Question about Zenith C27F33 27" TV
High pitch noise
I have 2 of these televisions in the bar I manage. They are both 3 years old. They have begun to give off a high pitch noise. It could be after 20 minutes of use or up to 3 hours of use, or anything in between. Turning them off, resting (say 1/2 hour) then turning back on only eliminates the problem momentarily.
  • joehegg Jan 04, 2009
    Where might the horizontal linearity coil be located
    Scholar:
  • 119 Answers
What you are hearing is the mechanical vibrating of coils & or transformers in the tv. 1st and easyest is to hot glue the parts that is making the noise down. if that does not work, removing & reinstalling the part is next. the last is replacement. the most likely parts causing is the 1. horizontal linearity coil, 2. the run or switch mode transformer, or 3. the flyback transformer. good luck.
Posted on Jan 09, 2007
Funai tv. When plugged in, makes ear piercing high pitched buzz that goes away when unplugged. Will not respond to buttons. No picture or power. Already replaced power board. What now??
TV not turning on; making high-pitched sounds - Tom's ...
www.tomshardware.com > Forum > Graphics Cards
Tom's Hardware Guide
Nov 30, 2013 - 7 posts - ‎2 authors
Both of them are refusing to turn on, and make high-pitched sounds when plugged in and unplugged. More about : turning making high pitched ...Missing: ear ‎piercing
Top 136 Complaints and Reviews about Funai TV ' Page 2
www.consumeraffairs.com > Electronics > Televisions
Rating: 1.1 - ‎65 votes
We unplugged the unit and waited 15 - 20 seconds and plugged the unit back in, and it wouldn't ... He heard a loud high-pitched whining which led him to TV in my daughter's room. ... It only makes a humming sound now, no pictures at all.Missing: ear ‎piercing
HELP! what is that high pitched noise when tv is on? - TV - Audio ...
www.tomsguide.com/forum/60895-6-help-high-pitched-noise
Jan 25, 2013 - 3 posts - ‎2 authors
Hello, I hear this constant high pitched noise, almost like ringing, but even ... pitch
Jan 21, 2016 | Funai Televison & Video
5 year old goodmans tv suddenly went off, then intermittent high pitched squealing noises
Check the horizontal output section circuit. It sounds that the LOT {Line Output Transformer} has damaged.
May 11, 2012 | Televison & Video
My laptop charger, after about 1 and a half years of use, has begun to make a strange, high pitched noise and refuses to charge my laptop.
In most modern laptop chargers, this high pitched sound it emitted when a "safety switch" has been activated in the charger. It is possible that there may have been damage to one of the components in the charger. The only solution is to replace the charger.
Mar 30, 2011 | Sony Vaio PCG FR415S Laptop AC Adapter...
The TV is making a very high pitched noise. The longer it is on the louder it gets.
Easy repair with some Super glue.Must take the tv back cover out.The FBT-the big block of plastic with a red wire with a cap hook to a CRT(tv tube).It have a high voltage gap going through a "3 inches paper clip steel bar on a FBT the big black plastic block.Put some super glue on that "3 inches paper clip steel bar on that big black plastic block.Should stop the high voltages gaps through that "3 inches paper clip steel bar causing a high pitched noises.
Nov 17, 2010 | Jensen TS2050J 20" TV
I keep getting a very high pitched noise / buzzing from my TV even when volume is muted! its spoiling the viewing. its not always there but its all to frequent now. TVis 3 years old
The power supply is a switching mode power supply. They work at high frequencies. Sometimes they produce harmonics that can be heard by people. The power supply may need to be replaced if it get really bad.
Apr 16, 2010 | Philips 42PF9630A 42 in. Plasma Television
High pitched sound comes from tv ---no controls on tv work--you have to unplug it to get the high pitch to go away
Is this a tube tv?IF it is the Flyback tranformer have a little still bar tranformer hight current volt make that noise take off the tv cover put some glue on the little steal bar should stop the noise or lower it very good.
Aug 12, 2009 | Televison & Video
High pitched noise
I am about to post a in depth guide about how to fix this problem. It's because a capacitor inside the TV has blown which causes the buzzing high pitched noise. It's really easy to fix however and only costs about £1 / $2 to sort out.
You can read a similar guide here http://www.fixya.com/support/r741402-polaroid_flm_373b_lcd_tv_black_screen but I will shortly be uploading a guide on the buzzing problem!
Dec 22, 2008 | Polaroid FLM-3732 Television
High pitched noise on Polaroid HDTV
It appears like your power supply is not filtering the voltage properly and that is why you are hearing that high pitched noise. If your LCD is less then a year old, you can call Polaroid to have it repair under warranty.
If more then a year old, check the info from this link to replace the capacitors.
Let me know if you need further assistance.
Oct 07, 2008 | Polaroid FLM-3734B 37 in. LCD HDTV
High pitched noise
The power supply is starting to fail on your LCD. The noise you hear is because the circuit is trying to provide the proper power to the rest of the circuitry and is forcing itself.
The noise does increase if you tune to an HD channel because of more demand for power for a brighter picture.
Sep 18, 2008 | Polaroid FLM-3734B 37 in. LCD HDTV
High pitch noise
Hello there, You have to specify where the noise is coming from. Is it coming from the speaker or from the back of the unit. SMPS power supply powering your unit create this kind of noise when some capacitor gone out of their value.
Good Luck.
Jan 26, 2008 | Samsung LW26A33W 26 in. HD-Ready LCD...
Zenith C27F33 27" TV Logo
93 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
