Question about Farmall Toys
Tractor stalls after approx. 15-20 of run time (1957 farmall cub)
It will start back up after 5 min. but only run for 2-3 minutes. I replaced the coil (6V pos. ground system) with one from Tractor Supply and the tractor won't start at all. Put the old coil back in and it fires right up. Is it a coil problem? The coil I bought is 6v IH coil but the terminals are on the opposite end. The coil for 12v systems looks just like the one in there now?????????
Could you be having a fuel supply problem? I have a 1957 Farmal Model 100 and has its own problem caused by moisture building up in the distributor SLOCITYJOHN
Posted on Sep 18, 2011
  • 46 Answers
Try the 12volt coil. and remember the positive verses ground . you might have to order one from whitenys.com search that web site , i hope i spelled it right ,dang it sucks being 50 years old and cant remember things. but any ways check that website out okay .
Posted on Dec 01, 2008
Show me how to wire farmall cub tractor when converting from 6 volt to 12 volt. It's a 1951 farmall cub
Replace the coil with a 12volt coil. Replace the generator with an alternator. Replace any light bulbs with 12volt. Fit the new 12volt battery in with the negative terminal to chassis! and there you have it.
Feb 02, 2017 | Farmall Garden
My 1953 international cub farmall won't stay running?
If furl flow not issue?,. Code be when ignition coil gets hot.
Jun 21, 2014 | Cub Cadet Street Sign- tractor lawn riding...
Cub Cadet LT1050 Runs fine..20 min...dies...wait 20 min....runs fine 20 min.
Check the breather in the fuel cap, run it with the cap loose and see if it is any better.
May 30, 2013 | Cub Cadet Riding Lawn Garden Tractor 25hp...
Stalling after one hour run time
Sounds to me like you need to replace the ignition coil,they will go open when they get hot and when this happens the plugs will stop fireing.
Apr 22, 2010 | John Deere 420,1020,2010,2020,2510,2520...
Changing the oil
Hi there..my name is Keith and i restore tractors....and to answer your question..a Farmall Cub hold 3 quarts of oil..i hope this has helped
Jun 28, 2009 | Farmall Cub Tractor Radiator
Farmall Cub 1955, runs fine for about 20- minutes
I have cub that done same thing, there was crud in orfice between tank and sediment bulb, cleaned orfice, runs fine.
May 30, 2009 | Farmall Cub Tractor Radiator
1957 Farmall Cub was running and starting fine. Started most of the time when the engine turned over. I was pulling some dirt and made a couple of passes. After a couple of passes it shut down and would...
Hi..my name is Keith..and i restore tractors..and when they dont run..its usually from the lack of spark or fuel...but its common on the cubs to have rust(trash) in the fuel tank..but both the gas and spark are easy to check..i hope this has helped
Apr 14, 2009 | Garden
Engine quits after running 15 min
Hi..my name is Keith..i restore mostly old Ford tractors but i work on others...and this problem that you are having is kind of puzzling..but whatever it is..its either fuel or ignition..on the ignition side of it..i would suspect the coil or the condenser is breaking down when the engine warms up..and on the fuel side..i would suspect rust(trash) in your fuel tank and its stopping up your fuel line(which will need to be blown out with air)..or the fuel line is too close to a heat source and its vapor locking...i hope this will help..please write back if this doesnt
Apr 06, 2009 | Garden
Toys Logo
839 people viewed this question
Top Farmall Toys Experts
Wayne Fellows
Wayne Fellows
Phil Walker
Phil Walker
Jerry Radcliffe
Are you a Farmall Toy Expert? Answer questions, earn points and help others
