Question about Whirlpool GBD307PDS Electric Double Oven
I have a Kitchen Aid Oven. I self cleaned it and when it was clean It did not work. Can you tell me why or how I can repari it.
  • 76 Answers
There are thermal overloads in the back of the oven, if this is a built-in, you will have to remove the oven from its space and take the case off of it.
Posted on Jan 01, 2009
We a kitchen aid oven the door was accidentally lock. Can you find out how to open it? Whirlpool owns kitchen aid
  • Look for a manual lever to unlock the oven. If there is one, it will probably swing back and forth horizontally, just below the upper edge of the oven door
  • Swing the locking lever, if one is present, all the way to the left. This should unlock the oven. If there is no manual lever to unlock the oven, it may be unlocked using push-button controls.
  • 3
    Check to see if the oven is in a self-cleaning cycle, or has just completed a self-cleaning cycle. If so, the door will unlock automatically once the oven has finished the cleaning cycle and cooled completely, which may take several hours. You cannot unlock the oven before it has cooled.
  • 4
    Unlock the "Clean/Off" button. Depending on the brand and model of your oven, the button may display both of these designations or just one. If your oven door is locked, but the oven is not warm and is not in a cleaning cycle, unlock it by pressing and holding the "Clean/Off" button.
  • Nov 18, 2012 | Ovens
    Owner's manual re self clean feature Kithcen aid Superba27 self clean double oven purchased 1988 Cannot get it to turn on and heat. The Lock light does not go on and no heat is generated.
    Before you go working too hard to get you oven to go into the self clean mode(self destruct)....check out this tip...
    Self Cleaning Oven Problem
    heatman101
    " Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!!
    Jan 17, 2011 | KitchenAid Ovens
    Kitchen aid wall oven Model YKEBS2780B1 SHOWS
    Hello,4 Digit Failure Code F0 - E0 Analog to Digital Failure Disconnect for 30 seconds - if display re-appears - replace control F1 - E1 Safety flip flop Replace Electronic Range Control/Clock(ERC) F2 - E0 Shorted keypad Replace Electronic Range Control/Clock(ERC) F3 - E0 Oven temperature sensor or oven temperature sensor fuse opened Replace oven temperature sensor or fuse F3 - E1 Oven temperature sensor shorted Replace oven temperature sensor F3 - E2 Oven too hot Replace oven temperature sensor F3 - E3 Clean temp too hot Replace oven temperature sensor F5 - E0 F5 - E1 and E2 Check door/latch switch Replace component 2 Digit Failure Code F0 or F1 or F5 Failed transistor Replace Electronic Range Control/Clock(ERC) F2 - E0 Oven temp too high 1. Test operation of door lock on self-clean models
    2. Test relay contact operation
    3. High resistance in oven temperature sensor F3
    Thanks
    May 26, 2010 | Ovens
    I cleaned over with self clean and it blows the thermostate. Is this normal on Kitchen aid wall mount ovens?
    if u have unproper vent specs on unit it will blow. read instellation spect for proper vent specs
    Feb 12, 2010 | KitchenAid Architect Series KEBC177KSS...
    Will not come on after self cleaning
    this is a common occurance with many self clean ranges, especially slide in and wall oven units. the kitchen aid ranges usually have a non reset hi-limit. meaning it opens one time and needs to be replaced, sadly.
    to replace the thermostat can be tricky to do if you're not experienced, so if you have any reservations about taking you range apart, call a qualified tech in your area. if you decide to take a go at it, well first things first.
    **FIRST unplug from the wall or shut off the breaker**
    *the other issue is not knowing what model you have.
    I can tell you most recent kitchen aid units made by whirlpool have a fixed hi-limit at the back outer oven wall. remove the rear panel, and the hi-limit should be easily accessed. that part # 8300802
    hope that helps,
    good luck
    Sep 28, 2009 | KitchenAid Ovens
    I hit the self clean button on my Kitchen aid oven and now the door is locked and the oven lights are off
    I have heard that with this model, the self clean will ruin the electircal components. It sounds like you may need to have someone test it out to find what is ruined. If I were to guess I would say its the controller board. Mine was on backorder for 2 months.
    There is a person in this link that has the same issue:
    http://www.consumeraffairs.com/homeowners/kit_stoves.html
    May 09, 2009 | KitchenAid KEBC107 Electric Single Oven
    Kitchen aid, self cleaning
    The only solution is to get a new oven, The paint in the oven burned off, and now the electic board is burning out. This oven when it hits about 400 degrees it makes this chemical plastic smell, and at selfcleaning it makes the same smell for 3 1/2 hours, and come to find out it burned the paint off
    Jan 04, 2009 | KitchenAid Architect Series KEBC107KSS...
    Kitchen aid wall oven kebs177dssp
    call whirlpool tecnical assitance see if they have a kit for it tech knows parts people dont most of time they do beleive or not they want it to work right been working for the factories for years and they doo care
    Dec 22, 2007 | KitchenAid Architect Series KEBC107KSS...
    Self Clean does not work
    Hi, Before you go working too hard to get you oven to go intothe self clean mode(self destruct)....check out this tip...
    heatman101
    " Wish I had read this first. I never would have used the self cleaningoption. Thanks for the info!!
    Oct 30, 2006 | KitchenAid KEBS177 Electric Single Oven
    Whirlpool GBD307PDS Electric Double Oven Logo
    77 people viewed this question
    Top Whirlpool Ovens Experts
    Sal De
    Oloyede Monsuru
    Are you a Whirlpool Oven Expert? Answer questions, earn points and help others
