Question about SVA-USA HD4208TIII-PDP 42 in. EDTV-Ready Plasma Television
Pc ready How do you use thiss tv as a PC monitor. It is currently in use as a TV
    Problem Solver:
There is a PC/DTV RGB input area with two audio jack inputs.  The input is a standard 15 pin PC jack. Hook it up to your PC video card input.  You can get the audio cable from Best Buy or a electronics store...split RCA on one end and the headphone jacks on the other to your PC. Then select the TV/Video source button on your remote until you see PC/DTV YPbPr screen appear.  It will search for the signal, find your PC and display the screen. You may have to go to MENUE on your remote to adjust the HDTV (1080i) frequency.... an option that only appears if there is something hooked up to the PC/DTV RGB signal input.
Posted on Dec 21, 2008
Connect pc to toshiba 40bv700b television as a second monitor
The easiest way is just run a HDMI cable from your pc to the TV. Then just change the display settings on your PC to enable the second monitor feature. Change the TV input to the HDMI port that the PC is hooked up to. And you should be ready to go.
Jan 26, 2013 | Toshiba Computers & Internet
Hello.im from malaysia..i have using 42" LG LCD tv..when i see info..i feel confuse because at box it say Full HD 1080p ready but when i see info, it only 1080i 50hz..how can i change this?
You do not change the resolution at the TV, the vidoe/signal sources will dictate what it will display on the TV, if it is fed with 1080i it will display 1080i. If you want 1080p, your video source will have to be 1080p. It works the same as your PC monitor, you adjust the resolution at the PC, not at the monitor.
I hope I explain it well enough.
Basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Jun 14, 2011 | Televison & Video
Trying to hook my home PC into my LG TV gets me the message Invalid Format, what can I do to get the signal or can i use this tv for my monitor with a dell PC
Connect VGA (D-sub 15 pin) cable from PC to TV (RGB PC) input jack. Connect audio cable from PC to TV. Set screen resolution on PC to be compatible with TV, such as 800 X 600 or 1024 X 768 etc. Select on the TV, the PC INPUT using the TV remote when ready to use as monitor.
Under PICTURE on the TV select SCREEN (RGB-PC). You can AUTO-CONFIG or you can set resolution manually to the same you set PC to. Other adjustments can be done here as well to get optimum picture on TV from PC.
Mar 01, 2011 | LG 26LG30 26 in. LCD TV
I don't have problem just a question can a tec view be used as a computer monitor? where can i get a remote
Look for a port labeled 'VGA' on the back or sides of your TV. Also, compare the ports on your TV to the port on your current PC monitor and if you see on your TV a port that matches the one on your current monitor, then you can use your TV as a PC monitor.
Sep 06, 2010 | TechView P4204TW Television
What wires / connections do i need to run my home pc through the t.v
Depends on what hookups the Tv and PC have. Newer laptops have a HDMI jack, otherwise the external monitor jack will do. Then the TV must have a monitor hookup. Most likely not. So then you'll need some type of a conversion cable to go from PC to TV. Check your local Best Buy for the cable.
Nov 25, 2009 | JVC LT32DS6 32 in. HDTV-Ready LCD TV
Flat screen zenith Z20LCD1 use as a moniter HOW? Thanks
this is from the manual:
When the input source is PC (Only for Z15LCD1)...
PC S ettup ((Z151L5CLC1RD1
onlly))
Connections
1. Set the monitor output resolution on the PC before connecting to the TV.
2. Connect the TV to the PC with the PC cable.
3. Connect the PC audio output to the TV's PC S OUND input.
Viewing Setup
1. Turn on the PC.
2. Use the PC b utton on the remote control to select PC .
it appears only the 15" model may be used as pc monitor
Dec 06, 2008 | Zenith Z20LCD1 20 in. EDTV-Ready LCD...
Need use New HD PC Monitor with DVI/VGA inputs like HD Ready TV
you need to get a lcd tv device such as from dany or xpod.  it will connect your cable, and its output can be fed into the lcd monitor.
Nov 14, 2008 | Samsung SIR-T451 DirecTV DTV Receiver
Lcd hd tv conected to my pc do not work
Try going through the settings in properties on your computer
Aug 04, 2008 | Samsung SyncMaster 216BW Monitor
Limited monitor resolutions
By plugging into the tv you created an additional monitor profile. You will need to go to the resolution page and open the advanced button, from here set the monitor to the laptop screen versus the vga tv. There is also a troubleshoot button that can be useful.
Jun 28, 2008 | Acer Aspire 3100-1405 Notebook
When my PC is connected to my TV, the TV screen only shows the PC's background without the icons and other stuff.
cant use s video oout have to use vga dvi ect if your tv can take it ok to work way uw ant it like a pc desktop
Feb 02, 2008 | Samsung LE40R72BDX 40 in. HD-Ready LCD...
SVA-USA HD4208TIII-PDP 42 in. EDTV-Ready Plasma Television Logo
153 people viewed this question
Top SVA-USA Televison & Video Experts
Henry  Thomas
Henry Thomas
Tony
Michael Galve
Michael Galve
Are you a SVA-USA Televison and Video Expert? Answer questions, earn points and help others
