Hello, I have a viewsonic 19 inch LCD panel. When I turn it on, the screen just goes black after 3 seconds.Whats wrong?
    Scholar:
  • 39 Answers
Hi there. It's probably your backlight inverter that has gone bad. What model is it ? The inverter can be on a seperate board, or on the main board on that viewsonic LCD. Is it a VX922 ? Common problem on these..
Posted on Nov 26, 2008
The Screen comes on for 1 second then goes black but you can still faintly see the image on the screen
It can be as simple as bad DC filter caps (leaking/bulging tops), that will be the first thing to look for, it can be more serious problem in the inverter circuits or bad CCFL assemblies.
http://s807.photobucket.com/albums/yy352/budm/Viewsonic%20VG2021/
Failed TV and Monitors: http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Sep 06, 2010 | ViewSonic Graphic VG2021m LCD Monitor
VX900 19 in. Flat Panel LCD Monitor: when i turn it on the screen is black....
You may have backlight inverter failure, check the fuse as shown in my pictures, you can also have bad backlight assemblies also, but check the fuse on the inverter bd first, verify that you do have 12v at the fuse.
http://s807.photobucket.com/albums/yy352/budm/Viewsonic%20VX900/
May 16, 2010 | ViewSonic VX900 19" Flat Panel LCD Monitor
Monitor flashes on then off power light stays on whats wrong?? shows screen for about 3 seconds then goes black
Some 22" Viewsonics will have worn out bulging capacitors in the power supply that causes this symptom.
Monitor Mike
Apr 14, 2010 | ViewSonic 22" FLAT SCREEN CRT BLACK...
The monitor only turns on for a second and then goes black again. the green light stays on. what can be done?
More likely to be failed components.
Most common failure in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, falied inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed VIEWSONIC monitors to get some ideas what goes wrong: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further.
Mar 31, 2010 | ViewSonic VX922 19" Monitor Flat Panel
Blank screen
You probably got yourself a bad backlight or better yet a bad inverter board inside. A lot of experts found if you open this thing up and See any puffed up capacitors replace them as that could also cause this issue. But viewsonics had a issue with a bad capacitor on the power supply board.
I sure hope this information is Very Helpful to you!
Dec 13, 2009 | ViewSonic VE710b 17" Flat Panel LCD...
Vx900 dispays for a second and goes blank.
is the vx922 worth fixing? my neighbour found it now i trying to fix it. wheres the capacitor, or the other thing to look at, as the screen goes black but button stays green..... i need diagram or simple play by play.
Apr 17, 2008 | ViewSonic VX900 19" LCD Monitor
Vx900 viewsonic monitor problem . Blank screen except for power off/on
no, Viewsonic has the part for sale 42.99 - free shipping. Easy to replace
May 25, 2007 | ViewSonic VX900 19" Flat Panel LCD Monitor
Computers & Internet Logo
105 people viewed this question
David Payne
David Payne
