Question about Neovo F-417 17" LCD Monitor
Screen flicker, color swirls
My monitor was fine for about 2 years then suddenly one day it has a lot of flicker and color swirls on the entire screen. Looks similar to the vertical hold on a tv being messed up (similar). Twice it eventually went normal, but then messed up again after it went to sleep or off and back on. Any ideas?
  • Todd DeLand Jun 19, 2007
    In case your interested, I've had it working fine (with the exception of four days ago, when I tapped on it and it worked again...ugh) since about March I would say. I have been using Ubuntu since then, maybe its a driver related thing?? I'm not sure, I thought these Neovo were supposed to be really good!?
Mine does the same has done since new, It was sent back and when returned it still does the same. If i tap the top of the screen it comes right again for about 10 miniuts
Posted on Jun 19, 2007
SOURCE:
Luxor 40 914 tvb
If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years.
Check the cables, connectors and connections.
Take it to a repair shop.
Apr 13, 2014 | Televison & Video
Yellow screen hp dv6000
The screen is faulty or the screen cable has become dislodged. Best take it to a repair shop.
Oct 12, 2017 | HP Computers & Internet
Monitor is flickering
Welcome to Fixya Support,
I am happy to assist you.
Monitor Flickering May due to following Reason
1. Deffective LOT
2. Deffictive Filter IC or Deffective horizontal IC
To fix this issue,you have to check LOT, if LOT working fine, you have to search for burn out capacitor along with filter IC and replace with new one. After this your monitor must work properly, without any flickering.
Thank you for using Fixya Support. If any problem leave a comment or feedback we will deffinately help you.
Have a Nice Day!
Best Regards
Fixya Expert
Chandrashekhar.
Dec 06, 2010 | LG 700M 17" CRT Monitor
I am at work right now looking for solution to my monitor at home. The screen is so wavy that I cannot read the text very good. My 5 year old plays on the computer a lot. And all of a sudden the other...
Connect the monitor to a different computer (laptop or desktop), to see if the problem "follows" the monitor.
Connect a different monitor to your computer, to see if the video-card in your computer is generating the "wavy" display.
Move any "power-bars" and PC Speakers *FAR* away from the monitor, to eliminate electrical interference.
Oct 22, 2010 | E-Machines eMachines Monitor E15T4
HP Pavilian external monitor color problem.
The easiest thing would be to check your cable for a bent or loose pin. Next put another external monitor on the laptop. The circuitry to provide video to the laptop screen and the external monitor are separate except that they share a video processor and video memory. There can be bad electronics involved.
Apr 08, 2009 | HP Pavilion dv6000z Notebook
Reddish tint on the screen
LG 700e
power suply is dad
resistanc is black not show it ohom
plz help
Dec 21, 2008 | LG Studioworks 700S 17" CRT Monitor
Ocassional flickering
Not sure what the problem is, but am experiencing the same symptoms every few minutes on a Mitsu Diamond Pro 91TXM, just retrieved from storage after 7 years. How's your screen holding up since April?
Apr 17, 2007 | Mitsubishi Diamond Pro 900U 19" CRT...
Flickering crispy screen
maybe ur screen was put into a lot of magnetic interference. so check for any magnetic rays emitting devices like speaker adapters etc. a simple check would be to degauss( its in the screen properties). raja
Feb 28, 2007 | LaCie Electron IV 19" CRT Monitor
HP f1903 LCD Monitor mild flickering & color variance
I would bet it is the cable or connection. Have you tried connecting the monitor to a different PC?
Feb 14, 2007 | HP Pavilion F1903 19" Flat Panel LCD...
Neovo F-417 17" LCD Monitor Logo
343 people viewed this question
Top Neovo Computers & Internet Experts
Steve Allison
Steve Allison
Dimitar Todorov
Are you a Neovo Computer and Internet Expert? Answer questions, earn points and help others
