Question about Whirlpool GGQ8831L Gas Dryer
Whirlpool gas dryer not heating up consistantly...
I have a 6 year old LGB600KQ1 Whirlpool gas dryer. I replaced the ignitor because that seemed to be the cheapest and most logical solution. Unfortunately, it still doesn't heat up consistantly. If I start the dryer up, the ignitor starts and the flame comes on but if I turn it off, and restart it, the ignitor doesn't start... then if I turn it off again, and restart, the ignitor comes back on and the flame comes on. It seems to work every other time. I've also let it run and some times, I get a gas smell, as if the gas comes on but the ignitor doesn't. Could this be a problem with the radient sensor or the Main Timer? or is there something else I should be checking and how would I check to narrow it down without ordering all the parts?
Also it is possible the coils need to be replaced. I had similar symptoms as you describe. Found a place that had the primary and secondary coils as a pair in a pack. Popped them in and solved the problem. The coils are electromagnets that control the gas flow valve, and despite being a solid state part, they go bad sometimes.
Posted on Dec 30, 2008
    Sergeant:
    Champion:
  • 291 Answers
Replace the sensor on side of the heat tube where valve and ign is located
Posted on Nov 26, 2008
6 year old dryer will not heat. Gas line & supply
Use this video to replace your gas ignitor.
http://www.youtube.com/user/RepairClinic#p/search/10/NVvI2kbOA-g
Aug 19, 2011 | Whirlpool WGD5320SQ Gas Dryer
No heat. Elec. power OK. 12 years old
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Dec 19, 2010 | Whirlpool WGD5200TQ Gas Dryer
My whirlpool dryer, model LGC6646AWO will not heat. It doesn't sound like the electonic ignition lights up. what part most likely needs to be replaced? this dryer is 16 years old
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Oct 25, 2010 | Whirlpool Dryers
The dryer is under a year old and was setting in the garage for 6 months not being used. Now its hooked up and operates but does not heat up. Help?
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
heatman101
Sep 14, 2010 | Whirlpool Dryers
Heating went out on dryer. dryer only 6 years old
heatman101
Aug 03, 2010 | Whirlpool WED5300S Electric Dryer
Not heating up
check the ignition spark ignitor
Feb 28, 2010 | Whirlpool LGB6300 Gas Dryer
Dryer will turn but won't heat.
Check the gas valve in the back of the unit and also check the Glow ignitor to make sure that you are igniting the gas to heat the drum. Sounds more like it is the Glow ignitor that is bad
Feb 09, 2009 | Whirlpool LEB6200 Electric Dryer
No Heat on a whirlpool dryer. 14 years old.drum turns,timer moves,getting gas to valve,tapped solenoids-no change.burner not lighting. thanks for any info
if ignitor not coming on could be flame sensor mounted on side of burner housing or ignitor ..if ignitor glowing but burner no lighting replace both solenoids bad connections interally on solenoids..also if ignitor not glowing possible small white thermal fuse open.. sensor and fuse can be jumped across to confirm ..
Dec 22, 2008 | Dryers
Samsung dryer smells like gas
Replace the operator coils. They are intermittant. Typical operator coils look like this:
Nov 27, 2008 | Whirlpool GGQ8831L Gas Dryer
Whirlpool LGB6000KQ1 gas dryer not heating up consistantly and sometimes smells like gas is leaking.
if ignitor is glowing but burner fails to light ck/replace the 2 black coils on valve they will sometimes fail after 1st couple of heat cycles
Nov 26, 2008 | Whirlpool GGQ8831L Gas Dryer
Whirlpool GGQ8831L Gas Dryer Logo
157 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
