Question about Soltek (SL-5700L-XD) (128 MB) Graphic Card
My Soltek Geforce 5700 (SL5700XD) heat sink fan.
Just bought this card off of ebay and it is supposed to be "almost" new, however the heatsink fan is definitely not on. The card works and provides good graphics, however I'm worried that this will shorten the life of the graphics processor and cause it to run poorly. Is it run by drivers that will turn on that fan at a cerain temperature? Or is it probably a faulty fan? Will this cause problems with the quality of video?
  • Matt Sherwood
    Matt Sherwood Jan 26, 2007
    Thanks for the help. I just did a workaround and added a case fan that blows on it. It seems to work well enough while playing games.
  • 31 Answers
If the fan seems to belong there, then it must run, may be slower at idle but must run or at least spin-up at boot time. Better put any fan u can get on it, even a 10cm case fan will do. On the other hand, if you dont play games on it in sommer, it will survive the rest. There are heat sinks without fans on cheap cards and they work (like the MX series Nvidia) Start a game, OpenGL or D3D and let it render for a hour or so, while being arround. If the screen doesnt display any funny rectangles or freezes, you should be ok. The heat wount kill the card, cause yours already has a overheat protection in the chip.
Posted on Jan 26, 2007
Alert chipset heat sink not detected system halted dell xps 420
Sounds like your heatsink which is inside the computer and sits on top of the CPU is bad. There will probably be a fan that sits on top of the heatsink.
Look on ebay and purchase one for your system.
http://www.ebay.com
I found a new one below on ebay for $14.95 (the link is below)
http://www.ebay.com/itm/New-OEM-Dell-Dimension-9100-XPS-420-430-Heatsink-Assembly-XP850-/350520689627?pt=LH_DefaultDomain_0&hash=item519ca943db
May 12, 2012 | Dell XPS Computers & Internet
I have an HP pavilion with an AMD Phenom X4 9750 processor with an Nvidia GeForce 9100 graphics card. I have noticed a ridiculous decrease in frame rate that happens randomly while i play pc games...
hi,
you may even find a new graphics card won't help. you are most likley suffering from an overheated northbridge. there not usually monitored for temp this is on the MB so, not good news as this will eventually go dead. and even re- greasing at this point won't help. however. by disassembling both the video card and northbridge heat sinks. you should find one of them pretty dried out.
GL
hope this helps
don't forget to vote for me
Thanks
Jamer
Jul 12, 2011 | HEWLETT-PACKARD HP Pegatron M2N78-LA ASUS...
I have a 3dfr6200lee BFG Technologies 3DFuzion GeForce 6200 LE Graphics Card. The cooling fan on it broke, and I am looking for a replacement fan. What is the specs on the fan itself ... ie, pin width,...
Hi, Amazon sells a 40mm fan for about 4.99, it is a 3 pin setup (may be available in 2 pin). But that should be about the same size as your existing card fan. Just watch for height issues on the new fan. This would be easier that trying to replace the existing fan, as it is most likely powered through your video card port and would be difficult to replace.
As far as mounting it to the card, try just a couple of drops of super glue on the outside corners of the fan, then mount it to the heat sink on the card, the existing fan is probably mounted w/ screws, you may get lucky and the new fan will match the existing holes, otherwise just super glue it.
Not a factory fix, but it will work!
Take care Dave
Mar 30, 2011 | BFG Technologies (3DFR6200LEE) 3D Fuzion ...
Am using an mPAQ model:M66SE laptop. it heats up very much and after few minutes it hugs up.until i restart and wait few some minutes and cools. what will i do. the heat sink on top of the south bridge is...
remove your heat sink then clean the surface of the heat sink with clen cloth apply athin layer of heatsink compund and fix the heat sink tightly if the heatsink is dried or worn out the heatsink gets heated up also check the fan is working
Mar 28, 2011 | Compaq Heatsink CPU Heatsink & Fan
Must heatsink have epoxy before clamping onto mount
DO NOT use anything on the heat sink but heat sink compound!!!!!!!
Jul 21, 2010 | Dell (N1240) Heatsink With Fan
HP stops giving input to mnitor, have to reboot whole system.
that is problem of processor when processor is overheated it do so there is a white heat sink compound between processor and heatsink detach heat sink and apply new heat sink compound on the processor and look properly that heatsink is firmly fixed to processor or not .it may problem of fan if fan is rotating with low frequency then also it happens replace new fan the frequency of fan can be seen in setup
Apr 03, 2010 | HP Pavilion F1903 19" Flat Panel LCD...
New Video card cooling
I would highly reccomend paying for an aftermarket heatsink insted of playing too much with additional fans on the graphics card. While bigger fans make small difference, a bigger better heatsink, with higher quality/conductivity contact material (copper) makes a HUGE difference. Also the way the heatsink contacts the processor on the graphics card is very important, thousands of PC modders apply "Artic Silver 5" to the bottom of the graphics card heatsinks(where it contacts the processor) and have large drops in temperatures. The compound costs about five to ten dollars, and most neighborhood radioshacks have it in stock.
If your interested in getting a new heatsink: (See GPU heatinks at newegg.com)
Just make sure its compatible with your particular card.
May 14, 2009 | HP Pavilion a705w PC Desktop
Upgrading the cpu and heat sink and fan
All the factory fitted CPUs are having such heat sinks as previously u were having.
Check on the backside there will be small plastic covers where screws fit these could be removed by screw driver but u can purchase that heat sink or can use previous heatsink as well if it is working.
Feb 26, 2009 | Intel Socket 775 Heat Sink and Fan up to...
Having Problem with my GeForce FX 5700 Graphic Card
The card may be overheating and switching to lower DPI to save on the power consumption and heat. Try using a diagnostic utility to check the card temperature. Also, check the heatsink/fan to make sure that it is properly seated on the card.
Aug 18, 2006 | XFX GeForce FX 5700 Graphic Card
Soltek (SL-5700L-XD) (128 MB) Graphic Card Logo
81 people viewed this question
Top Soltek Computers & Internet Experts
clar4444
Level 1 Expert
Paul Bade
Steven Wander
Steven Wander
Are you a Soltek Computer and Internet Expert? Answer questions, earn points and help others
