless button
The computer has a wireless button, one or more wireless devices, and two wireless lights. All of the
wireless devices on your computer are enabled at the factory, so the wireless light is on (blue) when
you turn on the computer.
The wireless light indicates the overall power state of your wireless devices, not the status of individual
devices. If the wireless light is blue, at least one wireless device is on. If the wireless light is amber, all
wireless devices are off.
Because the wireless devices are enabled at the factory, you can use the wireless button to turn on or
turn off the wireless devices simultaneously. Individual wireless devices can be controlled through
Wireless Assistant software (select models only) or through Computer Setup.
check chap.2, page 22 in this manual:
http://tinyurl.com/3czcyss
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks,
Joe Diaz, Nashville TN.
De Cayey, P.R.!!
May 20, 2011 | Computers & Internet
Hi, my wire less internet was working and now i cant get it to work. on the icon on the bottom of the screen when you click on wifi it has a red cross on it.it says something about the setting is turned...
It sounds like your WiFi switch was somehow shut off.
hpweb_1-2_minus.gif Wireless device is turned off or disabled The power to the wireless network and Bluetooth devices is controlled by a switch or button on most computers. It is possible to accidentally bump the button and turn off the wireless service. c02230159.jpg On most computers, there is an LED light that glows blue when the wireless device is turned on and enabled, and glows orange when off or disabled. Some newer models use different a different color scheme, see the user guide for more information. To turn on and enable the wireless device, do the following:
  1. To turn on the wireless device, simply move the switch to the on position. On some computers, the switch is actually a touch point on the panel above the keyboard.
  2. To enable the wireless device, right-click the HP Wireless Assistant (disabled) icon c02448899.jpg and select Open Wireless Assistant . Click Turn On . The HP Wireless Assistant (enabled) icon c02448900.jpg will display.
  3. Or you can try pressing the Fn and the F2 keys at the same time to enable your wireless adapter.
  4. Here is a link for your product support page at Hp.com : http://h10025.www1.hp.com/ewfrf /wc/searchResults?tmp_product=Compaq+Presario+V6000T+CTO+Notebook+PC&product=3177516&tmp_qt=turn+on+wireless+switch&lc=en&dlc=en&cc=us
Apr 21, 2011 | HP Compaq Presario V6000T Notebook
The wireless switch is turned off cannot be turned back on cannot get internet connection
Start by
1) Make sure Wireless Lan is Enabled by pressing the light button of it
2) Click with right button on the Battery Icon (on the botton bar aside clock)
3) Select Windows Mobility Center (a window will open up)
4) Click on "Turn wireless on" button.
You can also disable the power management from turning off this device
Go to Control Panel and then to Device MAnager. Click on the wireless device and then on Power Management tab and uncheck the first box.
May 27, 2010 | Acer Aspire 6930-6455 Notebook PC
How do I reset the Hawking HWR54G to factor settings - delete passwords and security settings?
At the back of your device next to the WAN Port (internet port) you will find a small hole with a button inside it, turn your device off then press and hold the small button in while switching on your device, keep pressing down on the button for about 5 seconds, that will reset your router to default settings.
Keep Moving Forward.
Jul 18, 2009 | Hawking Wireless-G HWR54G (603992506064)...
Computers & Internet Logo
20 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
