Question about Canon Pixma MP800 All-In-One InkJet Printer
Error U140 & U071 for Cannon pixma mp800
The error U 140 has just now shown up. Error U071 was first. Both pertain to the yellow ink tank. The printer eithr cannot find a yellow or there are 2 yellow tanks installed.
  • Anonymous Dec 13, 2008
    I have "EXACTLY" the same problem (Errors U071 for the yellow cartridge and U140) on my Canon Pixma MP500, which was barely used. Last time it was used for scanning and it stopped working after reboot. I guessed there's no relationship between the cartridges and the scanning function. It just simply stopped working... by itself !!!...
Thanks for checking back my printer problem. Solved the problem--purchased a new printer.My big problem now is repairs on my Mitsubishi WD 52725. I do not think I will buy a new one of those.I will purchase your help package for help with that. Please advise.
Cosie
Posted on Nov 29, 2008
Hi, I refilled cartridge CLI-526M fromCanon Prixma MG5250 and I have the error U130. How can I resolve the error to reprint? Thanks.
FAQ: An Error Message Is Displayed on the LCD
Issue
If an error message is displayed on the LCD, take the corresponding action described below.
Cause
The following ink may have run out. Replacing the ink tank is recommended. U041 Print head is not installed.Install the print head.U051 / The type of print head is incorrect.Install the correct print head.U052 Some ink tanks are not installed in place. U072 / More than one ink tank of the following color is installed. U071 The remaining level of the following ink cannot be correctly detected. Replace the ink tank. U130 The following ink tank cannot be recognized. U043 U140 U150 The following ink has run out. Replace the ink tank. U163 There are no photos in memory card Contact the support center or service center for ink absorber replacement. Press OK to continue printing Ink absorber full. Service required Timeout error has occurred The device may be incompatible. Remove the device and check the manual supplied with the connected device An unsupported USB hub is connected. Remove the hub. B200Printer error has occurred. See the manual **** Printer error has occurred. Turn off power then back on again. If problem persists, see the manual
Jul 06, 2011 | Canon MG5250 Printer
Error code U071 , more than one ink tank of te following color is installed, is the message on the screen. This is not the case as each cartridge is different and correctly installed?
Error U071 : More than one ink tank of the following color is installed. U071.
Action : Confirm that the ink tanks are installed in the appropriate positions.
The machine will not print if the wrong type of ink tank is used, or if it is installed in the incorrect position.
Be sure to install the ink tanks in the correct order. The proper arrangement from the left is Black (CLI-8BK), Black (PGI-5BK), Yellow (CLI-8Y), Magenta (CLI-8M), Cyan (CLI-8C).
Hope this hepls.
Nov 28, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Error U071 ;more than one ink tank for black
your chip may get something wrong if the sensor is dirty or some ink goes over it!try to pull out the Bk carige and put it back again if not help try same but get some tishue and clean up the chip contact serfice!
Aug 24, 2009 | Canon Pixma MP500 All-In-One InkJet...
Error U071 or U140
check in bottom of the ink cartidge u must have to remove plastic strip.then also check u proper fixed ink cartridge in ink tank as matching color.
re-seating the cartridge may temporarily fix the problem but it will not last. but if even that doesnt give u relief.... then its a hardware failure and wud service is required at this point. contact Hp...
thank you for using Fixya...
have a nice day
Jul 16, 2009 | Canon Pixma MP950 All-In-One InkJet...
Error U071
Make sure that the inks are not re-manuafactured ones with chips taken off genuine canon inks. It is possible that the wrong chips could be fitted to the wrong colours.
Dec 04, 2008 | Canon PIXMA MP830 All-In-One InkJet...
Canon PIXMA MP530 printer repeatedly getting LCD Error Message: "CHECK INK U071 5Bk". I have removed, reinstalled, reseated the 5Bk and all other ink tanks multiple times. Usually when this...
I have Canon M560 printer installed 8 months ago. I replaced the CLI 221 Magenta and CLI221 Cyan ink cartridges, won't work and got this message Error 1411. Tried repeatedly to reinstall the ink cartridges and still have this message coming back. Any solution you could offer? I would appreciate it. Thank you.
ben
Nov 06, 2008 | Office Equipment & Supplies
Alarm light is lit -
Ok my printer is giving me the U140 message saying that ink tank cannot be recognized. The new ink tank is Cannon (not a off brand or refill). i think it is a problem with the chip reader port inside the printer not the ink tank chip. I feel this way because if you switch around the yellow and black 8 tanks, the printer accepts them without error.. soo if it was the ink cartridge i could be able to swap the black with the magenta and it should read it.
Sep 08, 2008 | Canon Pixma MP500 All-In-One InkJet...
UO71 More than one ink tank of the follwoing color is installed/U140 The following ink tank cannot be recognized
i had the same problem and when i checked inside to see why it was not working with the cyan i saw that a sensor was the problem... it had fallen out. check it out and let me know if it is the same with yours.
May 15, 2008 | Canon Pixma MP500 All-In-One InkJet...
Canon Pixma MP800 All-In-One InkJet Printer Logo
879 people viewed this question
old marine
old marine
