Question about Whirlpool GGQ8831L Gas Dryer
Whirlpool LGB6000KQ1 gas dryer not heating up consistantly and sometimes smells like gas is leaking.
  • Anonymous Dec 01, 2008
    lint blows everywhere and seems like it it clogged out of the exhaust hose
    Genius:
  • 1,028 Answers
If ignitor is glowing but burner fails to light ck/replace the 2 black coils on valve they will sometimes fail after 1st couple of heat cycles
Posted on Nov 27, 2008
Whirlpool Dryer LGB6000KQ1 - Dryer Doesn't heat nor does timer advance.
Probably the heating element. They go bad more often than timers.
Jul 25, 2017 | Whirlpool Dryers
Whirlpool model LGB6000KQ1 electric dryer. I have to run the dryer two to three times before the clothes dry. There is a little heat, and I cleaned all the vents. Do I need a new heating element?
if the exhaust hose is clear of debris and you feel a good flow of air through it then ' Yes ' I would say that the heating element is bad.
c...
Dec 30, 2010 | Whirlpool Dryers
Whirlpool Gas Dryer (ggq9800pw1) - No Heat
You have a leak somewhere in your gas system, Either from the gas valve or some other tubing. In this situation unless you understand how it works I would recommend getting a tech out to look at your system. That way you know that it is being done properly.
Jan 02, 2010 | Whirlpool GGQ9800L Gas Dryer
I have a a Whirlpool LGB6000KQ1 Gas Dryer. Sometimes the heat comes on, sometimes it does not. Could it be the thermostat or something else?
it appears as if your unit has a small plastic plug/access hole cover below the left corner of the dryer door. if you remove that you should be able to look within the dryers burner area and observe what might be happening..
if when you turn the dryer to a normal timed cycle, on high heat and start the unit, shortly after the dryer begins running you should be able to observe the glow ignitor glowing through that access hole, and shortly after that hear a click and flames appear, if is not glowing then there are probably thermal fuses blown out on the backside of your unit, or the ignitor is bad.
if however it does glow, and maybe even fire up once then all the safetys mentioned b4 are good.. now sit there and watch your ignitor/burner assembly.. the flame will cycle on and off depending on the dryers internal temperatures, but the main thing to look for is whether the ignitor glows, then fails to click then produce flames, if that be the case the gas valve coils are bad and need to be replaced part # is 279834 - M STYLE COIL KIT
hope this helps,
best of luck,
ttfn
Oct 25, 2009 | Whirlpool LGB6000KQ Gas Dryer
I have a Whirlpool LGB6000KQ1 Gas Dryer. It
Hello, Unfortunatly your wrong on all 3 counts sorry :) This problem is going to be your safety valve coils...basically they get old and over time of heating then cooling develop a short when they heat up...It may appear the gas lights to start but then goes out until the safety valve coils cool back down. Here is a picture of the coils 57d5263.jpgThis The coils are mounted to the gas safty valve, This should solve your problem. Hope this helps, Please feel free to comment again if you have any further questions or concerns. Good Luck! Mike
Sep 09, 2009 | Whirlpool LGB6000KQ Gas Dryer
Dryer smells like gas
If you smell gas then there is a leak. The gas company came out and checked for a leak? Get them back in the morning before you open the room to check again. Eric
Aug 27, 2009 | Whirlpool 7.4 Cu. Ft. 10-Cycle Super...
Whirlpool model LGB6000KQ1 gas dryer runs but has no heat only cool air. The timer when set to timed drying, moves down to off position, but does not shut off. Please let me know what parts may be faulty...
If the timer advances to OFF and does not stop you have a bad timer. It could also be the cause of no heat. Replace the timer first. If still no neat replace the glow bar ignitor.
Aug 24, 2009 | Whirlpool Dryers
Whirlpool gas dryer not heating up consistantly...
replace the sensor on side of the heat tube where valve and ign is located
Nov 26, 2008 | Whirlpool GGQ8831L Gas Dryer
Dryer has gas smell, whirlpool lgn 2000w gas dryer
Hello Tuna59,
I would strongly encourage you to identify the source of the gas leak as soon as possible. To do this, you can buy a product at most home depot or lowes department stores called SNOOP.. It is in essence..soapy water with a dauber in the cap. You use it by dunking the dauber in the solution and then putting the solution over gas piping joints. If it bubbles up at all..chances are that is where you have a small leak. You may or may not want to tackle that repair yourself since it poses personal risk if you don't know what you are doing. A build up of gas vapor in a confined space is very very dangerous and only needs a small ignition source to explode so please be careful. Probably a good idea to do all your troubleshooting ( if you decide to do this on your own ) with the windows open in that area. Do not use a fan or any other ignition source to move air/gas. Be careful.. and good luck...
Regards,
Rick
Nov 24, 2008 | Kenmore 63942 Dryer
Whirlpool GGQ8831L Gas Dryer Logo
356 people viewed this question
Top Whirlpool Dryers Experts
Tim Whalen
Sal De
Craig Butler
Craig Butler
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
