Question about Dyson DC07 Bagless Upright Cyclonic Vacuum
Ive got a sock in the tube
It is in the flexible tube and cannot be reached
    New Friend:
Lie the hoover down (on it's side); un-attach any hose extensions, pop super glue on a straightened out wire coat hanger, push this down hoover hose. hold for 3 seconds, pull sock or whatever out. (May need to be done repeatedly to remove sock) (: just removed one from mine today! >w<
Posted on Jun 29, 2013
  • MeganJJang Jun 29, 2013
    Problem Solver:
  • 5 Answers
Remove dust bin from hover and remove handle from hose then remove hose from hover and push a peice of doul up hose to remove sock and rebuild hover or buy new hose hope this helps
Posted on Nov 27, 2008
Making a loud noise and not picking up
Not picking up? Usually caused by a clogged vacuum line/filter or full bag. First, check your filters/bag for capacity. Next, inspect the ribbed hose. If it's heavier than normal, your clog is probably in there. You can clear it by gently squeezing to find the foreign body that has likely become wedged into the ribbing, and while squeezing, apply a twist to dislodged it from the ribs. Then shake it gently to allow the clog to fall out into a dust pan or trash can. If the hose is lite, it's likely a foreign body lodged into the tube of the lower housing where the wheel brush forces it up the curved tube with the air vacuum before it reaches the flexible hose. You should be able to clear this by disconnecting the hose from the lower housing, possibly removing a lower faceplate from the wheel brush area, and fish a coat hanger or other flexible but rigid object through the tube to dislodge the debris.
Jul 20, 2014 | Vacuums
Clogged
If you can find a way to reach the clog you may be able to remove it without tearing it apart. I use a flexible tool that comes from the auto parts store. It's made to reach down into tight spaces to retrieve a dropped part or nut. When you push the. Button on the handle it pushes little tines out the other end which I use. To grab the restriction to pull it out.
Mar 14, 2014 | Hoover Vacuums
Richar rad
go to www.riccar.com and download in pdf your respective manual for to procedure to disassembly.
God bless you
Jul 19, 2012 | Riccar 8925
I have a nv30 infinity vacuum. The handle is clogged with a sock right where the flexible hose begins. I cannot reach the sock even after removing the telescoping tube. How can I unclog the handle?
Hi Jackie ma268...
You need a metal coat hanger nd a pair of pliers.
You will straighten out the coat hanger with a pair of pliers, except the end that you hang the clothes hanger up with, because it has got the hook already made..
After you have gotten the hanger straight, you will take the hook of the hanger and make a smaller hook that will slide easy into your hose with the hook being able to catch the sock ...once it has caught the sock, then twist it a few times so that it will get caught up in the sock really well...then pull the sock out of the hose...Job done.
Please take time to rate me
Sep 06, 2011 | Vacuums
Was using vacuum and sock is now lodged in vacuum hose. How can I get the sock out?
The easiest way to remove an article of clothing from the hose is to remove one end of the hose from the vacuum, and reach in with a piece of wire with the end bent into a hook. A wire coathanger will work well for this. Just straighten out the coathanger, take a pair of pliers, and put a small bend at the end of the wire, in a J, or hook shape. Then, reach the wire into the hose, and when you feel the obstruction, twist the wire, so that the hook gets stuck on the sock. Then, pull it out, and reattatch the end of the hose back on the vacuum.
It doesn't matter which end of the hose you remove, just whichever is easier, and hopefully closest to the clog.
Do not try to push it out, as it will just bunch up tighter. It must be pulled out.
Jun 17, 2011 | Kenmore 31913 Progressive Direct Drive...
I got a sock stuck in the hose how do i get it out?
Take a metal closthes hanger and undo the hook end from the spiral at the base of the hook, leave the hook and the coil that held the hanger together as is and straighten the rest. Put the spiral end of the hanger into the hose, when it reaches the sock twist the hanger to screw the spiral into the fabric, not too far, only a little. If you have enough grip on the sock, it should pull back out. You may have to try several times until the sock pulls free. Good luck.
Feb 04, 2010 | Kenmore Vacuums
I just bought a new belt for my vacuum and have a brand new bag in and it isn't sucking anything up.
1 - make sure that the belt is installed properly and brush roll is spinning as you are vacuuming.
2 - it is not unusual to have a clog in the miniemptor / fill tube assembly - black plastic shoe-like bag bottom part with tube (you can see it HERE)
3 - Sometimes something gets caught in in the exhhaust - part of the main body where you install the bag. Take coat hanger and run through it. Once I have pulled a sock out of there and I could nor see or reach it without the wire...
Rocky
Aug 09, 2009 | Kirby Ultimate G Bagged Upright Vacuum
Any tricks to putting on a central vacuum hose sock? The last one took me 4 hours and I'm sure there must be an easier solution. It has no zipper.
Send it back and get one with a zipper. :) Okay did it come in a tube or with a tube? They are really necessary when putting a hose sock on. You first want to put the hose sock on the tube. You then slide the tube over the hose and take the hose sock off at the end. Tie the hose sock securely in place and start pulling the tube over the hose. The sock will slide off the tube and onto the hose as you go.
Jun 08, 2009 | Electrolux Central Vacuum
Blockage in Tube
if u have an air compressor then try that. otherwise a long pole.
Aug 14, 2008 | Bissell 220522 CleanView Upright Vacuum
Dyson DC07 Bagless Upright Cyclonic Vacuum Logo
473 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
